LINK
Provalite reversed komi znak za ediciju
Twilight Rebelion preview
- Resurrection
Re: Twilight Rebelion prewiew
Hmmm.. tremere anarhsi? interesantno... Edicija bas i nema nesto mnogo vapira, booster only edicija je, right? Ili ce biti preconsturcted deckova?
- Resurrection
Samo 60 novih karata.
- Resurrection
Re: Twilight Rebelion preview
#01: Clifton Derrik [TR:V]
Clan: Brujah
Group: 4
Capacity: 2
Discipline: cel
Camarilla.
#02: Jack Drake [TR:V]
Cardtype: Vampire
Clan: Brujah
Group: 4
Capacity: 8
Discipline: pre tha CEL POT
Independent. Anarch. When you put a younger vampire in play from your uncontrolled region, that vampire may burn a blood to become anarch. +1 Strength.
Artist: Leif Jones
#03: Marguerite Foccart [TR:V]
Clan: Brujah
Group: 4
Capacity: 6
Discipline: aus pot PRE CEL
Camarilla. Marguerite gets +1 intercept vs. political actions.
#04: Anarch Convert [TR:V]
Clan: Caitiff
Group: any
Capacity: 1
Discipline: -
Independent. Anarch. When the convert enters play, you may remove him from the game to make a non-titled vampire you control anarch and either gain 1 pool or draw a card from your crypt.
#05: Andy [TR:V]
Clan: Caitiff
Group: 4
Capacity: 1
Discipline: for
Camarilla. An older vampire opposing Andy gets one optional press each combat.
#06: Dirk [TR:V]
Clan: Caitiff
Group: 4
Capacity: 1
Discipline: pre
Camarilla. Titled vampires get +1 intercept when attempting to block Dirk.
#07: Calvin Cleaver [TR:V]
Clan: Gangrel
Group: 4
Capacity: 3
Discipline: for pro
Camarilla. Calvin may add a blood to an anarch as a +1 stealth action. Once each turn, an anarch may add a blood to Calvin as a +1 stealth action.
#08: Jacob Fermor [TR:V]
Clan: Gangrel
Group: 4
Capacity: 5
Discipline: ani tha PRO
Independent. While Jacob is ready werewolves you control get +1 bleed. Jacob gets an optinal press each combat.
#09: T.J. [TR:V]
Clan: Gangrel
Group: 4
Capacity: 3
Discipline: cel for
Independent. T.J. may tap and burn 2 blood to cancel a referendum called by a titled Camarilla vampire.
#10: Antoine, The Lost [TR:V]
Clan: Malkavian
Group: 4
Capacity: 5
Discipline: aus cel dem OBF
Camarilla.
#11: Sean Rycek [TR:V]
Clan: Malkavian
Group: 4
Capacity: 4
Discipline: aus dem
Camarilla. Once each referendum Sean may tap or burn a blood to gain 2 votes. He may burn a boon as a +1 stealth (D) action.
#12: Toby [TR:V]
Clan: Nosferatu
Group: 4
Capacity: 5
Discipline: ani obf pre
Camarilla. Once each action, Toby can burn a blood to give an acting anarch +1 bleed.
#13: Topaz [TR:V]
Clan: Nosferatu
Group: 4
Capacity: 7
Discipline: ani for qui OBF POT
Camarilla. When Topaz successfully equips from your hand, you may look at your prey`s hand, and Topaz may take an equipment from it instead (discard the original equipment card).
#14: Laecanus [TR:V]
Clan: Toreador
Group: 4
Capacity: 5
Discipline: obt pre CEL
Camarilla. Once each combat, Laecanus may press to end combat. He is immune to frenzy cards.
#15: Lin Jun [TR:V]
Clan: Toreador
Group: 4
Capacity: 4
Discipline: aus cel pre tha
Camarilla. If Jun is in torpor, vampires with Thaumaturgy controlled by your predator get +1 bleed.
