Confrontation 3.5!!!
http://www.rackham.fr/pdf_EN/CONFRONTAT ... web_VU.pdf
Alahanski konjanici vise nisu tolike baje, ali cinavoli, magovi, popovi i strelci postaju baje!
Evo i dopune:
Q. Is the imaginary line traced after the AIM test?
Or must it be declared before of test?
Before.
Q. How would experimental fusil of sharpshooters goblins work now?
When is dice rolled to determine modifier to range? Before or after of determining point and imaginary line?
Before.
Q. Does the shooter need line of sight on the chosen point? And on every model below the imaginary line?
Nope.
Q. This is important: “whose base” or “whose figure”.
Base.
Is not there an AIM test by target in line? Only is necessary one AIM test? i.e. projectile impacts all fighter or none…
Ony one AIM test.
Modifiers as large size, different height levels, moving, dodging… do they affect the AIM test difficult?
Altitude level does : you choose only one level that is going to be affected.
The rest doesn't.
Can an artillery shooter fire on friends models? i.e. can the imaginary line be traced on friends models?
Yes.
If the imaginary line crossed on a model in melee, does the shot impact that model or must a dice be rolled to determine what model is impacted?
No roll.
How Sceptre of atrocity work now?
Does it allow acquiring infinite spells to The Gorgon?
Yes.
Do Aspects of Faith modified by Liturgy Relics allow acquiring additional miracles?
Yes.
Do character marksmen with artillery gain these abilities?
They get assault fire as per C3 rules. They don't get bull's eye.
Can a character combine bull’s eye and quick recharge?
He can shoot once using Bull's eye and then once normally.
Then, if a fierce fighter is killed outright during activation phase, it’s retired before combat phase. Am I right?
You are so right
Are successful defences whose final result is not two points higher than final result of attack considered valid defences to avoid the attack?
They are.
What is a valid part of body?
a hand? an arm?
a foot? a knee? a leg?
Picture your miniature naked, ready to take its shower. Everything he still has then is a body part (this includes prosthesis).
Can lines of sight be traced crossing between legs of a model to see another model behind (for example, seeing a foot of a wolfen between legs of other wolfen)?
Yes, if the shooter can see its target between said legs without bowing.
Caps (Cyanhur) and banners aren’t valid parts, but they block line of sight, aren’t they?
Yes, they do block line of sight.
Najvise polemike izazivaju nova pravila za line of site i besplatne magije i cuda. Mozda bi tu trebalo ugalviti neka kucna pravila:
1. Line of site kao sto je bio
2. Magije i cuda za prizivanje se palcaju
Pa nije lose , svidja mi se ovo za fierce........ :twisted:
igra se naglo i neverovatno pogorsala... Vracamo se na koncept c2/ shooty-spelly-faithy stvari, pri cemu je hand-to-hand renderovan nebitnim. Narocito mi je neverovatno i ekstremno glupo ono o besplatnom uzimanju spelova i magija.
Vec vidim kombo za turnir :
Ardokath+invocation of N'agoth + ira tenebrae summoning+song of cornu... sve za 90 pts... hahahahha....ne....
Ipak, oslabili su fierce (sto je trebalo), artiljeriju (sto je trebalo), charging str (sto je trebalo) i malkice su ojacali normalne warriore zbog sequence...
Jako sam tuzan zbog ovoga
jorgurt hlebozvak
Gorgona
Post by jorgurt hlebozvak »
Super. Sad ću da uzmem Gorgonu i da joj platim samo Spectre of Atrocities koji joj omogućava da uzima magije i preko duplog Pow. Pa te magije neću da plaćam. Platiću i artefakt koji je koristio Minja da na 1 ne padam incatation test. Pa ću joj dodeliti jedno 10 magija. Za dzabe. Čisto da joj se nađe. Od viška ne boli glava. I stavim ekipu u House Brisis. I imamo Pow 7. Sreća da postoji maksimum mana koje može da ima. Još i to da ukinu... Već vidim gomile morbid Puppeta, Ira, Darkness elementale Fire Elementale i jedno do dva fajtera.
Knight
Post by Knight »
Sva sreca da pravi gospodar madjije ima artifakt koji mu dozvoljava bacanje spelova bez mane ;)
Zbog ovakvih 'sitnih' problema c2 sam prestao da igram posle desetak partija.
Blaurgh
Post by Blaurgh »
Ne razumem odakle ideja da magije i miracli postanu besplatni..
