Uputstvo i mere predostroznosti su ispisane na "Engleskom" jeziku. Nisam imao baterije u aparatu da slikam, pa cu da prepisem bukvalno sve kako pise na kutiji. Ako vidite stamparske greske u daljem tekstu, najverovatnije nisu moje, nego tako pise. Isto tako, ako mislite da sam ispustio neki zarez ili tacku, nisam, tako pise
Elem da krenemo, strana na kojoj su mere predostroznosti:
Slicica sa okom precrtanim:
Carefully don't let the glue drop into the eye, if immodesty contact, can flush or seek the doctor to handle with water.
Slicica sa precrtanim decijom glavom:
Keep out of reach of children
Precrtane ruke:
The attention not lets the glue the contact the skins.
Sunce precrtano:
Deposit: Cool dry have no the sunlight to shoot the place, and use the empress namely cover tight.
Druga strana uputstvo za upotrebu:
Use: Can in a twinkling glue to match the every kind of metals rubber leather plastics timber porcelain and ceramics jade jewelry handicraft product car glass electric appliances spare parts etc. (nema gresaka u prekucavanju, jos jednom da pomenem)
Method of using: 1 use, will first two the water of coalescence things varnish rust the dust clearance is clean, and combine to beat to whet neat (mali razmak) fit together the position. Because of its have no to fill the characteristic of the crevice.
2. break the mouth of a bottle with pinprick, and lightly extrude a little amount glue even draw the cloth a the thing is superficial, fleetness with another a thing coalescence stick positive, bring pressure roughly 10 seconds, immediately glue to match.
3. if have to glue to connect not good, must afresh separate, and remove the gum layer, repetition above operation
Eto to je to, pa srecno u tumacenju (kazem jos jednom, mislim da sam sve bukvalno prepisao kako pise na kutiji)
P.S. Inace, lepak odlicno lepi, mnogo bolje od recimo bisona 8O
Super lepak (na engleskom)
Re: Super lepak (na engleskom)
Auuu, secam se osecaja kao da ce mi ruke izleteti iz caure (leptir, ne metak)joggy wrote:Precrtane ruke:
Ipak, ovo mi je najbolje 8)
A koji je lepak u pitanju?joggy wrote: Sunce precrtano:
ne pise made in china, ali pise neka mway tway fabrika (nemam sad kutijicu pored sebe). Znaci najverovatnije jeste kineska