#16: Preston Varrick [TR:V]
Clan: Tremere
Group: 4
Capacity: 7
Discipline: aus nec DOM OBF THA
Camarilla. Preston gets +1 bleed when bleeding a Methuselah who controls a ready ally.
#17: Tarautas [TR:V]
Clan: Tremere
Group: 4
Capacity: 4
Discipline: aus nec tha
Camarilla. While Tarautas is ready, Blood Doll and Minion Tap cards cost an additional pool.
#18: Juniper [TR:V]
Clan: Ventrue
Group: 4
Capacity: 6
Discipline: ani dom pre FOR
Camarilla. Juniper may steal an ally controlled by your predator or prey as a +1 stealth (D) action.
#19: Louis Fortier [TR:V]
Clan: Ventrue
Group: 4
Capacity: 5
Discipline: aus dom for obf pre
Camarilla.
#20: Reverend Adams (ADV) [TR:V]
Clan: Ventrue
Group: 4
Capacity: 4
Discipline: aus PRE
Camarilla. During your master phase, you may look at the top X cards of your libary, where X is the number of Gehenna cards in play. Older vampires do not tap for successfully blocking Adams.
Clan: Brujah
Group: 4
Capacity: 2
Discipline: cel
Camarilla.
Cardtype: Vampire
Clan: Brujah
Group: 4
Capacity: 8
Artist: Leif Jones
Clan: Brujah
Group: 4
Capacity: 6
Clan: Caitiff
Group: any
Capacity: 1
Discipline: -
#05: Andy [TR:V]
Clan: Caitiff
Group: 4
Capacity: 1
Discipline: for
#06: Dirk [TR:V]
Clan: Caitiff
Group: 4
Capacity: 1
Discipline: pre
Clan: Gangrel
Group: 4
Capacity: 3
Discipline: for pro
Clan: Gangrel
Group: 4
Capacity: 5
#09: T.J. [TR:V]
Clan: Gangrel
Group: 4
Capacity: 3
Discipline: cel for
Clan: Malkavian
Group: 4
Capacity: 5
Camarilla.
Clan: Malkavian
Group: 4
Capacity: 4
Discipline: aus dem
#12: Toby [TR:V]
Clan: Nosferatu
Group: 4
Capacity: 5
#13: Topaz [TR:V]
Clan: Nosferatu
Group: 4
Capacity: 7
Clan: Toreador
Group: 4
Capacity: 5
#15: Lin Jun [TR:V]
Clan: Toreador
Group: 4
Capacity: 4
Clan: Tremere
Group: 4
Capacity: 7
Clan: Tremere
Group: 4
Capacity: 4
#18: Juniper [TR:V]
Clan: Ventrue
Group: 4
Capacity: 6
Clan: Ventrue
Group: 4
Capacity: 5
Camarilla.
Clan: Ventrue
Group: 4
Capacity: 4
Discipline: aus PRE
Ressurection, da li ima negde velika slika edicije, posto petokraka sa vampirima je stvarno funny thing...
No imam pitanje, hoce li mozda biti nekih bedzeva edicije, ili white wolf je to uradio samo za FRP...
pa verovatno ce biti kad izadje zvanicno. a bedzeva do sad nije bilo.
- Resurrection
Blade Clot
Action Modifier, Combat
Requires an anarch.
Only usable when this anarch diablerizes a vampire with a capacity
above 6. Put this card in play with three clot counters. When an
anarch you control inflicts hand or melee weapon damage, you may move
a clot counter from this card to the opposing minion. A minion with a
clot counter goes to torpor or is burned during his or her untap
phase. If an older vampire rescues the vampire, burn the clot counter.
Blood Turnip
Unique master. Requires a ready anarch.
Put this card on any minion. When this minion enters combat, he or she
moves this card and 1 blood (or life) to the opposing minion. If the
opposing minion is an anarch, that anarch can move this card onto any
minion instead (but it must move).
Chameleon
x blood
+1 stealth action. Requires a baron.