Jel moze neko da me ispravi ako sam pogrsno ukapirao ambidexterous:
svaki put kad se odbranim (znaci bez povecane tezine) dobijem attack dice, ako taj attack dobije 1 na rolu meni se vraca difens kocka ili mogu da uzmem jos jedan attack?
Koliko karaktera mogu da se vode?
Mucous
Post by Mucous »
ja sam za to da se ova pravila revidiraju....
line of sight...igrati po starom
firing.....moze da ostane....pojacava male strelce, sa ogranicenjem da neradi za modele koji imaju artiljeriju.....
Rallying .... moze,
Perforating artillery......ovo na neki nacin oslabljuje, a na neki pojacava artiljeriju.....neznam....mozda da mozda ne.....
magije i miracly.....izbaciti....
ambidexterus, counter attack.......moze
charging str.....moze
bulls eye, assoult fire.....moze
fierce......da
sequence.....moze.....
ovo moze da bude SECORD revizija 3.6 pravila
Meni samo smeta pravilo o magijama ostalo je OK :twisted:
jorgurt hlebozvak
Pravila
Slažem se. Sad Ambidekstrični Gulovi imaju nekog smisla. Ne bi bilo loše postaviti glasanje tipa - ko je za to da se magije i dalje plaćaju? Ja sam za. Line of sight treba ostaviti po starom. Ostalo možemo da primenimo.
Pazite, svidjalo nam se to ili ne, tako je izaslo i CORD-ovi, ce se, jedan po jedan morati na neki nacin uklopiti u ovo, pa i mi, ukoliko imamo aspiraciju da budemo ozbiljan CORD. Sada svi u inostranstvu cekaju reakciju GDR-a koji treba da as we speak objavi limitacije za 2007-mu, posto je naravno jasno da GDR rulinzi za turnire cirkumventuju knjigu (bar do sada je bila takva praksa).
A posto svi daju komentar, ajde i ja :
Line of sight : Ovo je definitivno najdebilnije i zaista mislim da jedini haus rule treba da bude da nastavi da se gleda baza. Jer, ovako, najozbiljnije vam govorim da cu na svim mojim velikim modelima (vukovima, konjima itd) da napravim scenske baze pune kamenja i rastinja tako da izgledaju kao da su u j**noj dzungli ne bih li sprecio ljudima da im pucaju "kroz noge, pa u glavu"
firing : tja... nije bas cool, ne toliko zbog assault firea, koliko zbog bull's eyea. sada skauti sa pistoljima, ili nedaj boze drunski strelci koji mogu da reroluju 5 i 6 postaju neverovatan problem, svi sa prosecnom snagom shota na short rangeu od 8-10... ali sta je tu je, kao sto sam rekao to ce samo voditi vise u shooty/spelly/ faithy pravcu...
rally : ok, ajde, sada je malo teze rallyovati se, ali obratiti paznju da je nemoguce to ucijniti ukoliko ste u kontaktu sa fear-inducing fighterom, sto je cista glupost...
Perforating artillery : e ovo je jedina prava stvar. To ce da spreci krititcne sentinele da pucaju u short rangeu na nekoga na 6, pa onda projektil nastavi u onog iza njega na 3 i vise, kada ovaj promasi...
Magije i miracli : Ideja ovoga je bila da osposobi male magove (npr druid sa prosecnim spelom kosta kao formor, i naravno da ga neces izvoditi. Ovako, jos i razmislis), kao i da poveca frekvencu uzimanja magova i fathfulla ( zasto bi npr, vuk uzimao karaktera faithfulla kada za manje poena moze da uzme megaubicu iz dimenzije x?) jerbo su samo cynwall, alahan drune i acheron konstantno uzimale magove, dok su druge armije preferirale fighter karaktera sa velikim leadershipom disciplinom i sta-sve-ne... u principu za tu ustedu u poenima mozes da kupis 1-2 nova fightera, i imas vecu fleksibilnost, ali si i dalje ogranicen brojem spelova i manom/faithom. ALi naravno francuzi su kratkovidi i vec su izasle rupe u struktur : gorgona sa svim darkness spelovima, Ardokath sa svim cudima ciji je fervor 2 i manji, i onaj alahanski baja, kako li se bese zove ono... :) 8) . Cinjenica je da cemo mnogo manje na turnirima vidjati fighting karaktere, jer sada magovi/ faithfuli za iste/manje pare daju mnogo vise supporta, naravno ukoliko vam armija nije plasljiva...
