Ko to moze znati...Luka wrote:Razlika je u tome sto se sa busterima dobija bolji card-pool za Sealed.
Conflux
Re: Conflux
Re: Conflux
Inkwell Leviathan 7uu
Artifact Creature - Leviathan (Rare)
Islandwalk, trample, shroud
"Into it's maw went the seventh sea, never to be seen again while the world remains." -Esper Fable
7/11
30/145
Kederekt Parasite (Creature - Horror) Rare (horror)
B
When any opponents draw a card, if you control a red permanent,
you may choose Kederekt Parasite to deal one damage to that player.
1/1
Rakka Mar (Legendary Creature – Human Shaman) Rare
2RR
Haste
R,Tap: Put a 3/1 red Elemental into play
2/2
Rotting Rats (Creature - Rat) Common
1B
When Rotting Rats comes into play, all players discard a card.
Unearth: 1B
1/1
Nije lose u reanimatoru, jos samo da reprintuju Zombify
Master Transmuter (Artifact Creature Human Artificer?) Rare
3U
U,Tap, Return a target artifact you control to your hand: put an artifact card from your hand into play.
1/2
Celestial Purge (Instant) Uncommon
1W
Remove target red or black permanent from game
Ovo mi se dopada, ubija Biterblosom
Mark of Asylum (Enchantment) Rare
1W
Prevent all non-combat damage to creatures you control this turn
Ovo mi se bas i ne dopada
Charnelhoard Wurm 4brg
Creature - Wurm (R)
Whenever ~ deals damage to an opponent, you may return target card from your graveyard to your hand.
6/6
Maelstrom Archangel wubrg
Creature - Angel (M)
Flying
Whenever ~ deals combat damage to a player, you may play a nonland card from your hand without paying its mana cost.
5/5
Ovaj udari i onda odigras Cruel ultimatum za dzabe. Nije lose.
Gwafa Hazid, Profiteer 1wu
Legendary Creature - Human Rogue (R)
wu,tap: Put a bribe counter on target creature you do not control. Its controller draws a card.
Creatures with bribe counters on them cannot attack or block.
2/2.
Ovo mi je dosta sumnjivo.
7/11
30/145
B
1/1
2RR
Haste
2/2
1B
Unearth: 1B
1/1
3U
1/2
1W
1W
Creature - Wurm (R)
6/6
Flying
5/5
2/2.
Re: Conflux
1W
odma u sajd u kitkine...
1W
MTGO: portugalovic
Re: Conflux
Zaboravio si da napises za ovo zadnje bice da zahteva wu i tap da bi uradio svoj los sbility, sto je sumnjivo, mislis da je toliko los?Maneater wrote:Inkwell Leviathan 7uu
7/11
30/145
B
1/1
Rakka Mar (Legendary Creature – Human Shaman) Mythic Rare
2RR
Haste
2/2
1B
Unearth: 1B
1/1
3U
1/2
1W
1W
Creature - Wurm (R)
6/6
Flying
5/5
Legendary Creature - Human Rogue (M/R)
2/2.
Cliffrunner Behemoth
3g
Creature - Rhino Behemoth Rare
Cliffrunner Behemoth has haste if you control a red permanent.
Cliffrunner Behemoth has lifelink if you control a white permanent.
5/3
lol, 2 potez wolly 3 ovaj, i smehotres u glavu za 10! Sick bice
"evo ga leopaR iz magle!!"
evo tebi zombie goliath iz goliatha!
http://www.badgerbadgerbadger.com/
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
Re: Conflux
Ako ti je do ubijanja Bitterblossoma za to ti je mnogo bolja karta Wispmare sto se kithkina tice. S tim izuzetkom ovu kartu bi ionako koristio kao removal za stvorenja a tu ti je Path to Exile neuporedivo bolja karta.Galovic wrote:Celestial Purge (Instant) Uncommon
1W
http://piv.pivpiv.dk/
Re: Conflux
Ali whispmare nije instant, ovo ti ostavlja manu za sledeci potez.
Whispmare je u sustini jedino i koristan protiv bittera, dok je ovo recimo korisno i protiv demigoda.
Re: Conflux
Bilo mi je sumnjivo jer tada jos nije bilo potvrdjeno, a i jeste lose. Rhino je dobar, ali ne znam koliko je primenljiv u constructedu. Tih 3 u bulji mu bas smeta.Chuck Norris wrote: Zaboravio si da napises za ovo zadnje bice da zahteva wu i tap da bi uradio svoj los sbility, sto je sumnjivo, mislis da je toliko los?
3g
5/3
Re: Conflux
1) Ako igras kithkine, aggro spil, ostavljanje mane za ovo je poklanjanje vremena protivniku. Imas makar 18 boljih playeva (10 stvorenja za jednu i 8 za dve mane), ne racunajuci spustanje hideaway zemlje, od cekanja sa dve otvorene mane dok protivnik spusti Bitterblossom.Roderick wrote:Ali whispmare nije instant, ovo ti ostavlja manu za sledeci potez.
