Heldorado
Heldorado
Na linku je prevod pravila na engleski.
http://www.duke.edu/~mt29/HellDorado/He ... ulesEN.pdf
novi link
http://www.helldorado.fr/ressources/tel ... ichier.pdf
obratite paznju: direktan link ka fajlu od 53MB
Re: Heldorado
Zekina banda wrote:Na linku je prevod pravila na engleski.
nije...
Jeste:
HELLDORADO ELLDORADO CORE RULES
Unofficial (and rough) translation by Mathieu Thérézien and Sébastien Longuet
Note: terms in French may be indicated between parenthesis for easier reference.
Basics
Dice
In Hell Dorado, you'll only use D6. Each player should have at least 5 dice. Some of the characteristics on the
fighters stat cards will correspond to the same number of D6 to roll.
Distance
When a miniature must be at a certain distance from another or from a particular point on the battlefield, it is
sufficient that any part of its base is at that distance. A fighter is within a zone if at least part of its base is. The
rules will specify whenever the whole base must be within a certain distance or zone.
Measuring
In Hell Dorado, players may measure any distance they wish at any time during the game...
Samo treba biti uporan nece bas iz prve (ponekad bas ni prvog dana :lol:
Jesu li figure metalne i u 35mm? I nisu pre-painted?
Prosle godine na Gen Conu je bila prica da ce figure biti pre-painted. Nemam pojma dali su ostali pri tome ili nisu.Nisam video ni jedan privju figure a da nije bila ofarbana (ili zelena WIP). S obzirom da je izasla na francuskom ocekujem uskoro vise informacija.
Zar figure nisu rezinske?!
Sivi poliuretanski rezin na osnovu preview-a... Sto znaci da mogu da se bacaju u nitro ako vam se ne svidi kako su ofarbane...
Jel moze neko, prvenestveno mislim na Zekinu bandu, da postavi linkove ka nekim stranama koje daju neke, bilo kakve, informacije o igri i figurama, na engleskom.
Sve na sta sam naletao je na francuskom, a ono sto je i bilo na engleskom je bilo jako shturo.
@Ko, jel` ja?
Pazljivije citaj forum :lol:
http://www.klubzmaj.org.yu/forum/viewtopic.php?t=4333
hvala velika :D
najnovija vest je da je Heldorado na Engleskom za sada "on hold", tj. hoce dobro da ga ispoliraju pre nego sto ga objave (ko zna, mozda su nesto naucili iz iskustva poznate francuske kompanije).
shukaku
Re: Heldorado
Post by shukaku »
Posto je Rick dobio ceo range za igru nedavno i danas sam pogledao i ipak se nalozio(na frakciju saracena) iako sam rekao da necu vise novih igara da kupujem i da se igram,zanima me da li ce se igrati ova igra da ipak ne kupujem bzvz. iako mi se figure bas dopadaju.
Mada mi je Rick nagovestio da ce on mozda da uzme demone,ipak me zanima,da li jos nekog interesuje pa da se igramo
Re: Heldorado
Pa moram da kazem, nakon sto sam i ja video demone danas... ozbiljno razmisljam. Bas me podsecaju na onaj stari confront stil. Ali, posto su pravila za sada jos uvek SAMO na francuskom, ipak bih sacekao da ih malo vidim na nekom "normalnom jeziku", pa da se odlucim
Zulufic
Har!Haaaar!Ya, matey!
Re: Heldorado
Post by Zulufic »
Sad cu vas sve zbuniti.... Meni su se svidele figurice Saracena i oni Mercenary!!! Mislim video sam one na kutiji, ne znam kakve su unutra. Beleive it or not, ako bi imao puno para skupljao bi te Saracene ako igra nije bas preterano "ozbiljna" ko war machine, jer juce su ljudi mogli slobono da stave stolove u Knez i da igraju paralelno sa onim tamo sahovskim turnirom. Previse mi je bila trans atmosvera....Ja bi ga igrao rekreativno. Ajde videcemo kad neko prevede pravila sa zabarskog...i ja postanem svestenik i bog mi podari neograniceni pristup paklu i tamo orobim Onazisa i Rokafelera...Pocecu da igram. Ako nista, pozajmice mi neko Saracene za par partija, bas me interesuje kako radi. E da i imaju golu sisatu cicu, respekt!!!
Re: Heldorado
Imaju Don Kihota...
Re: Heldorado
Za one koji bi pravila na eng nek pogledaju prvi post ovog topika
Re: Heldorado
Preleteo sam preko pravila, i cini mi se, da iga dosta nalikuje Confrontu, ali nekako sam stekao utisak da su nabacali puno statova i abilitija po jedinici...Ne znam, nekako mi igra, sa aspekta pravila, deluje konfuzno. A figurice su super (naravno, hriscani-inkvizitori).