D - Take control of a younger vampire with capacity of X who entered
play since your last minion phase. That vampire becomes anarch (and
independent).
Club Illusion
1 pool
Master: unique location.
When any anarch vampire declares a bleed action, he or she can 1 blood
to get +1 bleed on that action (only usable once each action).
Constant Revolution
+1 stealth action. Requires an anarch. Unique.
Put this card in play with 1 counter. During your untap phase, put a
counter on this card. During each other Methuselah's untap phase, he
or she must burn X pool and/or cards at random from his or her hand,
where X is the number of counters on this card. Any vampire may burn
this card as a D-action that costs 1 pool.
Crypt's Sons
1 pool
Retainer
Unique mortal with 3 life. Requires an anarch.
Whenever this anarch is blocked, he or she may burn a life from the
Sons to cancel combat and continue this action as if unblocked. The
Sons inflict 1R damage each round of combat during normal strike
resolution.
Failsafe
Master: unique trifle
Put this card in play. If you have fewer than 3 pool, you may use a
master phase action to burn this card and gain 4 pool.
Final Loosening
Reaction
aus/dem/for
Requires an anarch.
aus: Play when an action vampire would gain 1 or more blood. The
action vampire and this reacting anarch each gain 1 blood instead.
dem: Gain 4 votes.
for: Only usable when an ally is acting. The action fails and the ally
takes 1 damage. Tap this reacting anarch.
The Framing
2 blood
D- Put this card on the acting anarch and choose a ready minion. If
the anarch with this card is blocked, this card is burned. The the
blocking minion enters combat with the chosen minion instead of this
anarch (or the action ends with no combat of that combat cannot
occur).
Garibaldi- Meucci Museum
Tap and burn 1 pool during your untap phase to exchange a card in your
ash heap that requires an anarch for a card from your hand. Tap before
range is determined to end combat between an anarch you control and
another anarch.
Grey Thorne
2 blood
Ally
Unique ghoul with 2 life. 1 strength, 1 bleed. Requires an anarch.
Grey may play cards that require Celerity or Potence as an anarch
vampire. During your untap phase, if grey has only 1 life, any ready
anarch may burn a blood to add 1 life to him.
Open War
Put this card in play. Anarch vampires can enter combat with any
minion as a D-action. They can burn a location as a D-action that
costs 2 pool. Any Methuselah may use a master phase action to move 1
counter from his or her pool to this card. When this card has 4 pool,
burn it an gain 4 pool. Only one Open War can be played in a game.
Patsy
Political Action
Requires a baron. Only usable if you control the Edge.
Choose a titled non-anarch vampire. Successful referendum means that
you burn the edge to remove that vampire's title and burn 2 pool from
his or her controller.
Piper
Master. Requires a ready anarch.
A ready untapped anarch you control employs or recruits a retainer or
ally from you hand (requiremenets can cost apply as normal). This is
not an action and cannot be blocked. Tap that anarch.
Poacher's Hunting Ground
Master. Location. Hunting Ground. Derivative.
During your untap phase, choose up to X ready anarchs you control who
each gain 1 blood, where X is the number of non-derivative hunting
grounds controlled by other Methuselahs. A vampire can gain blood from
only one hunting ground card each turn.
Shattering
chi/dem/pro
1 blood
Requires an anarch
chi: +1 stealth action. D - look at another Methuselah's hand and
discard a card from it.
dem: +2 stealth action. Burn an event (undirected, no matter who
controls the event).
pro: D - inflict 2 unpreventable damage on a ready minion.
Smear Campaign
1 pool
Unique Master. Requires a ready anarch.
Put this card in play. Tap during your untap phase and choose a tapped
non-anarch minion controlled by your predator or prey to burn a card
on that minion. Cannot be used to burn an equipment or a retainer.
That minion's controller then takes control of this card.
Stealing Years
+1 capacity.
D - Diablerize an older vampire in torpor and put this card on the
acting anarch. Capacity increases by 1. In the resulting blood hunt
referendum, each anarch gets an additional vote.
