Turnir april 2011
Turnir april 2011
Turnir u rat mashini u nedelju 10.04
Re: Turnir april 2011
Yay!
Nego ovaj otkud to, ko sve dolazi?
Ja dodjem sigurno. Nihta bez kriksa ;}
Manje-vise ekipa koja je igrala ligu (a mozda jos neko bane
- BoltaFodda
Hocu i ja!
Koliko poena, scenariji koji su, sav taj dzez..
Eve Stevo:
Please be aware that the event will start at 12.30 this Sunday. At the front desk there will four equal sized cards that you should write your lists on. When registered you will be assigned a table and you should lay all four cards out for one to be picked by your opponent. Once each of you have picked a list then set up and play as normal. The list picked is then no longer available to use in later rounds.
You list needs to include a separate Warcaster/Warlock in each list (though primes and epics count as distinct and can be used) and character models and units and Warjacks/Warbeasts can only be used once and not repeated.
Each scenario is the same. It is a 35pt game and the scenario is Extreme Shot Clock. The rules of this are simple, from the first players third turn onwards both casters/locks lose 1d3 health from their maximum health. Thus if on the 3rd turn an unwounded Tyrant Xersis is playing a Jeremiah Kraye with 6 wounds left and both players rolled 2 on a d3 then Xersis would effectively lose 2 wounds but Jeremiah Kraye wouldn't - he would only be able to be healed to 2 less than his maximum. Wounds lost from the shot clock cannot be healed - you are effectively losing your actual health capacity.
Due to the nature of the scenario the games have no round limits. However each game has a time limit of 100 minutes. If it is on the first players turn after 95 minutes he must immediately end his go and the 2nd player gets 5 minutes to complete their turn. If it is the second players turn after 100 minutes then it is immediately dice down.
Please ensure that you arrive before 12.30 so that we can start all games on time. Players not at the club when the first round starts automatically forfeit the first match. The tournament is free to enter and the last of the really nice Retribution medals are up for grabs for the winner.
Znaci - 4 liste; protivnik bira na slepo; 4 kastera (epici se racunaju kao zasebni); karakteri ne mogu da se ponavljaju u listama.
Ako ti ne odgovara format, ipak dodji - prosvercovacemo te
