ETC 2019
Bojan Tiger Ace
ETC 2019
Post by Bojan Tiger Ace »
Saborci,
izasla je prva verzija pravila za formiranje ETC timova.
The rules committee has discussed and agreed an INITIAL base line for players to start forming their team and to test further. We stress this isn’t final but represents and agreement between us all and works when we have built example teams list. We thought people would like to know sooner so at least they can get a feeling of where it’s going.
- 100pt games
- no more than 2 players per nation. Please note that using a allied formation counts as 1 use however a player using 2 formations from the same nation counts as 1 use. Allied support units do not count towards his limit.
- No more than one use of a formation per team. Eg you can’t take 2 x afrika rifle formations. Please note that formations with the same name from different books can’t be used eg you can’t take a Panzer 3 formation from afrika korp and iron cross. However you can take a strelk and hero strelk as they have different names.
- all command cards can be used however no command card may be taken more than once per team. The only exception is cards needed to form core units of a card based formation. Eg a Cossack formation may take more than 1 Cossack card to allow the formation to be created. However you can’t take more than 1 captured 6pdr pltn.
- the match up is likely to remain similar to last year but stances assigned before before match up but hidden until all match ups are complete.
- web units allowed. BF have stayed these will be added to forces.
The intent is to encourage a wider range of forces do to the more limited selections hence the no repeating formations etc these also some what limits the worst of the spam. We realise some lists will be a bit more hit by this likitatikn such as no double Italian armoured formation but the odd impact benifits the over all system.
Please can teams test these, and then come back with any fundermental issues that need to be looked at.
These points are subject to change but represent a starting step for team organization. Testing will continue until the end of Dec to allow a full rulepack to be created in Jan 19.