Twilight Camp
Master.
Put this card in play with 4 counters. When you put a non-titled, non-
anarch vampire in play from your uncontrolled region, you may burn a
counter from this card to make that vampire anarch (and independent).
You may burn a counter from this card to add a blood to an anarch as a
master phase action. Burn this card when it has no couters.
The World's a Canvas
Action
2 blood
dom/obf/vic
Reuires an anarch
dom: D - Burn half the counters in an uncontrolled minion in your
prey's uncontrolled region (round down).
obf: +1 stealth action. D - Burn a location.
vic: D - Burn 4 blood from a ready, titled, non-anarch vampire.
Requires an anarch.
Blood Turnip
Chameleon
x blood
independent).
Club Illusion
1 pool
Constant Revolution
Crypt's Sons
1 pool
Retainer
resolution.
Failsafe
Final Loosening
Reaction
aus/dem/for
Requires an anarch.
dem: Gain 4 votes.
The Framing
2 blood
occur).
another anarch.
Grey Thorne
2 blood
Ally
Open War
Patsy
Political Action
Piper
Shattering
chi/dem/pro
1 blood
Requires an anarch
Smear Campaign
1 pool
Stealing Years
+1 capacity.
Twilight Camp
Master.
Action
2 blood
dom/obf/vic
Reuires an anarch
- Resurrection
#01: Anarch Manifesto, An [TR:C]
Cardtype: Equipment
Equipment.
The anarch with this equipment gets +1 stealth on actions that require an anarch. Titled non-anarch vampires get +1 strength in combat with this minion. A minion may only have one Anarch Manifesto.
[DRAFT]: As above, and a vampire becomes Anarch when he or she equips with this card.
Artist: Heather Kreiter
#02: Anonymous Freight [TR:C]
Cardtype: Action
+3 stealth equip action. Requires a vampire.
Equip this vampire with a non-location equipment card from your hand (requirements and cost apply as normal).
[DRAFT]: As above, but ignore requirements of the equipment.
Artist: Brian LeBlanc
#03: Baseball Bat [TR:C]
Cardtype: Equipment
Cost: 1 pool
Melee weapon. Do not replace until the end of the action.
Strength+1 damage each strike. If the action to equip with Baseball Bat is successful, untap the acting minion at the end of the turn.
#04: Blade Clot [TR:R]
Cardtype: Action Modifier/Combat.
Requires an anarch.
Only usable when this anarch diablerizes a vampire with a capacity above 6. Put this card in play with three clot counters. When an anarch you control inflicts hand or melee weapon damage, you may move a clot counter from this card to the opposing minion. A minion with a clot counter goes to torpor or is burned during his or her untap phase. If an older vampire rescues the vampire, burn the clot counter.
#05: Blood Turnip [TR:R]
Cardtype: Master
Put this card on any minion. When this minion enters combat, he or she moves this card and 1 blood (or life) to the opposing minion. If the opposing minion is an anarch, that anarch can move this card onto any minion instead (but it must move).
Artist: Tom Biondillo
#06: Chameleon [TR:R]
Cardtype: Action
Cost: X blood
(D) Take control of a younger vampire with capacity of X who entered play since your last minion phase. That vampire becomes anarch (and independent).
Artist: Jim Parilec
#07: Club Illusion [TR:R]
Cardtype: Master
Cost: 1 pool
When any anarch vampire declares a bleed action, he or she can 1 blood to get +1 bleed on that action (only usable once each action).
#08: Constant Revolution [TR:R]
Cardtype: Action
Put this card in play with 1 counter. During your untap phase, put a counter on this card. During each other Methuselah's untap phase, he or she must burn X pool and/or cards at random from his or her hand, where X is the number of counters on this card. Any vampire may burn this card as a D-action that costs 1 pool.
#09: CrimethInc. [TR:C]
Cardtype: Action Modifier.
Disciplines: Protean/Quietus/Thaumathurgy
Requires an anarch. Play after resolving a successful action that requires an anarch or makes this vampire an anarch.