2) I Path to Exile sklanja Demigoda van igre ali, za razliku od ove karte, Path to Exile ce uvek biti bolji izbor za maindeck u kithkinima.
Re: Conflux
Ma nece mu smetati videces, imaju da se igraju mimici kao ludi Jeste da neces cesto njih pumpati ali ce davati advantage ovim kartama iz confluxaManeater wrote:Bilo mi je sumnjivo jer tada jos nije bilo potvrdjeno, a i jeste lose. Rhino je dobar, ali ne znam koliko je primenljiv u constructedu. Tih 3 u bulji mu bas smeta.Chuck Norris wrote: Zaboravio si da napises za ovo zadnje bice da zahteva wu i tap da bi uradio svoj los sbility, sto je sumnjivo, mislis da je toliko los?
3g
5/3
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
Re: Conflux
Ne verujem da ce se igrati mimici, ali tu su figura, Ajani V., bice neki dobar Naya agro. Uklapa se dobro i u bloom\razor deck. Da u upravu si igrace se.
Re: Conflux
ne samo za blosum...Luka wrote:Ako ti je do ubijanja Bitterblossoma za to ti je mnogo bolja karta Wispmare sto se kithkina tice. S tim izuzetkom ovu kartu bi ionako koristio kao removal za stvorenja a tu ti je Path to Exile neuporedivo bolja karta.Galovic wrote:Celestial Purge (Instant) Uncommon
1W
karta za 2 mane sklanja permanent iz igre.... dakle, sajd pa ako neko igra rb .... idemo.....
MTGO: portugalovic
Re: Conflux
jebote sad mi sibul kaze da se igra ala con con na draftu....
ja to nisam ni upratio... jbt draft ima skroz da bude drugaciji...
MTGO: portugalovic
Re: Conflux
ali izgeda da sibul nije u pravu...
ovo pise za drugi dan roterdam
Day 2 and Top 8: Booster Draft (2 Shards of Alara boosters, 1 Conflux booster)
MTGO: portugalovic
Re: Conflux
nema Šibul pojmaGalovic wrote:ali izgeda da sibul nije u pravu...
Happy Devil on MODO
Bbajgo @ TWITTER
Re: Conflux
Da sam bio siguran u to postovao bih ovde ne bih ti slao na PM, ali svejedno hvala ti sto si me ispravio. Ovako je mnogo losije, gomila karata koje traze 5 boje nece moci da se igraju jer se karte za nalazenje zemalja, osim onih losih pseudofetcheva, nalaze upravo u Confluxu.Galovic wrote:ali izgeda da sibul nije u pravu...
Re: Conflux
True....Maneater wrote:gomila karata koje traze 5 boje nece moci da se igraju
Pa te petobojne karte su ti ionako sve u confluxu a i nema ih toliko mnogo tako da ti dodje na isto. Ovako je mnogo prirodnije, kao i ranije odredis shard i mozes normalno da nastavis da ga forsiras i kroz conflux s tim sto imas dodatnu opciju za prosirenje u 5 boja. Meni je mnogo veci haos bilo ono ludilo sa prebacivanjem iz SHM u EVE booster.
dd_fan on MTGO
Re: Conflux
Ti manji setovi(a ovo je najmanji do sada?) nisu pravljeni za draftovanje u vise od jednog primerka sto smo mogli videti kada smo igrai 3xEVE(i na online u beti kada sam gledao, prvi pik je bio flame jab zbog mimic imbalansa), i 3xMOR koji se na online dosta igrao zbog vrednih karti je bio bruka dosadan format.Galovic wrote:meni je bas bila dobra ideja.... i bilo bi loodo...
ovako opet isto
dd_fan on MTGO
Re: Conflux
dobro...to je zato što ga i ne prave da se igra sa više od jedan.....
bilo bi do jaja da tako naprave set da je fora da se sve promeni a da bude balansirano....
MTGO: portugalovic
Re: Conflux
Hahah meni je bas bilo zanimljivo kada sam imao 8 mimika ( 5/3 trample ) i udriii, samo da mi Curman nije sekao Snakeform-ove... Al svejedno sam ih polomio )
Re: Conflux
Oces da kazes da si pobedio turnir na kome je igrao curman? Ne znam Javore kako ovo da ti kazem...ali to je bio samo sanSerbZmaj wrote:Hahah meni je bas bilo zanimljivo kada sam imao 8 mimika ( 5/3 trample ) i udriii, samo da mi Curman nije sekao Snakeform-ove... Al svejedno sam ih polomio )
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
Re: Conflux
Aven Squire 1w
Creature-Bird Soldier c
Flying
Exalted
1/1
3/145
Jako dobro za limited.
Scattershot Archer g
Creature-Elf Archer c
T: Scattershot Archer deals 1 damage to each creature with flying.
