Nema sta da se predpostavlja, jeste Lord of War, kao sto ce biti i brat kapetan Lisander i PapaSmurf Marneus Agustus Kalgar.
Psylencer ima force special rule? Da vidim da li dobro razumem puca str4 ap/ force, ako upalim force a neki karakter ili monster padne save = UMRE ?
I mogu da se bacaju psyk out grenades 8 inc, str2 ap /, blast 3 inca, PSY SHOCK ? ? ? LOL
RatGod wrote: I mogu da se bacaju psyk out grenades 8 inc, str2 ap /, blast 3 inca, PSY SHOCK ? ? ? LOL
To je ok....jedan model u unitu ima pravo da baci granatu, i range je obicno neki sitan.
Bitan detalj je da su sad samo Dreadnoughti psykeri...ne i ostala vozila. ;)
bone shard of solor:
the bearer gains a 3+ invulnerable save if he is within 12" of a model with the special rule daemon. this invulnerable save becomes a 2+ if a model with the special rule daemon of khorne is within 12". in addition the bearer also gains the hatred: khorne special rule.
Vec vidim GK sa malim Allied detachmentom Khorne-ovaca.. :lol:
RatGod wrote:Psylencer ima force special rule? Da vidim da li dobro razumem puca str4 ap/ force, ako upalim force a neki karakter ili monster padne save = UMRE ?
O da :)
U posedu sam knjige ako nekog nesto zanima nek pita :)
luka to malo gleda kao neko ko vodi screamerstar sa knjigom. I onda dodju knightovi koji se teleportuju ili deep strikeuju do njega i bace psygranate (svaki unit koji stigne, a moze da ih bude dosta). = skremer star je morao biti ubiven.
Izasao Officio Assassinorum dataslate....brutalni su.
Culexus je smrt svih psykera, ovo je samo odlomak:
Psychic Abomination: Psykers, friend or foe, within 12" of a Culexus Assassin have -3 Leadership, do not generate any Warp Charge (i.e. they do not add dice to their owning player’s Warp Charge Pool in the Psychic phase) and only harness Warp Charge points on a 6. A Culexus Assassin can never be targeted or affected by psychic powers – other units in the Culexus Assassin’s vicinity that are hit by beam or nova powers, or by Witchfire powers that use templates, are hit/ affected normally. Any blessing or malediction psychic powers affecting a unit immediately cease to be in effect if the unit moves within 12" of a Culexus Assassin or vice versa.
drekavac.... drekavac...
+++OBAVESTENJE+++
Svi koji koriste AB 3.2, od danas imate da skinete update za WH40k 7th Edition. (konacno :roll: )
:applause: :applause: :applause:
P.S. Ocekujte bagove. :D
Ove nedelje nesto sto niko nije ocekivao. Izlazi Space Hulk!
OOOOOOOOO!!!!!!!!!!!
Je l' će da bidne reprint onog zadnjeg sa Blood Angels-ima, ili će da ga updateuju na nešto drugo? DeathWing recimo?
Ne kaze mi u mailu koi su u nutra terminatori ali nije reprint, kaze new edition.
This week sees the release of a brand new edition of the iconic boxed game SPACE HULK.
•Contains everything you need to play 16 scenarios, including 4 totally new ones.
◦35 easy to assemble Citadel miniatures that do not require glue - 22 x Genestealers, 1 x Broodlord and 12 x Space Marine Terminators.
◦189 board sections and gaming counters, including the new boarding torpedoes, breach counters, a damaged control room and turbo-lift tile sections.
◦1 x Rulebook and 1 x Mission book.
75 funti
Ako ovo moze da se naruci preko vas ... ja to zelim :)
bogme po sastavu zvuci identicno kao postojeci space hulk... sem ovog jednog dodatka. Ne verujem da su remodeliralu svih 12 terminatora...
nego, ima li neko 75 funti na poklon? xD
na onim sajtovima sa rumorima pise da su isti termosi
$125USD or €100/£75
English only this time around. No translations
Limited Re-release from the 2009 edition but with
-4 new scenarios
-The box contains new counters (boarding torpedoes, breach counters, damaged control room and turbo lift tiles)Box
Contents
35 Easy fit models
22 Genestealers, 1 Broodlord and 12 Space Marine Terminators.
189 board sections and gaming counters.
1 x Rulebook and 1 x Mission book containing 16 scenarios including 4 new ones.
COVEN Supplement
From a 100% reliable source wishing to remain anonymous (confirmed by pics):
Power from pain - by turn number.