[pro]: Untap this anarch.
[qui]: Untap another ready anarch.
[tha]: Put this card in play. During your minion phase, you may burn a pool to untap a ready anarch you control.
Artist: John Bridges
#10: Crypt's Sons [TR:R]
Cardtype: Retainer
Cost: 1 pool
Whenever this anarch is blocked, he or she may burn a life from the Sons to cancel combat and continue this action as if unblocked. The Sons inflict 1R damage each round of combat during normal strike resolution.
#11: Detect Authority [TR:C]
Cardtype: Reaction
Disciplines: Animalism/Serperntis/Thaumaturgy
Requires an anarch.
[ani]: Only usable duringa a (D) action directed at this minion or location you control. The action ends (no cost is paid), unless the acting minion burns 2 blood immediately.
[ser]: +1 intercept.
[tha]: Reduce a bleed against you by 2.
Artist: Peter Bergting
#12: Elixir of Distillation [TR:C]
Cardtype: Equipment
Weapon. Requires an anarch.
Ranged strike: burn 1 blood from the opposing vampire and reduce his or capacity by 1 (capacity cannot be reduced below 1). That reduction last until that vampire's controller uses a master action to tap that vampire. Burn this weapon after use.
#13: Exclusion Principle [TR:C]
Cardtype: Political Action
Successful referendum means each methuselah gains 1 pool for each ready independent vampire he or she controls.
Artist: Eric Dechamps
#14: Failsafe [TR:R]
Cardtype: Master
Put this card in play. If you have fewer than 3 pool, you may use a master phase action to burn this card and gain 4 pool.
#15: Final Loosening [TR:R]
Cardtype: Reaction
Disciplines: Auspex/Dementation/Fortitude
Requires an anarch.
[aus]: Play when an action vampire would gain 1 or more blood. The action vampire and this reacting anarch each gain 1 blood instead.
[dem]: Gain 4 votes.
[for]: Only usable when an ally is acting. The action fails and the ally takes 1 damage. Tap this reacting anarch.
#16: Framing, The [TR:R]
Cardtype: Action
Cost: 2 blood
(D) Put this card on the acting anarch and choose a ready minion. If the anarch with this card is blocked, this card is burned. The blocking minion enters combat with the chosen minion instead of this anarch (or the action ends with no combat of that combat cannot occur).
#17: Garibaldi-Meucci Museum [TR:R]
Cardtype: Master
Tap and burn 1 pool during your untap phase to exchange a card in your ash heap that requires an anarch for a card from your hand. Tap before range is determined to end combat between an anarch you control and another anarch.
[DRAFT]: As above, and you may tap this card to make a vampire you control an anarch.
#18: Grey Thorne [TR:R]
Cardtype: Ally
Cost: 2 blood
Grey may play cards that require Celerity or Potence as an anarch vampire. During your untap phase, if grey has only 1 life, any ready anarch may burn a blood to add 1 life to him.
Artist: Matt Dixon
#19: Haven Hunting [TR:C]
Cardtype: Action
Put this card in play. At the end of a combat involving an anarch you control, if both combatants are still ready, you may burn this card to have the two combatants begin another combat.
[DRAFT]: (D) Enter combat with a ready minion.
Artist: Matt Dixon
#20: Hell-for-Leather [TR:C]
Cardtype: Combat
Discipline: Animalism/Celerity/Obtenebration
Requires an Anarch. Only one Hell-for-Leather may be played at a given Discipline each combat.
[ani]: Strike: dodge, with and additional strike.
[cel]: Additional strike (that doesn't count against the limit).
[obt]: Play if this anarch is ready and the opposing minion is not. The opposing minion's controller burns 2 pool.
#21: Keystone Kine [TR:C]
Cardtype: Action
Disciplines: Celerity/Necromancy/Obfuscate
Requires an anarch.
