[VtES] Lords of the Night preview
- Resurrection
- Resurrection
- Resurrection
Da, ne mozes igrati isti reaction vise od jednom, a kako se akcija ne zavrsava dok se svi reactioni ne odrade, ja cenim da je da ne moze da se odigra vise od jednom po akciji bez obzira ko je igrao kartu. Cekam onikicu za klarifikaciju. Koliko sam upozant, recimo ti ne mozes da igras dva puta redirection, cak i da ga igras sa dva razlicita vampira, sem kao redirect karta nije neka druga.
ne, mozes da bacis dva ista defeksna sa istog vampira - svaki novi blid na tebe je nova prilika da reagujes.
Stoga - ovu kartu ne mozes da igras tako! Nju igras jednom po akciji.
- Resurrection
Ne, ne racuna se kao novi blled atempt za potrebe (reakcionih) karata.Megabaja wrote:da, racuna se - mozes ponovo da ga npr. smanjis za dva.
Sve sto odigras za vreme blida ne tebe i dalje radi cak i kad prebacis blid dalje.
Dakle, ako si odigrao Wake i dalje mozes da igras reakcije i da blokiras kad ti se blid vrati, ali to znaci da ne mozes da igras Wake ponovo (istim vampirom) jer si ga vec odigrao.
Ako si nabacio 3 intercepta i dalji imas 3 intercepta kad ti se blid vrati.
Svi efekti reakcija su za vreme trajanja cele akcije.
- Resurrection
Akhenaten, The Sun Pharaoh (Mummy)
Type: Ally
Cost: 4 pool
Unique mummy with 3 life. 3 strength, 1 bleed.
Akhenaten may play cards requiring basic Necromancy [nec] as a vampire with a capacity of 3. Any cost in blood is paid with his life. If a card would give him blood, give him life. If he is burned, shuffle him into your library. If he is in combat with a Follower of Set, any damage he inflicts is aggravated. Akhenaten can burn himself to burn a Follower of Set controlled by your prey as a (D) action.
Amam the Devourer (Bane Mummy)
Type: Ally
Requires: Follower of Set
Cost: 2 pool
Unique mummy with 3 life. 0 bleed, 2 strength.
Amam may enter combat with any ready minion controlled by another Methuselah as a (D) action. Amam may burn a vampire in torpor to gain 1 life as a (D) action. This does not constitute diablerie. If a minion opposing Amam in combat is burned, Amam gains 1 life. If Amam is burned, shuffle him into his owner's library.
Kherebutu (Bane Mummy)
Type: Ally
Cost: 5 pool
Unique mummy with 3 life. 3 strength, 2 bleed.
Kherebutu may play cards requiring basic Necromancy as a vampire with a capacity of 3. Any cost in blood is paid with his life. If a card would give him blood, give him life. If he is burned, shuffle him into your library. (D) Burn Kherebutu to burn a Tremere with a capacity below 5 controlled by your prey.
Qetu the Evil Doer (Bane Mummy)
Type: Ally
Cost: 3 pool
Unique mummy with 3 life. 2 bleed, 1 strength.
Once per combat, Qetu can press to end combat. If Qetu is burned, shuffle her into her owner's library.
Tutu the Doubly Evil One (Bane Mummy)
Type: Ally
Cost: 4 pool
Unique mummy with 3 life. 1 bleed, 2 strength.
Once during each of your minion phases, you can untap Tutu. Once each combat, Tutu may dodge as a strike. Tutu may steal an equipment card from a vampire in torpor as a (D) action. If Tutu is burned, shuffle him into his owner's library.
Type: Ally
Cost: 4 pool
Type: Ally
Cost: 2 pool
Type: Ally
Cost: 5 pool
Type: Ally
Cost: 3 pool
Type: Ally
Cost: 4 pool
- Resurrection
- Resurrection
SPOJLERI:.
Mesu Bedshet
Action. Requires FoS.
+1 stealth action.
Show the top card of your crypt to all players. If it is a Follower of Set,
move the card to your uncontrolled region. If it is a younger FoS, move 2
blood from the blood bank to it. If it is not a Follower of Set, shuffle it
back into your crypt.
Blithe Acceptance
Action
1 blood
obf: Put this card on the acting vampire. This vampire gets +1 stealth. Burn
this card if this vampire enters combat. A vampire can only have 1 Blithe
Acceptance.
OBF: As above, but this vampire can burn 1 blood when he enters combat
instead of burning this card.
Vessel
Master. Trifle.
1 pool
Put this card on a vampire, and you may burn a Blood Doll in play (if any).
During this vampire's controller's untap phase, he or she may move 1 blood
from this vampire to his or her pool or from his or her pool to this
vampire.
Dream World
Action
pre: (D) Bleed at +1 bleed.
PRE: +1 stealth action. Each of your minions gets +1 bleed for the remainder
of the turn or until a bleed action is blocked. Only one Dream World can be
played at superior each turn.
Eluding the Arms of Morpheus
Reaction
1 blood
Only usable by a tapped vampire. This vampire untaps and attempts to block.