Ambidexterous je vracen na c2 izdanje i ponovo je jako zao
COuter attack je logicniji
charging str, svejedno
fierce je oslabljen, IMO previse. U redu je da se sklanjaju na kraju svake faze, ali je ekstremno glupo da moze da se krece,ali ne i da radi pursuit... Ne vidim nesto da su oslabili sacred w/sareda a na to je bilo mnogo vise prituzbi nego na fierce... Sto potvrdjuje moju teoriju zavere light francuskih cordovaca :twisted:
sequenca: pa ovo je ojacanje koje je bilo bespotrebno, ali sada jako znaci fighting karakterima.
Uopste, objasnjenje koje se provlaci tu i tamo jeste da je ideja bila da se igra balansira i da se cynwalli icine igrivim. PA NAPRAVITE IM NEKE DECENT TRUPE ONDA, RACKHAM MORONI!!!
Ovo za magije i miracle nije ni toliko lose... Mozda bi trebalo to sve ograniciti na neki drugi nacin, ali mislim da je Dule u pravu za doticno... Npr. ja nikad ne bih stavio mage, kad moram da puknem brdo poena za neki manje-vise ok spell...
Knight
Post by Knight »
-Privremeno resenje koje izgleda koriste svi cordovi: Nova pravila za sve osim magije i Line of Sight-a.
Tako se moze normalno igrati :)
Pogledajte rasprave na rackhamovom forumu, ako imate vremena - ima puno zanimljivih argumenata ;)
Pa to za magije bi ipak trebalomalo korigovati, bar kao house rule, line of sight jeste malo debilan (malo vise zapravo), ali mi ipak ovo sa magijama najvise smeta(iako sam smislio novu Mid/nor i Dirtz powerplay listu .........ali ipak)
@Pendragon
Racham je bar posteniji u svojoj zaveri, u WH su Light vojske pretezno slabje od zlih, a opet nekako pobede horde Haosa :twisted:
da znam, ucestvujem u njima. Ali za sada koncenzus postoji samo za line of sight... Mozda bi bilo dobro probati da npr, samo jedna figura moze da dobije besplatne magije/faith, a sve ostale, ako ih ima moraju da plate. To deluje kao solomonsko resenje ( a i sprecice one koji hoce da izvedu sardara tiliusa, meliadora, i barda sa : Chimerical glaive
elemental storm
sparkling summoning
Light elemental summoning
Bard's song
Primal attack
Upisite jos po zelji i ostane vam mesta za konjanike, strelce itd...
Knight
Post by Knight »
I da, Dule - kako to mislis samo jedan Alahanski baja? ;)
lions army:
Mage1 72ap
Mage2 76ap
Mage3 44ap
Bard of allahan
-fill the rest of ap with some archers, falconeers and 2 knighs or a knight and some royal guards.
these boys brings wth them to the field:
-Chimmerical Glaive
-Sparkling Summoning
-Elemental summoning
-Celestial Scourge
-Strange art
-Storm of light
-Source of light
...and much more, but you you get the idea. Notice that quite possibly this is not even the best way to go about winning while frustrating the opposition with magic , but it illustrates the problem the best. What would it look like to cut down to 2 characters and deck out with some artefacts that affects mana recovery/casting difficulty/enables casting for free? Now that, my friend, is no longer the game of confrontation i enjoyed playing so far.
lost INI :-)
slayer king wrote:...
...u WH su Light vojske pretezno slabje od zlih, a opet nekako pobede horde Haosa :twisted:
Neki ljudi se ne bi slozili.
Ale ne vise o tome na ovoj temi posto je OT.
I da - u WH nemas bas Light vs Darkness vojske. Srecom.
A sta ce biti ako na spelovima i miriklima prestanu da stavljaju AP?
Kako onda ignorisati promenu pravila?
ma smislicemo nesto.....inace moze samo jedan mag koji nije karakter da ima dzabe spellove....
i da ograniciti shooting da dobiju samo modeli koji nisu artiljerija, jerbo sentinel sa bulls eye-om ili assaulotom je mnooogo zajebata stvar, ili imaju specijalna oruzja, poput seruma.......
