Privateer Press nabavka
Moderators: stalker, lord warrior
Re: Privateer Press nabavka
Za desetak dana porucujemo pa pisite ako vas jos nesto interesuje sa firestorma.
Hvala.
Hvala.
- TheSerbianRaven
PIP32064 Protectorate of Menoth Vassal Mechanik
PIP32069 Protectorate of Menoth High Reclaimer
PIP35052 Retribution Epic UA Eiryss Mage Hunter Commander
Po kojoj ceni i do kada treba dostaviti pare?
Hordes 4 inch Area Effect Ring Markers (3), PIP91087
Blighted Nyss Hex Hunters, PIP73049
Bayal, Hound of Everblight, PIP73050
Trench Buster, Cygnar Solo PIP31110
Captain Jonas Murdoch PIP31079
Arcane Tempest Rifleman – Cygnar Solo PIP31127
Cygnar Major Katherine Laddermore PIP31055
Convergence Light Vector Corollary PIP36013
Convergence Optiflex Directive (3) PIP36007
Convergence of Cyriss Attunement Servitors (3) PIP36015
Convergence Solo Accretion Servitors (3) PIP36008
Convergence Heavy Vector Assimilator/Conservator/Modulator PIP36014
Convergence of Cyriss Diffuser PIP36005
Convergence Warcaster Divinity Architect Father Lucant PIP36019
![Image](http://www.mandmdesign.it/images/BannerMKII_cygnar_caine.png)
PIP75028 MINION WARLOCK DR. ARKADIUS
PIP75034 MINIONS HEAVY WARBEAST ROAD HOG
PIP75036 MINION CHARACTER SOLO TARG
PIP75072 MINION SPLATTER BOAR (PLASTIC)
PIP75071 MINION BATTLE BOAR (PLASTIC)
PIP75042 MINION RAZOR BOARS WARBEASTS
PIP75050 MINION WARLOCK HELGA THE CONQUERER
isto pitanje, po kojoj ceni i kada pare da se dostave?
Shvatio sam i prvi put, nisam te zaboravio.STOKA wrote:Trench Buster, Cygnar Solo PIP31110
- TheSerbianRaven
Jos i ovo:
PIP74045 Skorne Dominar Rasheth
PIP74006 Skorne Basilisk Krea
PIP74029 Skorne Agonizer
i ovo :D
PIP91073 Convergence of Cyriss Token Set MK II
PIP91051 Token Set Mk II Cygnar
AP-TL5016 Laser Line - TARGETLOCK
Product Code: PIP74078 Skorne Praetorian Keltarii/Swordsmen (10) PLASTIC
Product Code: PIP74028 Skorne Immortals (2) - blister!!!
![Image](http://i35.photobucket.com/albums/d177/Pendargon/Magnus.gif)
![Image](http://i35.photobucket.com/albums/d177/Pendargon/disc_dominate.gif)
![Image](http://i35.photobucket.com/albums/d177/Pendargon/disc_potence_s.gif)
![Image](http://i35.photobucket.com/albums/d177/Pendargon/disc_celerity_s.gif)
![Image](http://i35.photobucket.com/albums/d177/Pendargon/obf.gif)
![Image](http://i35.photobucket.com/albums/d177/Pendargon/disc_quietus_s.gif)
Hordes Trollbloods:
1x Dire Troll Blitzer (Metal preferred), ako nema, onda Dire Troll Heavy Kit
Warmachine Retribution
1x Heavy kit Banshee, Sphinx, Daemon
1x Hypnos upgrade
Guildball
Brewers starter kit
Brewers - Scum
Brewers - Spigot
Brewers - Stave
Brewers - Mash
Brewers - Esters
Brewers - Stoker
Union - Veteran Rage
1x Hypnos upgrade
Guildball
Brewers starter kit
Brewers - Scum
Brewers - Spigot
Brewers - Stave
Brewers - Mash
Brewers - Esters
Brewers - Stoker
Figure su narucene(nisu poskupele
) I stici ce do 7.08.
Molio bih Vas da mi novce dostavite do tog datuma ako nije problem. Mozete je podici u klubu od 09.08.
Ja putujem na more 09.08. tako da samo dodjete do kluba I pokupite vase figure, sve ce biti pripremljeno.
Hvala unapred
Hvala unapred
Stigla je porudzbina. Možete je preuzeti u klubu.
Drugari napravili bi jednu Warma/Hordes porudzbinu u narednih 15ak dana.
Pisite ako vas nesto interesuje.
Hvala unapred.
Hvala unapred.
- TheSerbianRaven
PIP74095 Skorne Battlegroup Mk III
PIP74020 Skorne Tyrant Xeris
PIP74005 Skorne Basilisk Drake
PIP41050 Mercenary Captain Bartolo Montador
Last edited by TheSerbianRaven on Thu Oct 06, 2016 10:24 am, edited 1 time in total.
