Alara Reborn
Alara Reborn
Prerealese karta
Broodmother Dragon 2rrrg
Creature - Dragon (M)
Flying
At the beginning of each upkeep, put a 1/1 red and green Dragon token with flying and devour 2 into play.
4/4
Jean-Sebastien Rossbach, *53/145
Release karta
Knight of New Alara 2wg
Creature - Human and Knight (R)
Each other multicolored creature you control gain +1/+1 for each of its color.
2/2
David Palumbo, *70/145
http://forums.mtgsalvation.com/attachme ... 1237810747
Flying
4/4
Release karta
2/2
Re: Alara Reborn
Broodmother Dragon?
Jako mastoviti ovi dizajneri iz magica...
E ovaj knight je vec imba. Ja ne znam za vas al vec vidim Doranov comeback
Re: Alara Reborn
True.Roderick wrote:E ovaj knight je vec imba. Ja ne znam za vas al vec vidim Doranov comeback
Ovo bi tako lepo leglo umesto Rafiqa u doran-bant dek...
Re: Alara Reborn
šibulov pre-relase spam počinje!!Maneater wrote:Prerealese karta
Flying
4/4
Release karta
2/2
Happy Devil on MODO
Bbajgo @ TWITTER
- Deicidemilan
Re: Alara Reborn
Bas je premocna slika ovog behemotha naci ono bas je velik oni sages esperovi su jako sitni naspram njega
"evo ga leopaR iz magle!!"
evo tebi zombie goliath iz goliatha!
http://www.badgerbadgerbadger.com/
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
Re: Alara Reborn
Aven Mimic 1WU
Creature - bird wizard (R)
Flying
At the beginning of your upkeep,put a Wing counter on target creature, Creatures with wing counters are 3/1 and have flying
3/1
Exsanguination 2BR
sorcery (R)
Name a nonland card, target player reveals his hand, Though Bleeding deals 3 damage to him or her for each card with that name, and the search the player's library, hand and graveyard for all cards with that name and remove them from the game.
Sage of the Anima 3UG
Creature - Elf Wizard (R)
If you draw a card, instead reveal the top 3 cards of your library, put all creature cards revealed this way in your hand and all other cards on the bottom of your library.
3/4
Ether-caste Knight WU
Artifact Creature - Human Knight (C)
Exalted
1/3
Tar Shards 3BR
Instant (U)
Double Cast (When you play this spell, remove cards from the top of your library from the game until you reveal a nonland card with converted mana cost less than this card, you may play this card without paying its mana cost, then put the other cards removed from the game on the bottom of your library in any order)
Tar Shards deals 4 damage to target creature.
Pale Priest-Spider(?)4GW
Creature - Spider (C)
Reach
Forest Cycling (2)
Plains Cycling (2)
4/5
Marici Twinclaw 2(R/W)G
Creature - Cat warrior (U)
Double strike
2/4
Flying
3/1
Exsanguination 2BR
sorcery (R)
3/4
Exalted
1/3
Tar Shards 3BR
Instant (U)
Reach
Forest Cycling (2)
Plains Cycling (2)
4/5
Double strike
2/4
- Al je kul ovaj Cepa
Re: Alara Reborn
ako se ne varam
jachi cranial i za 2 mane 2/4 doube strike?? o.O
Re: Alara Reborn
2(R/W)G cudno da su vratili hibridnu manu....Al je kul ovaj Cepa wrote:ako se ne varam
dd_fan on MTGO
Re: Alara Reborn
O da konacno se reprintovao terminate, kako dobra karta!!!
Jund Muckcutter*
{bg}r
Creature - Goblin Beserker Common
As long you control another multicolored permanent, Jund Muckcutter gains +1/+1 and haste.
neki zoo aggro 1 drop tattermunge, figura, mozda slina?
Jund Muckcutter*
{bg}r
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
Re: Alara Reborn
Jel ima neko link koji govori da ce se na draftu igrati shards-conflux-reborn?
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
Re: Alara Reborn
kako drugačije?Chuck Norris wrote:Jel ima neko link koji govori da ce se na draftu igrati shards-conflux-reborn?
