Brigantine - the choice of many pirate crews, able to mount 10 cannon and carry 100 crew
Evo i ja sam se iznenadio ali Turcin je bio upravu. Brigandin je stvarno postojao i bio jako koriscen.
Shta, nisi znao da su postojali brigantini??? 8O Lepo stho si okachio slichku, taman da se podsetim kako to izgleda (k'o klinac sam imao one knjige'od Peshaka do rakete' i gutao prosto sve o brodovima, ali se dosta toga zaboravilo...) 8)
Jes bas cu da pamtim svaku olpinu iz svake igre. Mene u piratesima nisu interesovale te sitne stvarcice. Secan se ovako sloop (jebiga moras da pocnes igru)>Merchantman>Cargo flyt> Frigate> Galleon > flota Galleona >Dosada (citaj legenda).....
Bas mi se igra nesto od tih igara.... Ima li neko Age of sail 2???????????????
HMS Victory, Nelson's flagship, was a three-decker ship of the line, a 104. The typical ship of the line of 1812 was a 74, with a deck of long 32-pounders, and two decks of carronades, plus chasers and other miscellaneous armament. USS Constitution was classed as a 44, with a broadside of 32 long 24-pounders, 20 32-pound carronades, and two long 24's as bow chasers, actually 56 guns. The more common frigate, such as HMS Shannon, was a 38, carrying long 18-pounders. Most ships of this period also had carronades; those with only carronades were at a disadvantage at long range and in good weather. Both the American and Royal navies made the mistake of too much reliance on carronades as primary armament. All these large ships were ship- or square-rigged on three masts. The masts were made up of three parts, a sturdy lower part well fixed in the hull, a topmast spliced to it, and a topgallant mast spliced to that. The upper parts of the masts were often torn off by gales or gunfire, and could be replaced from spares carried on the ship. Hundreds of men were required to man the sails and the guns; a crew of 300 was not unusual on a frigate.