Istina, istina......... :twisted:
@Rover
Ovo za shooting je u redu, ali bi magije sveukupno trebalo vratiti na staro ili sto blize moguce tome
jorgurt hlebozvak
Magovi
Ne Damjane, pravilo je jasno. MAG kao takav, dakle bez obzira da li je karakter ili ne, može besplatno pribavljati magije u okviru svog Pow-era. Isto važi i za faithfula.
tacno tako
to i pise u pravilima. Shooteri koji NISU artiljerija... citaj bre to
To je tacno ono sto ce se desiti. DA, da rackham prestaje da stampa ap na spellovima i miraclima, tako da ce se svi, nazalost morati pokoriti promeni pravila.
E jbg. onda idemo da se gadjamo magijama :?
Bila bi dobra fora da samo nekarakteri dobijaju dzabe magije i cuda. To bi bilo vise u duhu onoga sto je Dule rekao (mislio) da je R hteo ovim da postigne.
srebrni vitez
Post by srebrni vitez »
Ако су правила пре измена била боља, а на измене кукате, зашто уопште прихватате измене и зашто не играте по правилима каква су била пре измена?
Ko, jel' ja? wrote:A sta ce biti ako na spelovima i miriklima prestanu da stavljaju AP?
eto odgovora....
jorgurt hlebozvak
Kukanje
Debeli,
Niko ne kuka na izmene, ovo je samo faza prihvatanja izmena. Mi smo ljudi evropskih shvatanja, sa teznjom da postanemo punopravni clanovi medjunarodne zajednice i CORD-a, te prihvatamo evropske trendove i pravila igre, koliko god da nam tesko padaju. A ti balkanski saveti koje nam nudis, samo nam unose nemir i nespokoj u nase evropejske duse i zato te molim da ne podrivas nas uskladjen i harmonican sistem vrednosti.
Idem da popijem jednu plavu pilulicu.
Musa, kad mi donosis Gorgonu na farbanje?
Gledacu da do tada odradim Azaelku i Bugimena!
Shunka wrote:Musa, kad mi donosis Gorgonu na farbanje?
Moderator pa još offtopicira. Sramota :D
Rade na reviziji svih kartica. Bice gotovo pocetkom 2007. To bi trebalo da napravi balans u odnosu na nova pravila
Mind Uploader
Post by Mind Uploader »
Zekina banda wrote:Rade na reviziji svih kartica. Bice gotovo pocetkom 2007. To bi trebalo da napravi balans u odnosu na nova pravila
Do tada mislim da imam "mice" negde u ormanu...
jorgurt hlebozvak
Ne ljuti se čoveče
Ja sam sačuvao "Ne ljuti se čoveče" To je jedna veoma izbalansirana igra. Zavisi samo od kocke. Predlažem turnir u ovoj igri.
Knight
Post by Knight »
Tada:
http://en-forum.confrontation.fr/viewtopic.php?t=25719
Nova pravila za turnire.
najzanimljiviji deo, tj deo koji zaustavlja megasprz magijske liste:
The total rank of all mystic characters (magician, warrior-mage, faithful and warrior-monk characters) is limited as follows:
200 AP: 2
400 AP: 3
600 AP: 4
800 AP: 5
Only one example of a same spell, miracle, artefact or treatment can be played for every 500 AP (even incomplete).
All large Elemental summonings (Darkness Elemental, Fire Elemental, etc.) are restricted to rank 2 (or above) characters and count as the same spell for uniqueness purposes.
8)
Postigli su zeljeni efekat - sada svako moze da izvede jednog maga koji moze poneti vise spelova,a nema onog momenta imam 5 magova na tabli :roll: . Tako da su nova pravlia zapravo postala interesantna ;)
Najludja stvar koja se btw desava je da su summonig spelovi zapravo oslabljeni posto za njihov intenzitet 4+ mogu da se ponesu 3 spela koji pomeraju tvoje jedinice, lece rane, daju kocke ili abilitije - a vise nema onog momenta pa to kosta 90 poena.
thezgag
Post by thezgag »
Dobar. All makes sense now. Magovi pojačani, swarming ujeban. Me likey. 8)
EDIT: Sad sam malo gledao, kao da sam ja radio pravila :lol: Moja lista je samo ojačana, a skoro sve liste koje sam sretao moraju se modificirat. Hihi. Samo 1 alahan konjanik? 2 pretorijanca? 2 fomora? Nemaštoviti igrači će se nać na 100 muka :twisted:
Mucous
Post by Mucous »
Hm, ovo je možda istina ... a svi su podivljali na line of sight pravila...
http://en-forum.confrontation.fr/viewtopic.php?t=25720 Image
Return to “Confrontation”