Mental Maze
Reaction
1 blood
Only usable when this vampire successfully blocks an ally or younger vampire
(play before combat, if any).
obf: End the action (with no combat). If this blocking minion is an FoS,
this card costs 1 less blood.
OBF: As above, and do not tap this blocking vampire.
Into Thin Air
Action Modifier.
Do not replace until your untap phase.
obf: +1 stealth. Once this action, this vampire may burn 1 blood to give an
ally or younger vampire -1 intercept. Into Thin Air and Lost in Crowds may
not both be played on the same action.
OBF: As above, but for +2 stealth.
Can't Take With You
Political Action
Successful referendum means each Methuselah gains 1 pool. Each Methuselah
then burns 1 pool for each equipment, location, or retainer card he or she
controls.
Heart's Desire
Action Modifier
1 blood
aus chi: +1 bleed. You cannot play another action modifier to increase this
bleed. If an ally or younger vampire is currently attempting to block this
action, that block fails and that minion cannot block this action.
AUS CHI: As above, but with +2 bleed instead.
++DRAFT++ chi: as aus chi above.
Autonomic Mastery
Combat. Only usable at close range.
dom: Strike- burn the opposing non-wraith ally or a non-wraith retainer on
the opposing minion.
DOM: Strike- make a hand strike. Damage from this strike is reduced to zero.
Combat ends immediately after this strike resolves, unless it is dodged.
Only usable in combat with a non-wraith ally or a younger vampire.
Camera Phone.
Electronic equipment.
The minion with this equipment can bleed at +1 bleed as a (D) action. No
other equipment can increase the bleed amount of this action.
Burden The Mind.
Master.
1 pool.
Put this card on any minion. While it is not this minion's turn, using an
effect to untap this minion or to allow this minion to block as if untapped
costs an additional pool. This minion can burn this card and untap as a (D)
action.
Monty Coven
Assamite
8
CEL OBF QUI pre dom for
Group 5.
Sabbat. If Monty burns a titled vampire, he may become a bishop. If the
burned vampires title was worth more than two votes, he may become a priscus
instead. (The blood curse does not affect Monty.)
Belle Equitone
2
ser
Group 4.
Marla Kenyon
4
PRE ser
Group 4.
Halim Bey
6
DOM SER obf tha
Group 4.
While Halim is ready, mummies you control get +1 stealth.
Renenet.
5
OBF PRE ser
Group 4.
Sundervere, the Devil Brahmin
8
AUS PRE SER THA obf
Group 4.
Red List. If Sundervere is burned, you burn 1 pool. Once each action, he may burn 1 blood to get an additional +1 bleed. +1 bleed.
Unholy Penance
Combat
1 blood
Inferior Presence Strike- Combat Ends
Superior Presence As above, and put this card on the opposing minion (ranged). The
striking vampire gets +1 bleed against this minion's controller. This minion
may burn this card as a +1 stealth action. A minion can only have 1 Unholy
Penance.
Public Trust
Action
1 blood
Inferior Presence (D) Bleed at +2 bleed.
Superior Presence As above, and if the bleed is successful (for 1 or more), add 1 counter to a vampire in your uncontrolled region from the blood bank.
Zapaderin
Action Modifier. Requires Ravnos.
1 blood
Only usable by a ready untapped Ravnos other than the acting minion.
Allies and vampires younger than the modifying Ravnos get -1 intercept onthis action.
Agent of Power
Master. Discipline. Trifle. Unique.
Put this card on a vampire you control and choose a Discipline. This vampire gains 1 level of that Discipline. Burn this card during your discard phase.
++DRAFT++ As above, but this card not unique and is not burned during your discard phase.
Cobra Fangs
Combat
1 blood
Inferior Serpentis Strike: make a hand strike (at strength damage). If any damage from this strike is successfully inflicted on an opposing ally, burn that ally at the end of the action.
Superior Serpentis As above, and if any damage from this strike is successfully inflicted
on an opposing vampire, that vampire goes to torpor during his next untap phase.
Warrant
Political Action
Choose a younger ready vampire. If this referendum succeeds, put this card on that vampire. Any ready vampire may enter combat with this vampire as a (D) action that costs 1 blood.
++DRAFT++ (Requires Assamite) Action. Return this card to your hand (discard afterward) and enter combat with a younger vampire.
Forearm Block
Combat
Strike: Prevent 2 damage from the opposing minion's next hand strike this round (including any currently-resolving hand strike). If another round of combat occurs, this minion gets first strike on his or her initial strike that round.
Nightstick
Equipment. Melee weapon.
1 pool.
Strike: strength +1 damage. Or strike- prevent 3 damage from the opposing minion's next hand or melee weapon strike this round (including any currently-resolving hand melee weapon strike). Only usable once each round.
Jericho Founding
Political Action. Requires a non-Camarilla vampire.
Successful referendum means all locations are burned. Any Methuselah can keep any locations he or she controls by repaying their pool cost.
Mercury's Arrow
Combat
1 blood
Inferior Celerity Strike: 1R damage, with an optional manuever.
Superior Celerity Strike: 3R
++DRAFT++ As cel above.