Happy Devil on MODO
Bbajgo @ TWITTER
Re: Alara Reborn
pa do sad je bilo po dve edicije eto tako drugacije, a trazio sam link sam objasnjenjem ako neko imaBB wrote:kako drugačije?Chuck Norris wrote:Jel ima neko link koji govori da ce se na draftu igrati shards-conflux-reborn?
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
Re: Alara Reborn
Ako mislis na LLM i SSE, sada su opet vratili na staro sa po 3 edicije u bloku. To sa 2 (polu)bloka po 2 edicije su prosle godine uradili jer im je falila 4. edicija koliko im je godisnji standard. 2007. 4. edicija je bila core set, godinu dana pre toga Coldsnap. A od ove godine core setovi krecu godisnjim tempom tako da vracaju blok na 3 edicije + core set = 4 edicije svake godine.Chuck Norris wrote: pa do sad je bilo po dve edicije eto tako drugacije, a trazio sam link sam objasnjenjem ako neko ima
dd_fan on MTGO
Re: Alara Reborn
vidi se da si dankooov aprentisdd fan wrote:Ako mislis na LLM i SSE, sada su opet vratili na staro sa po 3 edicije u bloku. To sa 2 (polu)bloka po 2 edicije su prosle godine uradili jer im je falila 4. edicija koliko im je godisnji standard. 2007. 4. edicija je bila core set, godinu dana pre toga Coldsnap. A od ove godine core setovi krecu godisnjim tempom tako da vracaju blok na 3 edicije + core set = 4 edicije svake godine.Chuck Norris wrote: pa do sad je bilo po dve edicije eto tako drugacije, a trazio sam link sam objasnjenjem ako neko ima
Happy Devil on MODO
Bbajgo @ TWITTER
Re: Alara Reborn
tako je i bolje, hvala na objasnjenjudd fan wrote:Ako mislis na LLM i SSE, sada su opet vratili na staro sa po 3 edicije u bloku. To sa 2 (polu)bloka po 2 edicije su prosle godine uradili jer im je falila 4. edicija koliko im je godisnji standard. 2007. 4. edicija je bila core set, godinu dana pre toga Coldsnap. A od ove godine core setovi krecu godisnjim tempom tako da vracaju blok na 3 edicije + core set = 4 edicije svake godine.Chuck Norris wrote: pa do sad je bilo po dve edicije eto tako drugacije, a trazio sam link sam objasnjenjem ako neko ima
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
Re: Alara Reborn
Nemesis of Reason 3UB
Creature - Horror Leviathan R
Whenever Nemesis of Reason attacks, defending player puts the top 10 cards of his or her library into his or her graveyard.
3/7
Spellbound Dragon* 3UR
Creature - Dragon R
Flying.
Whenever Spellbound Dragon attacks, draw a card, then discard a card. Spellbound Dragon gets +X/+0 until end of turn, where X is the converted mana cost of the discarded card.
3/5
Unscythe, Killer of Kings* UBBR
Legendary Artifact - Equipment R
Equipped creature gets +3/+3 and first strike.
Whenever a creature dealt damage by the equipped creature is put into a graveyard, you may remove it from the game. If you do, put a 2/2 black zombie creature token into play.
Equip 2
3/7
Creature - Dragon R
Flying.
3/5
Equip 2
Re: Alara Reborn
Izasao je visual spoiler: http://www.wizards.com/magic/tcg/articl ... rn/spoiler
Ova edicija ce izgleda biti igrivija od zadnje dve a ilustracije su boli glava.
Re: Alara Reborn
Nadam se da ce pederi iz wizardsa napraviti neke korisne zemlje u ovom setu
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
Re: Alara Reborn
Mislio sam na alara rebornkosta105 wrote:A sta fali Ancient Ziggurat-u?
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
Re: Alara Reborn
Izgleda da reprintuju i Meddling Mage-a.
btw nformacije o novoj ediciji cure mnogo sporije nego ranije, 10 dana ima do izlaska a samo je 1/7 karata spojlovana i to uglavnom samo one koje su sami wizardsi pokazali...
dd_fan on MTGO
Re: Alara Reborn
To je zato sto kruzi prica da su wizardsi promenili playtestere. Totalno neprovereno, mrzi me da kucam, pricao sam u jednoj od geek online igara sa likom koji tvrdi da je to radio do pre godinu dana. Kad budem imao vremena napisacu sta mi je sve napricao.dd fan wrote:Izgleda da reprintuju i Meddling Mage-a.
