News from the FOW
Re: News from the FOW
Brown water navies- čamci,brodovi,helikopteri,avioni , kamioni.....ludilo. Šteta se izgleda jedini ja ložim.
Ajde bre, ne igraš ni ovaj "normalan" WWII FoW, tako da mo(nu)mentalno prestani da kukaš...
Ne, ali mi se ne daju novci za nesto stob ih igrao sa jednom osobom. Ma koliko zapravo meni nase partije bile super.Nemanja wrote:Brown water navies- čamci,brodovi,helikopteri,avioni , kamioni.....ludilo. Šteta se izgleda jedini ja ložim.
dve osobe zapravo
Peđa, izvini, delimično si u pravu. Ti si još u fazi sakupljnja žderača pirinča, zato sam rekao.
Deko, igram ja, bez brige...samo što igram previše perioda. Od turnira do avgusta prelazim samo na EW ETC liste.
Histerični, da samo vidiš ofarbane kobre i huije...
Ja bih rado voleo da ih vidim, mada je meni gotivnija arm cav varijanta.
Imate novi Lessons from the Front na FoW sajtu, za one koje zanima...
Mounted Assault transports can now assault buildings.
Smoke Ammunition uses all the normal hit allocation rules, just with the attacker choosing rather than the defender which is different to how I've always seen it played. So, if a CiC King Tiger joins a platoon of Panzer IVs you need to allocate smoke onto the PzIVs first as they have lower armour.
You can't use Crash Action to unlimber and dig in at the same time.
Barbarossa updates are in, most importantly the change to KV-2s.
Carius only ignores concealment from terrain so you can productively smoke him or night fight him.
Evo Zvezdinog PzIV F2
http://www.zvezda.org.ru/velikaya-otechestvennaya/6251/
- Bojan Tiger Ace
Zvezda ozbiljna!!! Jedva cekam da dodju u LW!
Zamisli zvezdine konigstiger-e ? :D
Berlin - stigao prvi sken, relativno los, samo liste i specijalna pravila bez fluff-a, dobar za prvu pomoc...
- Bojan Tiger Ace
Prve slike modela za Cold War gone Hot a.k.a. Team Yankee
http://www.breakthroughassault.co.uk/20 ... y-and.html
Evo (još) nešto za Uroša...
15mm British Cruiser A9 and A10 design variants in the pipe...
to je u pipline-u odavno, kao i KV i svašta nešto...
http://www.flamesofwar.com/Portals/0/Do ... eFront.pdf
Najnoviji FAQ (Lessons from the front) septembar 2015
Options for a platoon marked ‘All’ and
‘Any or all’ are clear as to which teams
may have the option. What about
options that don’t say either? Does that
mean ‘all or none’, or does it mean
‘any or all’?
Unless it says any or all, an option is an
all or none affair. You must take that
option for all the relevant teams or for
none of them.
‘any or all’?
none of them.
Stigao Sherman, mogu Sovjeti a mogu i Britanci da ga koriste. Rejoice!
http://www.zvezda.org.ru/velikaya-otechestvennaya/6263/
- Bojan Tiger Ace
Hm...
zašto meni ovo miriše na X-Wing sa tenkovima
- Bojan Tiger Ace
Upravo tako i izgleda, odlicno!
Vidjeh neke najave za 2016. godinu pa nekoliko komentara...
- Japanci i Amerikanci za Pacifik, dvije knjige... ubili me gomilom informacija oko ovoga . Vjerojatno će objaviti dvije slikovnice sa 2, 3 liste za svaki period i onda još deset puta toliko u jeb.... digitalnim listama
- V3 pravila za MW knjige, ali samo (pogađate) u digitalnom izdanju...
- Oživljavanje nekih LW knjiga vjerojatno dodatnim digitalnim listama...
- Dostupnost digitalnih lista za Android
Sa posla ne mogu lijepiti slike pa će to vjerojatno netko drugi napraviti .
T.
T.
Usput da dodam da su digitalne liste trenutno na solidnom popustu, 1 usd
Pacifik super izgleda,mada mi nije jasno sta ce sve biti unutra. Izvesno je da nema Burme, Britanaca,Kineza.....
Bojim se da će sa jednom tankom knjižicom pokriti cijeli pacifički rat (MW i LW) .Nemanja wrote:Usput da dodam da su digitalne liste trenutno na solidnom popustu, 1 usd
Šteta da ne idu sa pojedinačnim knjigama za svaku značajniju bitku.
Baš me zanima kako će izvesti velike bitke brodova i aviona, i hoćemo li napokon u listama imati nekoliko jedinica aviona, brodova... Avioni bi morali biti u nekom jako malom mjerilu, a brodovi pogotovo (možda 1/3000). Mada, ne vjerujem da će ići toliko daleko jer su se trenutno upetljali sa puno perioda (WWI, Team Y...).
Možda će Japanci napokon ispraviti povijesnu nepravdu . Za to im treba tek malo sreće i ozbiljni tenkovi tipa Chi-Nu, Chi-To, Chi-Ri, O-I..
T.
Upravo je ovo ono sto mene plasi, previse su se rasplinuli, i WWII ce polako prestajati da im bude interesantan (trosice resurse na druge periode) . . . Sasvim je logicno da traze nova trzista i nove puteve razvitka, da bi opstali, ali to meni licno ne odgovara jer me osim WWII nista drugo ne interesuje . . . Nasuprot meni, koliko vidim, vecina nema nista protiv da proba i neki drugi period, sto je upravo ono sto kompanija hoce . . .TomZG wrote:Nemanja wrote:Baš me zanima kako će izvesti velike bitke brodova i aviona, i hoćemo li napokon u listama imati nekoliko jedinica aviona, brodova... Avioni bi morali biti u nekom jako malom mjerilu, a brodovi pogotovo (možda 1/3000). Mada, ne vjerujem da će ići toliko daleko jer su se trenutno upetljali sa puno perioda (WWI, Team Y...).
