FAQ
FAQ
Okay some of this comes from Questions we have asked others from other Fede's. When i get a mo i'll try to compile it with other stuff into a single document...
Q: Can wraith riders be ressurected with "Ressurection of the Wraiths"?
No.
Q: Is the wraith riders interpreted as "drune wraith"s for -cost reduction and other abilities from Scourge: GaC?
-Ardokath faith points?
-Soulsnatchers special rules?
-Soulsnatcher requirements?
No.
Q: Do Red Karnaghs count as "karnaghs" for Kilgorm-the axe of Wandyr?
No.
Q. Arkeon Sanath gets a mutagenic dice and Rage of the Desert says he must put all dice in attack. What happens if an opposing Neuromancer attempts to use the Intimidation power on him?
Intimidation doesn't work. Re-read the power's text.
Q. In Lab/Inuka using the Solo/Pursuit. If a model using the Solo ability is unable to reach its intend target with the extra pursuit move, does it get to redirect to a different target?
No.
Q. Serum was shooting at a lion standard bearer, with a character right behind him. He took his shot, missed, but the shot strayed and hit the character behind. This shot was with the toxic love. Will the toxic apply? Or did I already use it up when I took the original aim roll?
Nope. If the shot misses, Toxic is lost; artillery doesn't combine with toxic.
Q. If a character warrior mage has the right paths does that include him into certain warrior mage types. I.e is Taemor a Mystic warrior.
No. By the way, Tamaor is not a warrior mage
Q. Question: Does assault fire come into effect on a pursuit movement if the target of the pursuit is visible at the time the move is declared?
No.
Q When a Penetrating Artillery weapon kills a target and follows into another target which happens to be in combat, do you hit the target in the line of fire or randomise it?
You hit the target in the line of fire.
Q Are cadwallon weapon bearers deployed on the same card as thier master, or whether they are supposed to be played on the same card for the entire game?
They're deployed on the same card, but use two different cards afterwards.
Q Can Paladins of Doriman use the normal Paladin extra's??
No.
Q 1) Does a fireball damage miniatures inside his area of effect even if this last is situated on a different level of altitude?
2) Does the spell "Vague de Mort" (my best translation from the italian card would be "Death wave" ) of Ahsa Ruyar count undead at different levels of altitude from the mage to increase damage?
Same level of altitude only to both questions. I think you got a more generic answer on the French board today...
Q. If Ahsa includes a model in a Cadwallon list does it count as an ally or is it much like some of the Theme packs where its not really an ally but part of the army...
A.
[Quote from: Martin TERRIER]
[Quote from: Finery of bewitchment]
The chosen fighter is an ally, but is not counted in the percentage of ally to which is entitled Ahsa Ruyar's side.[/quote]
So yes, it's an ally, and no, it's not part of the army. So can only be used when using the Allies theme.
No.
No.
No.
No.
No.
No.
A.
- slayer king