Re: Alara Reborn
m mage je sexy, to bi bilo ql da odstampaju
Fiki: nisi gledao
Fiki: guide to strap-on sex?
Fiki: jako je dobro
Fiki: jako je dobro
Re: Alara Reborn
yup povrđeno .... M.Mage opet u T2 :-)
na MtgSalvationu su stavili u spoiler
Re: Alara Reborn
Oce neko da qupi 4 komada? 8)
Re: Alara Reborn
Krle wrote:Oce neko da qupi 4 komada? 8)
ti treba da čuvaš te karte i da se baviš MTGom
Happy Devil on MODO
Bbajgo @ TWITTER
Re: Alara Reborn
Ocu ja...Krle wrote:Oce neko da qupi 4 komada? 8)
Al samo ako cena nije preko 3 miliona dinara!!!
to be or not to be.....that is a question...now
Re: Alara Reborn
mislim da ovo tebi nije prob...gile wrote:Ocu ja...Krle wrote:Oce neko da qupi 4 komada? 8)
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
Re: Alara Reborn
Ne,mislim da si me pomesao sa nekim drugim tipa galovic ili tako neko:D
Re: Alara Reborn
za sada se rariteti karata zute i crvene
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
Re: Alara Reborn
neee slika m mage je grozna, zasto jednostavno nisu odstampali staru koja je preterana... chobani
Fiki: nisi gledao
Fiki: jako je dobro
Fiki: jako je dobro
Re: Alara Reborn
mada mozda je slika lazna, jer ipak m mage je invitainal karta a na slici je zhena
Fiki: nisi gledao
Fiki: jako je dobro
Fiki: jako je dobro
Re: Alara Reborn
haha lici na tvog avatara
Qasali Pridemage
gw
Creature - Cat Wizard Common
Exalted
1, Sacrifice Qasali Pridemage: Destroy target artifact or enchantment.
Illus. Chris Rahn #75/145 2/2
bas extra bice kao common
Lord of Extinction
3bg
Creature - Elemental Mythic Rare
Lord of Extinction's power and toughness are each equal to the number of cards in all graveyards.
Illus. Izzy #91/145 */*
neki suludi dredge? doduse nema trample
Maelstrom Pulse
1bg
Sorcery Rare
Destroy target nonland permanent and each permanent that shares a name with that permanent.
Illus. Anthony Francisco #92/145
konacno neka vrsta vindicata
i da za sada ima 10 commona i par uncommona, lol 2 rare po boosteru?
Qasali Pridemage
gw
Exalted
Lord of Extinction
3bg
Maelstrom Pulse
1bg
Sorcery Rare
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
Re: Alara Reborn
Double Cancel*
uur
Instant Uncommon
Counter up to two target spells.
jesus, jebalui ih canceli
inace po meni je ova edicija bas onaj blok koji je nedostajao shardsima jer je overwhelmed by bombs i naravno da se sto pre zaboravi na conflux(iako ce se igrati na draftovima, uzas...) koji je u rangu losine coldsnapa
uur
Instant Uncommon
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
Re: Alara Reborn
http://mtgsalvation.com/alara-reborn-spoiler.html
izasao je ceo spoiler
Knotvine Paladin
gw
Creature - Human Knight Rare
Whenever Knotvine Paladin attacks, it gets +1/+1 for each untapped creature you control.
#71/145 2/2
koja bolest za exalted deck
Mayael's Aria
rgw
Enchantment Rare
At the beginning of your upkeep, put a +1/+1 counter on each creature you control if you control a creature with power 5 or greater. Then you gain 10 life if you control a creature with power 10 or greater. Then you win the game if you control a creature with power 20 or greater.
Some songs soothe the savage beast.
Mayael's song emboldens them.
lol
Knotvine Paladin
gw
#71/145 2/2
Mayael's Aria
rgw
Enchantment Rare
lol
BURNMILL!!
Dusan Trump Galovic
BURNMILL!!
Dusan Trump Galovic