Novi US tank destroyeri
Hmmmm . . . Na osonvu slike sprua deluje mi da mogu da se naprave i M10 i M36 pa da se samo menja kupola po potrebi . . . Nesto mi se sve cini da cu u skorije vreme voziti puno tank destroyera . . . :D
Hocu, moram samo da pazarim jos koji cavalry recce section . . . :D
- Bojan Tiger Ace
http://www.flamesofwar.com/hobby.aspx?art_id=3273
Tank aces izlazi!
Da li ima zainteresovanih da probamo da odigramo ovu mini kampanju?
Tank aces izlazi!
http://www.wwpd.net/2016/10/why-we-figh ... -bang.html
Počnite da slušate negde oko 1 sata. Pričaju o novim prvilima. Biće slična TY. Sa karticama. Počeće sa MW u pustinji.Kažu možda izađu u martu, mada ne zvuče ubedljivo.
Moći će i dalje da se koriste LW i EW knjige sa starom poentažom.
- Bojan Tiger Ace
Stigli plasticni tigrovi i pume od BF!
http://www.flamesofwar.com/hobby.aspx?art_id=5309
- Bojan Tiger Ace
Ako nesto nekome znaci, cuo sam od ekipe iz Spektar Mhobby da Zvezda planira da ukine komplet seriju drustvenih igara, odnosno vozila u 1/100 i 1/144 razmeri.
Tako da znate...
Tako da znate...
Najava nekoliko novih knjiga sa v4 pravilima.
http://www.flamesofwar.com/hobby.aspx?art_id=5411
Zanimljivo je da će knjige biti besplatne.
Imat ćemo pravila za EW i LW zajedno, zatim posebnu knjigu sa pravilima za nacije i warriore.
Pravila će biti tanja nego do sada.
Kartice će nam navodno pomoći da igramo brže i jednostavnije.
Dolaze nove 3 misije dok će postojeće biti dorađene.
Artiljerija će biti ubojitija protiv ukopane pješadije, AT topovi protiv tenkova...
Veća sloboda kreiranja liste.
Ukida se at the double, ali na njegovo mjesto dolazi Dash movement.
Samo sam malo preletio po tome što su napisali pa sam sigurno nešto važno izostavio .
Ono sto sam ja video i razumeo, nimalo me ne odusevljava . . . Imam utisak da ce vise do izrazaja doci papir/kamen/makaze/guster/spok, ali otkud znam, mozda to i nije tako lose . . . Zivi bili pa videli . . . Sve mi to vise lici na upro(pa)scacanje sistema zarad prikupljanja novih igraca iz redova omladine . . . Ja iskreno volim komplikovano, zato mi se i ne svidja upro(pa)scavanje pravila . . .
- Bojan Tiger Ace
Nemojmo odmah padati u ocaj, mozda bude dobro ipak.
Ova prica za artiljeriju protiv pesadije, at topove protiv tenkova zapravo veoma ima smisla. Kada pogledamo realnost, sanse da artiljerija pogodi tenkove u pokretu je maltene nepostojeca, sasvim nasuprot trenutnim pravilima gde je cak lakse pogoditi vozila (i za jacu arty) ubiti ih nego ukopanu pesadiju.
Takodje i za at topove koji protiv pesadije bukvalno rade ako pogode pesadinca direkt, i niko ih tako i nije koristio. Zato se zovu AT (Anti Tank) topovi. U EW se AT topovi poprilicno agresivno koriste za iskopavanje pesadije, znam da ja jesam :D
Videcemo, mozda se cak i igra popravi
Po onome što sam video pravila će da liče na Team Yankee.
Ne mnogo jednostavnija samo brža.
Ono što je dobro je što će moral i obučenost biti razvodnjeni.
Odnosno neće jedna numerička vrednost biti ista za sve testove.
Ево прочитао сам и други пут правила за Тим Друзја. Истина, нисам одиграо ни једну партију, још бојим војску. Правила за Тим Друзја су тек мало различита у односу на правила за ФоВ. Разлике стану на једну страну или страну и по`.
Оно по чему се Тим Друзја и ФоВ разликују је огромна разноврсност јединица у ФоВ. У Тим Друзја јединице су униформне, практично све су "тенк тимови" сем пешадије, нема "обичних" топова и артиљерије нпр. Свака страна за сада има један тенк а добиће можда још један у догледној будућности и то је све (а знамо да се рецимо Т-64, Т-72 и Т-80 готово не разликују по карактеристикама битним за нашу игру)
Чак и ако В4 правила личе на Тим Друзја то не мора да значи да ће игра бити лошија јер је основна предност ФоВа у тој разноврсности јединица. Мени се помало не свиђа та поентажа на 100 поена јер мислим да није довољно детаљна али стварно не бих унапред да критикујем.
Ако нам не легне В4 имамо све за В3 па ћемо играти.
Неке ствари у Тим друзја су по мени много боље решене. Лакше се погађа бочни оклоп тенка. Уништиш авион, уништио си га. Ако су стварно мало олабавили артиљерију против тенкова па то је одлично
Невезано за ову тему: За сада ништа од турнира у Вршцу ако будем могао после Нове године зваћу.