Quick Jab
Combat. Do not replace until after combat.
Strike: Make a hand strike (at strength damage) at first strike. If more
than 1 damage is inflicted with this strike, ignore the excess.
++DRAFT++ Strike: make a hand or melee strike at +1 damage.
Sympathetic Agony
Combat
Inferior Chimerstry Inferior Fortitude For the remainder of combat, when any damage is successfully
inflicted on this vampire in a round, the opposing minion becomes unable to use presses that round.
Superior Chimerstry Superior Fortitude As above, and if any damage is successfully inflicted on this
vampire in a round, the opposing minion becomes unable to use any additional strikes that round.
Ogwon
Follower of Set
7
OBF PRE SER for
Group 5.
If an ally or younger vampire attempts to block Ogwon and fails, that minion burns one blood or life when the action resolves (before resolving the action).
Jayakumar
Ravnos
6
ANI FOR chi tha
Group 5
Jayakumar may steal an equipment from any minion as a (D) action that costs 2 blood.
Arnulf Jormungandrsson
Follower of Set
8
OBF PRE SER aus cel
Group 5.
Camarilla. If Arnulf attempts to block, the acting minion cannot play action modifiers that require dem, dom, nec, or pre.
Mesu Bedshet
+1 stealth action.
Blithe Acceptance
Action
1 blood
Acceptance.
Vessel
Master. Trifle.
1 pool
vampire.
Dream World
Action
Reaction
1 blood
Mental Maze
Reaction
1 blood
Into Thin Air
Action Modifier.
Can't Take With You
Political Action
controls.
Heart's Desire
Action Modifier
1 blood
Autonomic Mastery
Camera Phone.
Burden The Mind.
Master.
1 pool.
action.
Monty Coven
Assamite
8
Group 5.
Belle Equitone
2
ser
Group 4.
Marla Kenyon
4
PRE ser
Group 4.
Halim Bey
6
DOM SER obf tha
Group 4.
Renenet.
5
OBF PRE ser
Group 4.
8
AUS PRE SER THA obf
Group 4.
Unholy Penance
Combat
1 blood
Penance.
Public Trust
Action
1 blood
Zapaderin
1 blood
Agent of Power
Cobra Fangs
Combat
1 blood
Warrant
Political Action
Forearm Block
Combat
Nightstick
1 pool.
Jericho Founding
Mercury's Arrow
Combat
1 blood
Quick Jab
Sympathetic Agony
Combat
Ogwon
Follower of Set
7
OBF PRE SER for
Group 5.
Jayakumar
Ravnos
6
ANI FOR chi tha
Group 5
Follower of Set
8
OBF PRE SER aus cel
Group 5.
- Resurrection
SADRZAJ FOLLOWERS OF SET DEKA
CRYPT (2 each)
Nakhthorheb
10
OBF PRE SER
Group 4.
May untap once during each of your minion phases. Minions with your
corruption counters may not block him. +1 strength.
Belle Equitone
2
ser
Group 4.
Marla Kenyon
4
PRE ser
Group 4.
Halim Bey
6
DOM SER obf tha
Group 4.
Renenet.
5
OBF PRE ser
Group 4.
8
AUS PRE SER THA obf
Group 4.
LIBRARY
Dream World x4
Revelation of Ecstasy X4
Secure Haven (new art)
Form of Corruption
Cloak the Gathering (new art) x2
Truth of a Thousand Lies x2
Eluding the Arms of Morpheus x2
Mental Maze x2
Vessel x2
Revelation of Despair x3
Public Trust x2
Khobar Towers, Al-Khubar
Majesty x4
WMRH Talk Radio
Dummy Corporation
Enticement x2
Opium Den
Temptation (new art) x3
Veil the Legions x2
Approximation of Loyalty x3
Confusion of the Eye x3
The Crocodile Temple
Hierophant
Into Thin Air x2
Revelation of Desire x3
Revelation of Wrath
The Jones x3
True Love's Face x4
Spying Mission x2
Ecstasy x3
Unholy Penance x3
Blithe Acceptance x2
Temple Hunting Ground
Tutu, the Doubly Evil One
Serpentis
Wash
The Summoning
Mesu Bedshet
CRYPT (2 each)
Nakhthorheb
10
OBF PRE SER
Group 4.
Belle Equitone
2
ser
Group 4.
Marla Kenyon
4
PRE ser
Group 4.
Halim Bey
6
DOM SER obf tha
Group 4.
Renenet.
5
OBF PRE ser
Group 4.
8
AUS PRE SER THA obf
Group 4.
LIBRARY
Dream World x4
Form of Corruption
Mental Maze x2
Vessel x2
Public Trust x2
Majesty x4
WMRH Talk Radio
Dummy Corporation
Enticement x2
Opium Den
Veil the Legions x2
Hierophant
Into Thin Air x2
Revelation of Wrath
The Jones x3
True Love's Face x4
Spying Mission x2
Ecstasy x3
Unholy Penance x3
Serpentis
Wash
The Summoning
Mesu Bedshet
- Resurrection