[cel] and/or [nec] and/or [obf] (D) Bleed. If using [cel], he or she gains one blood. If using [nec] the bleed is +1 bleed. If using [obf], you many burn an ally controleld by your prey whose cost is not greater than the bleed amount.
#22: Lam Into [TR:C]
Cardtype: Combat
Disciplines: Fortitude/Potence/Vicissitude
Requires an anarch. Do not replace until after combat. Strike: hand strike or use a melee weapon strike..
[for]: This strike is at +1 damage with an optional maneuver.
[pot]: This strike is at +2 damage.
[vic]: This strike is at +1 damage, with an optional press. If another round of combat occurs, range is automatically close.
#23: Libertas [TR:C]
Cardtype: Master
Cost: 1 pool.
Master.
Requires an anarch. Put this card on an anarch. Allies cannot block this anarch. Cards that require [dom] or
Cardtype: Equipment
Equipment.
Cardtype: Action
Cardtype: Equipment
Cost: 1 pool
Requires an anarch.
Cardtype: Master
Cardtype: Action
Cost: X blood
Artist: Jim Parilec
Cardtype: Master
Cost: 1 pool
Cardtype: Action
Cardtype: Retainer
Cost: 1 pool
Cardtype: Reaction
Requires an anarch.
Cardtype: Equipment
Cardtype: Master
Cardtype: Reaction
Requires an anarch.
Cardtype: Action
Cost: 2 blood
Cardtype: Master
Cardtype: Ally
Cost: 2 blood
Artist: Matt Dixon
Cardtype: Action
Artist: Matt Dixon
Cardtype: Combat
Cardtype: Action
Requires an anarch.
Cardtype: Combat
Cardtype: Master
Cost: 1 pool.
Master.
cost other minions an additional blood while this anarch is acting, attempting to block, or in combat. Artist: Andrew Trabbold #24: Monkey Wrench [TR:C] Cardtype: Action Modifier. Cost: X blood. Requires an anarch. +X bleed. X must be 1, 2 or 3. You cannot play another action modifier to increase this bleed amount. Artist: Brian LeBlanc #25: No Confidence [TR:C] Cardtype: Action Modifier Play after resolving a successful action that requires an anarch. Put this card on a titled non-anarch vampire controlled by the target of the action (or by your prey or predator if the action is undirected). A vampire with two No Confidence loses the benefit of his or her title. Burn this card if this acting vampire leaves the ready region. Artist: Brian LeBlanc #26: Open War [TR:R] Cardtype: Action +1 stealth action. Requires a baron. Put this card in play. Anarch vampires can enter combat with any minion as a (D) action. They can burn a location as a (D) action that costs 2 pool. Any Methuselah may use a master phase action to move 1 counter from his or her pool to this card. When this card has 4 pool, burn it and gain 4 pool. Only one Open War may be played in a game. Artist: John Bridges #27: Patsy [TR:R] Cardtype: Political Action Requires a baron. Only usable if you control the Edge. Choose a titled non-anarch vampire. Successful referendum means that you burn the edge to remove that vampire's title and burn 2 pool from his or her controller. [DRAFT]: Requires any vampire (and the Edge). Sucessful referendum means your prey burns 3 pool. Artist: Eric Dechamps #28: Piper [TR:R] Cardtype: Master Master. Requires a ready anarch. A ready untapped anarch you control employs or recruits a retainer or ally from your hand (requirements and cost apply as normal). This is not an action and cannot be blocked. Tap that anarch. Artist: Andrew Trabbold #29: Poacher's Hunting Ground [TR:R] Cardtype: Master Master. Location. Hunting Ground. Derivative. During your untap phase, choose up to X ready anarchs you control who each gain 1 blood, where X is the number of non-derivative hunting grounds controlled by other Methuselahs. A vampire can gain blood from only one hunting ground card each turn. Artist: Leif Jones #30: Power of All [TR:C] Cardtype: Reaction Cost: 2 blood. Requires a ready anarch. Tap this anarch and one other untapped ready anarch you control to cancel a library card as it is played. Usable even