1 – nothing
2 – Fearless
3 – Fear, Fearless
4 – Fear, Fearless, it will not die
5 – Fear, It will not die, zealot
6+ - Eternal Warrior, fear, it will not die, zealot
This is a straight copy from the book - yes some of the powers are omitted on purpose as they are not listed in the chart every turn
Warlord chart
1 – talos & chronos reroll FNP rolls of 1 within 12”of warlord
2 – warlord plus any grotesques he joins gain it will not die
3 – add or subtract 1 from reserve rolls
4 – If your warlord is slain by an attack/weapon with AP 1 or 2 or with the ID rule, gain D3 VP
5 – Warlord plus wracks he joins gain FNP4+
6 – Warlord gains preferred enemy
Artifacts
10pts – pick one of the following at the start of your turn which lasts until your next turn – IWND, fleet, poisoned 4+, rampage (used each turn)
10pts – fighting in a challenge – opponent suffers -5 to initiative
25pts – 8”range, S1, AP2, assault 1, blast, instant death, no effect on vehicles (used as a grenade in shooting phase)
10pts – Additional D6 attacks at S3, AP- at initiative 10, grant an additional pile in move at this step, no bonus applicable for furious charge, rending etc
20pts – IWND 4+, only wounded by poisons special rule on 6
35pts - +1 to FNP rolls, negate first wound suffered if it has the ID rule but when this happens, the item is lost
Coven Detachment
Required – 2HQ, 2 Elite
Optional – 4HQ, 6 Elite, 4 Heavy Support
Units that are available in the detachment – Urien, Haemonculus, Raider (DT only), Venom (DT only), Wracks, grotesques, talos, chronos
Benefits – if this is the primary detachment you can reroll warlord chart from this book. All enemy units within 12”of 1 or more models from this detachment suffer -1LD
7(!!!) formations as well!
Definitivno izlazi I kosta ce 44 funte.
Bezveze, lici na igracku. Nadam se da bolje izgleda uzivo.
Petar
Post by Petar »
:twisted:
Jos slika:
http://instagram.com/karlmix
Here's the rules and stuff from the new WD, my FLGS got it early.
>Toxicrene 160-ish pts (Heavy Choice, unit composition: 1)
>WS BS S T W I A Ld Sv
> 3 3 5 6 5 3 6 8 4+
>Special rules
>Fearless, Instinctive behavior (feed), Poisoned 2+, Shrouded, Hypertoxic (6's to wound inflicted by poisoned weapons whether in combat and in shooting= instant death)
>Weapons/Biomorphs
>Acid Blood, Choking cloud, Lash whips, Toxic miasma
>Choking cloud
>Rng S AP Type
>12" 3 - Assault 1, Ignores cover, Large Blast, Poisoned 2+, Hypertoxic, Predatory sentience (Gets armorbane against open topped vehicles and vehicles that have already lost one or
more hull points)
> Maleceptor 205-ish points (Elites Choice, unit composition: 1)
> 3 3 6 6 5 3 3 10 4+
>Special rules
>Psyker (lv 2)
>Shadow in the warp
>Synapse Creature
>Weapons/Biomorphs
>Scything talos
>Powers
>Maleceptor always knows Psychic Overload and must generate the remainder of its powers from the Hive Mind chart
>Psychic Overload: Warp charge 2. Focused Witchfire. Range 24". Target must take a Ld test on 3d6 (Vehicles can be affected as well and count as having Ld 10 for the attack). If the test is failed the target takes d3 wounds no armor/cover saves allowed. Vehicles that fail take a glancing hit with no cover allowed. The psyker may attempt to manifest this power up to 3 times in each of its psychic phases. Each attempt must be resolved separately. However a single enemy unit cannot be the target of Psychic Overload more than once a psychic phase.
the mycetic spore is back! I sada moze da nosi i druge MCs a ne samo karnifekse! Bye Bye range depravity za exocrine, toxicrene, tyrranofexe...
Taman sam pomislio da Tiranidi ne mogu biti odvratniji... :roll:
Cekaj, ima jos plutajucih pipaka:
Znam, znam...ima i jos neki ako sam dobro video, zato i kazem.. :roll:
Hintovi na kraju White Dwarf-a:
*Psychic Horror
*A New Campaign Begins!
Zoantrope i Venomtrope su nestale iz prodavnice. Da li to znaci da se nadamo plasticnim Zoantropama\Venomtropama + jos necemu? :)
Ček', ček', zar ovo nisu oni "fancy" Genestealer-i :?: :?: :?:
:headdesk:
deko... zivis u prosloj ediciji. Samo su stavili tog kao fotku. ne postoje vise ygmarl kao zaseban unit.
Pa u kodex-u nema ni Plasma Hatcher-a, pa izlazi model konačno u ovoj kampanjskoj knjizi...
onda bi mogli i ygmarle da vrate xD mada je ta glava originalno bila za feeder tendrils biomorph, pa je tek posle bila za taj poseban unit (koji vise ne postoji u kodeksu), a sada je cisto dekorativna. kao i flesh hooks glava
btw, gde nadje tog hatchera? daj neki link ka tome? :)
edit: dok ja povezem da plasma hatcher nije neki novi facehugger-like tyranid vec mycetic spore... nema veze :P kao sto rekoh, "mogli bi da vrate" ali cisto sumnjam da ce to da urade, vec imas dovoljno fluffy genestealer varijanti u dataslateovima.
Dark Vengeance Reinforcements...
Sa GW sajta:
"You also get 6 x 25mm round bases, 1x100mm round base and 1x 40mm round base and enough pieces to build 6 Spore mines."
10 cm baza... sta bre?! koliko je to cudo?!
Ko tvoje dupe rekao bih.
Ouch.