Everblight Hellmouth, PIP Code: 73099
Gorax, PIP: 72078
Grayle the Farstrider, PIP: 72058
Dzon Vejn wrote:
This advanced bot stole my avatar!
![Image](http://i.imgur.com/6sQLouc.gif)
- TheSerbianRaven
PIP31127 Arcane Tempest Rifleman – Cygnar Solo
Morvahna the Dawnshadow, PIP Code: 72069
Gnarlhorn satyr, PIP Code: 72077
Ja se lomim od jutros, ali cu ipak da budem pametan i sacekam erratu sa daljim kupovinama.
Ako može, poništio bih ovu narudžbinu I umesto toga poručio:Đura_Samurajac wrote:Gorax, PIP: 72078
Circle Orboros Battlegroup Starter box
PIP code: 72094
Moze.Đura_Samurajac wrote:Ako može, poništio bih ovu narudžbinu I umesto toga poručio:Đura_Samurajac wrote:Gorax, PIP: 72078
PIP code: 72094
Dodao bih:ZergLord wrote:Everblight Hellmouth, PIP Code: 73099
Nephilim Bloodseer, PIP Code: 73089
- Resurrection
- TheSerbianRaven
Ako nije kasno dodao bih jos:
PIP74058 Skorne Warlock Master Ascetic Naaresh
PIP74061 Skorne Tiberion Upgrade Kit
Engineer Starter Set (Ballista, Salvo, Velocity); Product Code: SFGBENG01-001
Hoist ;Product Code: SFGBENG02-004
Mainspring; Product Code: SFGBENG01-003
Ratchet; SFGBENG01-005
Drugari porudzbina je zakljuceni I otisla je danas.
Stize oko 10 novembra.
Drugari stigle su figure. Možete ih preuzeti u klubu od utorka.
Dva pitanja, kada je sledeca porudzbina i da li moze da se naruce paint setovi?
Verovatno u januaru. Naravno da mogu.
Drugari pravimo ponovo narudzbinu sa Firestorma. Za nekih 2 nedelje. Pisite vase zelje i pozdrave.
Hvala unapred.
Hvala unapred.
http://www.firestormgames.co.uk/circle- ... tem-bearer
http://www.firestormgames.co.uk/circle- ... pgrade-kit (mozda nema u stocku)
http://www.firestormgames.co.uk/bloodweaver-night-witch
MODEL COLOUR SET - BLACK & WHITE, Product Code: VAL70151
MODEL COLOR SET - WOOD AND LEATHER, Product Code: VAL70182 --mozda nema na stanju(kako moze da se proveri da li imaju?)
GAME COLOR SET - NON METALLIC METAL, Product Code: VAL72212
GAME COLOR SET - SPECIAL EFFECTS SET, Product Code: VAL72213
WARPAINT - BARBARIAN FLESH, Product Code: AP-WP1126
WARPAINT - DESERT YELLOW, Product Code: AP-WP1121
WARPAINT - FUR BROWN, Product Code: AP-WP1122
WARPAINT - LAVA ORANGE, Product Code: AP-WP1106
WARPAINT - NECROTIC FLESH, Product Code: AP-WP1108
WARPAINT - ALIEN PURPLE, Product Code: AP-WP1128
WARPAINT - QS DARK TONE INK, Product Code: AP-WP1136
Po onoj donjoj ceni je ovo ~~100e kada gledam da je funt 160 din... Da li ce me to onda izaci 100e ili ima jos neki trosak?
Nemas jos neki trosak i mislim da ce biti niza funta.sharpshooter wrote: ↑Tue Feb 21, 2017 12:51 pm MODEL COLOUR SET - BLACK & WHITE, Product Code: VAL70151
Seksi... Narucujem onda ovo.Mrzimsvee wrote: ↑Tue Feb 21, 2017 3:04 pmNemas jos neki trosak i mislim da ce biti niza funta.sharpshooter wrote: ↑Tue Feb 21, 2017 12:51 pm MODEL COLOUR SET - BLACK & WHITE, Product Code: VAL70151
Shadowhorn Satyr, PIP:72077
- TheSerbianRaven
http://www.firestormgames.co.uk/protect ... ar-officer
http://www.firestormgames.co.uk/menoth-blood-of-martyrs
- TheSerbianRaven
http://www.firestormgames.co.uk/skorne-tyrant-xeris
http://www.firestormgames.co.uk/skorne- ... ard-bearer
http://www.firestormgames.co.uk/cryx-ba ... ard-bearer
Last edited by TheSerbianRaven on Mon Mar 06, 2017 1:40 pm, edited 1 time in total.
