Ovo sam skinuo sa engleskog foruma. Lepo izgleda.
Zeïren 2:
15
6
6-10
6-8
7
0
Born killer, Résolution/2, Implacable/1, Wild/10, Personal Enemy the watcher.
92 ap
Blade Mistress (Eclipsante):
15
5
6-8
5-6
6
3
Born killer, assassin, Feint
In Rag, they use the same ability as Managarm/Meyleen if they are leading the group..just like normal Eclipsantes
50 ap
Ashkasa, warrior of blood
12,5
5
5-7
5-7
6
3
Bravery, commandement/12, 5, Ambidextrous
68 ap
Master of carnages
12,5
4
5-6
5-7
6
2
Power 2
Ambid, Scout, Initiate of Water / Torments
42 ap
Revelations of the Beast - Devourers
- jorgurt hlebozvak
- jorgurt hlebozvak
NAstaval
Pa onda sledi:
Ring of absence:
11 Pa.
The carrier cannot be taken for target direct of a shooting, of a miracle or magic spell if another devourer is near and free of any adversary.
Do not count in the maximum of artifact if the carrier is associated with the Blasphemy Revelation.
Voracious blade:
13 Pa.
Any critical wound inflicted by the carrier one is killed Net. With rag, the 5 are regarded as 6.
Ring of absence:
11 Pa.
Voracious blade:
13 Pa.
- jorgurt hlebozvak
Nastavak 3
I jos malo:
Armageddon.
Chief: Ellis
Révélation/1 Pa.
+1 with the Discipline roll, and the player can designate one Character to gain Authority
Solo instinct of warrior 2 Pa:
give Fencer
Solo special lord of the apocalypse.
Cost equal to the rank multiplied by 10. The character gives +X in Stregth to all the Devourers with Leadership range equal to his Rank. i.e. Nekhar = Rank 2...for 20 points he gives all Devs within Leadership +2 Str.
Blasphemy
Chief: Styx
Revelation Anathema 1 Pa:
1 marker for each (I assume incomplete) 250 ap of Devourers (500 ap for Rag) is acquired by the player. Each marker can be used to reroll an unfavorable roll..
Solo: Apostate 3 Pa. Give Insensitive / 5
Solo: killer of idols 1 Pa.
+1 to Str if the combatant is in the Aura of Faith of a Priest (friendly or enemy). Max +3. (this could be very cool....)
Carnage
Chief: Shurat
Revelation (2 Pa)
Courage / Fear +1
Solo/fury 2 Pa: To allot to a maitre carnages.
A MoC can distribute Points of Fury to any Dev within 15 cm. Line of sight is not required.
Solo/ bloodthirsty 4 Pa: Give implacable/1 or increases by 1 the value. Max: +3.
Armageddon.
Chief: Ellis
Révélation/1 Pa.
give Fencer
Blasphemy
Chief: Styx
Carnage
Chief: Shurat
Revelation (2 Pa)
Courage / Fear +1
- jorgurt hlebozvak
Slike
A odavde mozete skinuti karte. Koje sam ja naravno vec skinuo.
http://www.subculture.plus.com/ragnarok/mda_eclip.jpg
http://www.subculture.plus.com/ragnarok/ashkasa.jpg
http://www.subculture.plus.com/ragnarok/he_moc.jpg
http://www.subculture.plus.com/ragnarok/zeiren2.jpg
http://www.subculture.plus.com/ragnarok ... geddon.jpg
http://www.subculture.plus.com/ragnarok ... sphemy.jpg
http://www.subculture.plus.com/ragnarok/rev_carnage.jpg
http://www.subculture.plus.com/ragnarok/rev_eclipse.jpg
http://www.subculture.plus.com/ragnarok/rev_ecstasy.jpg
http://www.subculture.plus.com/ragnarok/rev_impure.jpg
http://www.subculture.plus.com/ragnarok/rev_impure2.jpg
http://www.subculture.plus.com/ragnarok/rev_rebel.jpg
http://www.subculture.plus.com/ragnarok/rev_rebel2.jpg
http://www.subculture.plus.com/ragnarok/rev_beast.jpg
http://www.subculture.plus.com/ragnarok/rev_beast2.jpg
http://www.subculture.plus.com/ragnarok/miss_eclips.jpg
http://www.subculture.plus.com/ragnarok/ring.jpg
http://www.subculture.plus.com/ragnarok ... _blade.jpg
I sad samo jos da to Oli prevede. Please.
- jorgurt hlebozvak
Prevod
Pa se neko dobar tamo vec nasao da prevede bar ugrubo ove pack-ove
Revelation: Armageddon
Revelation/Disciple of the Beast: In conf, Authority can be given to any devourer. It does not have to be a character!
Solo/Lord of the Apocalypse: The lord of the apocalypse also benefits from the bonus.
Revelation: Blasphemy
Revelation/Anathema: Themarker can be used to reroll a (INI, ATT, DEF, AIM, COU, DIS, Power or Divination) roll. It can reroll a roll made by a friend OR AN ENEMY. If several dice were used in the roll, all are re-rolled. If both sides wanted to reroll that roll the abilities cancel out.
Solo/Killer of Idols: Devourer faithful benefit from the bonus themselves.
Revelation: The Impure
Revelation/Impure: The army must consist of at least 50% non-wolfen, counting models not AP, including allies.
Solo/Poacher: The ability gained is 'minelayer', as in the rulebook page 138.
A model cannot have more than one of the 'blood of...' solos. (If I understood that sentence correctly...)
Revelation: The Rebellion
Revelation/Indomitable: +1 to the attack roll and to STR if the devourer is within range of AN ENEMY COMMANDER, or, if there is no enemy commander with leadership, if the devourer is within range of a friendly commander. The bonus is not cumulative.
So there will only be one model at a time that grants this bonus.
Solo/Subversive: The model retains leadership but it no longer transmit its values in COU/FEAR and DIS. However, enemies of a rank equal to or lower than the Subversive and in its leadership range suffer from a -2 penalty to the final results of their COU and DIS tests. This ability does not affect enemy constructs, immortals, righteous models ('Juste' is Righteous, right?) and living-dead.
Solo/Rebel: The cost of the Revelation is included in the cost of Rebel.
Ring of Absence: The carrier cannot be taken as a direct target of firing, a miracle or a spell if another devourer is CLOSER to the firer/spellcaster and not in contact with an enemy.