Re: Heldorado
Meni taj link ne radi...
Ali kako da ne volis igru koja ima don kihota.
I naravno, zna se, Paklene legije za mene (zar je IKADA moglo drugacije, na ocaj moje devojke :-))
Re: Heldorado
Dule, proveri novi link radi 100%
shukaku
Re: Heldorado
Post by shukaku »
@Pendargon radi drugi link
Ja cu najverovatnije pokupiti saracene ovih dana starter i jos neku kutiju,i od mercenaries-a
onog jevreja sa golemom,bilo bi bas zanimljivo da on ide sa saracenima,sta cu mnogo mi se dopadaju fugure :D
Re: Heldorado
Da li je Rick poceo da prodaje packove i blistere posebno?
Poslednji put sam cuo da je prodavao sve sto ima za jednu armiju zajedno, tj. da recimo nisi mogao da kupis samo jedan blister.
Re: Heldorado
Igra, tehnicki gledano, nema blistere. Imas startere i manje kutije sa jedinicama. Te manje kutije ponekad lice na blistere u smisli da dobijes, otkud znam, dva Gluttony demona unutra. Al' to je to, igra se ne pakuje drugacije.
shukaku
Re: Heldorado
Post by shukaku »
Evo ja imam cene za neke nadam se da niko ne zamera ako ih objavim
Imas startere za svaku armiju koji su 3300 u proseku dobijes 10 figura
Pored toga postoje male kutije koje sadrze po dve figure ili jednog konjanika ali nisu blisteri,ali mozes ih smatrati kao takve,i oni su u proseku 1100,1200 a za konjanike od 1450 do 1750
shukaku
Re: Heldorado
Post by shukaku »
http://forums.ttgamers.com/forums/yaf_p ... ences.aspx
evo link na kome imaju razne stvari za heldorado na engleskom,izmedju ostalog armybuilder i karte saracena,lost i westernersa na engleskom 8)
Re: Heldorado
Sto je tako skupo?
Re: Heldorado
Zato sto se pravi u Evropi. Da se pravi u americi bilo bi skupo zato sto dolazi iz Amerike 8)
Re: Heldorado
Ma nije nego. Pre bih rekao da je skupo zato sto im se moze. :D :D
De su bre ti Kinezi? Nesto zabusavaju u poslednje vreme sa pravljenjem jeftinih kopija.
Re: Heldorado
Kako skupo? Pa svaka figurica je kvalitativno na nivou solo/HQ figure iz bilo koje druge igre. 1200 za dve takve, odnosno 600 po komadu meni izgleda sasvim normalno.
Re: Heldorado
Dawngreeter wrote:Kako skupo? Pa svaka figurica je kvalitativno na nivou solo/HQ figure iz bilo koje druge igre. 1200 za dve takve, odnosno 600 po komadu meni izgleda sasvim normalno.
pa... manje-vishe
Re: Heldorado
Bilo bi lepo da neko dokon, procita malo detaljnije pravila i kaze, valja li igra cemu....
Jos bolje, ako bi Rick bio voljan da napravi neku demonstraciju....
Zulufic
Re: Heldorado
Post by Zulufic »
Demonstracija je potvrdjena, bice uskoro ali datum nije potvrdjen. Agitujem da to bude sto pre i pocne prodaja i da ljudi pocnu igrati jer me jako interesuje kako izgleda...
shukaku
Re: Heldorado
Post by shukaku »
Daj stvarno da bude sto pre i da recimo taj dan bude neki popust za one sto bi kupili neku armiju :twisted:
Re: Heldorado
Mrzelo me da kacim fotke ofarbanih figura na photobucket pa sam napravio svoj blog. Eve linka
http://waxerspasttime.wordpress.com/
Re: Heldorado
dodao sam i opis pravila na blog (samo da vas upozorima, ima da se cita 8) )
Re: Heldorado
E, svaka ti cast. Nisam stigao sve da procitam sa posla, ali izgleda vrlo informativno.
Re: Heldorado
Dali su Saraceni spremni da se oprobaju protiv Vestenera? (ne moraju da budu ofarbani sto se mene tice.
shukaku
Re: Heldorado
Post by shukaku »
Jel se to odnosi na moje saracene?
Re: Heldorado
Aha, ne znam za druge. Čisto da probamo pravila.
Re: Heldorado
Bilo bi lepo da unapred najavite tu partiju, voleo bih da vidim kako se igra.
shukaku
Re: Heldorado
Post by shukaku »
Pa pola figura je sastavljeno i prajmovano,a pola nije,ali cu uzeti sad da ih sklopim
Problem je sto ja za vikend nisam slobodan,a sredinom sledece nedelje putujem tako da jedino mogu u ponedeljak,utorak i sredu ako ti odgovara neki od tih dana?