if there is no action. Not usable during your own turn. [Draft]: As above, but you do not tap another anarch. Artist: Eric Deschamps #31: Power of One [TR:C] Cardtype: Action Modifier Cost: 1 blood Disciplines: Obtenebration/Potence/Presence Requires an anarch. [obt]: Only usuable when an action is blocked. The blocking minion burns 2 blood or 2 life (before combat if any). [pot]: +1 bleed. [pre]: +1 bleed, or +1 bleed and +1 stealth. You cannot play another action modifier to increase this bleed amount. Artist: Jim Parilec #32: Revolutionary Council [TR:C] Cardtype: Political Action Requires a baron. Choose X, then choose X ready anarchs you control and allocate 2X points among one or more Methuselahs, locations and equipment. Successful referendum means each chosen anarch is tapped, each Methuselah burns one pool for each point assigned, and each location or equipment assigned a point is burned. Artist: Brian LeBlanc #33: Shattering [TR:R] Cardtype: Action Cost: 1 blood. Discipline: Chimerstry/Dementation/Protean Requires an Anarch. [chi]: +1 stealth action. Look at another Methuselah's hand and discard a card from it. [dem]: +2 stealth action. Burn an event (undirected, no matter who controls the event). [pro]: (D) Inflict 2 unpreventable damage on a ready minion. Artist: Becky Jollenstein #34: Shoulder Drop [TR:C] Cardtype: Combat Grapple. Play when you sucessfully inflict damage from a hand strike. After strike resolution, if this minion is still readym the opposing minion take 1 additional damage. The opposing minion cannot press this round. A minion play only one Shoulder Drop each strike. Artist: Efrem Palacios #35: Smear Campaign [TR:R] Cardtype: Master Cost: 1 pool Unique Master. Requires a ready anarch. Put this card in play. Tap during your untap phase and choose a tapped non-anarch minion controlled by your predator or prey to burn a card on that minion. Cannot be used to burn an equipment or a retainer. That minion's controller then takes control of this card. Artist: Leif Jones #36: Stealing Years [TR:R] Cardtype: Action +1 stealth action. Requires an anarch. (D) Diablerize an older vampire in torpor and put this card on the acting anarch. Capacity increases by 1. In the resulting blood hunt referendum, each anarch gets an additional vote. +1 capacity. Artist: Becky Jollenstein #37: Steely Tenacity [TR:C] Cardtype: Action/Combat Cost: 1 blood Disciplines: Animalism/Dominate/Quietus Requires an anarch. Do not replace until the end of this action. When you would replace this card, you make take this card from your ash heap instead. [ani]: Strike: hand strike or use a melee weapon strike. This strike is at +1 damage, with an optional press. [dom]: (D) Bleed at +1 bleed. [qui]: +1 stealth action. (D) Enter combat with a ready minion. Artist: Peter Bergting #38: Twilight Camp [TR:R] Cardtype: Master Master. Put this card in play with 4 counters. When you put a non-titled, non-anarch vampire in play from your uncontrolled region, you may burn counter a counter from this card to make that vampire anarch (and Independent). You may burn a counter from this card to add a blood to an anarch as a master phase action. Burn this card when it has no counters. Artist: Leif Jones #39: World's a Canvas, The [TR:R] Cardtype: Action Cost: 2 blood Disciplines: Dominate/Obfuscate/Vicissitude Reqires an anarch [dom]: (D) Burn half the counters in an uncontrolled minion in your prey's uncontrolled region (round down). [obf]: +1 stealth action. (D) Burn a location. [vic]: (D) Burn 4 blood from a ready, titled, non-anarch vampire. Artist: Brian LeBlanc #40: Zip Line [TR:C] Cardtype: Action +2 stealth action. Put this card on the acting minion. This minion may burn this card to get +1 stealth. Artist: Brian LeBlanc
- Resurrection
Sve karte: slike
http://dnn.vtes.net/Default.aspx?tabid=858