1/2
90/145
O da, jos Biterblosom hatea.
Mirror-Sigil Sergeant - 5w
Creature-- Rhino Soldier (Mythic)
Trample
If you control a blue permanent, during your upkeep, put a token into play that's a copy of Mirror-Sigil Sergeant
4/4
Dobar u limitedu, ali stvarno mi nije jasno zasto je mythic. Mycoloth bi onda trebao da bude super mythic rare.
Flying
Exalted
1/1
3/145
1/2
90/145
Trample
4/4
Re: Conflux
Pa fora je u tome sto ako prezivi potez imas dva ova, a onda 4 samo od jedne karte, mislim ne kazem da ce se igrati, ali za razliku od mycolotha, a ne ubija tvoja bica i pravi 1/1, vec po sebi pravi stoke! Neprijatno je to sto moras imati plavi permanent.Maneater wrote:Aven Squire 1w
Flying
Exalted
1/1
3/145
1/2
90/145
Trample
4/4
U da ovaj glupi archer je bas problem za vile
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
Re: Conflux
Knight of the Reliquary
1gw
Creature - Human Knight Rare
Knight of the Reliquary gets +1/+1 for each land card in your graveyard.
{T}, Sacrifice a Forest or Plains: Search your library for a land card, put it into play, then shuffle your library.
2/2
Bas dobro bice
1gw
2/2
Bas dobro bice
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
Re: Conflux
Da bas mi se dopada. Da ima vigilance bio bi savrsen mada i ovako ima da kosta.
Re: Conflux
Sergeant ubacuje stoke geometrijskom progresijom a Mycoloth jedinicare samo aritmetickom a i ako ga vratis u ruku odlozio si pocetak kraja za jedan potez dok Mycolotha moze totalno da upropasti...Maneater wrote: Mirror-Sigil Sergeant - 5w
Trample
4/4
Gluttunous Slime
2g
Creature - Ooze u
Flash
Devour 1
2/2
jaako mi se svidja.....
dd_fan on MTGO
Re: Conflux
Hvala ti sto si mi objasnio neke stvari u zivotu. Naravno sarkastican sam ali ti to mozda neces primetiti.dd fan wrote:Sergeant ubacuje stoke geometrijskom progresijom a Mycoloth jedinicare samo aritmetickom a i ako ga vratis u ruku odlozio si pocetak kraja za jedan potez dok Mycolotha moze totalno da upropasti...Maneater wrote: Mirror-Sigil Sergeant - 5w
Trample
4/4
Gluttunous Slime
2g
Creature - Ooze u
Flash
Devour 1
2/2
To sto ti se ta slina svidja pokazuje da se samo u limeted i razumes, mada je i to sumnjivo.
Re: Conflux
Pa jasno da sam mislio na limited(najbolji format), nije kao da sam krenuo da pravim t2 deck oko njega a pored limiteda razumem se pomalo i u pravilaManeater wrote: To sto ti se ta slina svidja pokazuje da se samo u limeted i razumes, mada je i to sumnjivo.
dd_fan on MTGO
Re: Conflux
Ma razumete se vi u...,bez prozivki deco \:D/ pozz
Re: Conflux
Stiglo Confluks,jej.Pre relis 31.01,thg ako je neko zainteresovan 01.02.
Re: Conflux
A jel moze THG samo busteri conflux-a?
Re: Conflux
Knotvine Mystic
rgw
Creature - Elf Druid? Uncommon
1, {T}: Add {R}{G}{W} to your mana pool.
2/2
mana, mana, mana...
rgw
2/2
mana, mana, mana...
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
Re: Conflux
Iskreno se nadam da ce ako ne u 11. ediciji onda u sledecem bloku reprintovati dualce da bi ove divne trobojne i petobojne karte mogle da se igraju u T2 formatu.
Re: Conflux
Ja se nadam da ces ih reprintovati, uprkos ovim kartama!
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
Re: Conflux
Ja se nadam da tje da naprave blok o kome tjesh zapravo smeti sa ponosom da kazhesh da si ga igrao xD
So Damnation sucks where Wrath of God blows, but both of them rock
Aman wrote:Marvo citaj pravila, mrzi me da brisem vase male pogane postove...
kisici decacima
po guzici devojcicama
Re: Conflux
To ti je isto kao da gajis nadu da ces jednog dana pobediti Curmana u magicu i da ce scenario biti: on protiv tebe mulliganuje na 0 i pusta te da pobedis, jer mu polece avion za pro tour za sat vremena!
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
Re: Conflux
I konacno je izasla cela edicija, a podseca me na time spiral block, jer kao prva edicija bloka time spiral je bio dobar, a kao druga edicija, planar chaos nije, and welcome to planar chaos:
http://mtgsalvation.com/conflux-spoiler.html
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
Re: Conflux
CONFLUX JE ZIVO SRANJE!!!
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
