Prvi qualifier 2016 : 23.01.
Pocinje sezona qualifiera 2016. Za pocetak, zagrevanje uz 35-pts format, bez tier lista, bez ADR-a, kako bi se noviji igraci lakse uhodali u qualifier sistem. Pocnite sa prijavama!!!
Bold Horizons
2016 Serbian Masters Qualifier I
Noon on the 23rd of January 2016 @ Klub Zmaj, Belgrade
This is a Commander’s Crucible event where the players must use 35pt lists. Theme Forces cannot be used. Players select a faction, pact, or contract and construct a number of battlegroup lists, each consisting of one warcaster or warlock, the warjacks or warbeasts in his or her battlegroup, and any models attached to his or her warcaster or warlock. Players must have at least 2 battlegroup lists, and at most 3 battlegroup lists.
Players also construct a single support list containing units, solos, battle engines, and warjacks/warbeasts that are not part of a warcaster/warlock’s battlegroup. This support list is combined with a battlegroup list to create the player’s army list each round. Battlegroup and support list combinations cannot exceed the point size of the event and cannot fall more than 5 points under that point size (including warjack/warbeast points).
For example; Jovan prepares his support list of a minimum Choir of Menoth (2pts), a Vassal (2pts), Rhupert Carvolo (2pts) and a full unit of Temple Flameguard with unit attachment (8pts). This 14 point support list will be in every game. To compliment it Jovan has three 21pt + the WJ points of the warcaster battlegroups which are character restricted.
During the list selection phase, each player secretly chooses a battlegroup (represented by its corresponding warcaster/warlock card) to combine with their support list. Each battlegroup must be played at least once during the event.
Battle group lists must be between 20 and 35 points plus WJ/WB points and support lists must be between 0 - 15 points. Character restrictions apply to battlegroups.
We are also playing the Death Clock variation with each player having 42 minutes per round including for deployment. Base line painting restriction applies.
• Round 1 – Recon (pg20 Steam Roller 2015)
• Round 2 – Incursion (pg18 Steam Roller 2015)
• Round 3 – Outflank (pg19 Steam Roller 2015)
• Round 4 – Close quarters (pg15 Steam Roller 2015)
Please remember to print out a copy of each objective you wish to use for each list.
2015 Steamroller scenarios can be found here: http://files.privateerpress.com/op/sr20 ... iendly.pdf
A current list of the rules errata can be found here: http://privateerpress.com/files/WM%20MK ... 202015.pdf
Can everyone with an android phone/iOS please make sure that they download a CHESS CLOCK application for the event please? Most of these applications are for two players and so only one person per table needs to have the app running.
https://play.google.com/store/apps/deta ... Free&hl=en
Registration starts at 11:50 and the first dice fly at 12:30. The top two players will qualify for the end of year masters. If we have more than 16 players then the event will be separated into two smaller draws and the winner of each draw will qualify for the finals and so there will be no more than 4 rounds in total.
Please note the entrance fee for this is 300 dinars for Zmaj club members and 600 dinars for non-members.
As the previous year’s winner I will be judging this first event. Please remember that we want to be promoting sportsmanship and open play so abide with the rules of conduct.
• Do not offer advice, comments or criticisms of any games that are going on if you are not playing
• Prepare all templates and tokens in advance so that you do not waste your opponents clock time during the game
• Agree the board terrain prior to rolling the first dice
• If you have any questions call me over and I will stop the clock if necessary.
Liste poslati meni, do 16.tog januara, ovde na pm, ili na mail [email protected]
Prijavljeni :
1. Ota
2. Steva Krkelic
3. Boltafodda
4. Rick
5. Stefaz
6. CheMilan
7. Shunka
8. Serbianraven
9. Zekina Banda
10. Stoka
11. Zerglord
12. TakasunMc
13 : Dejan - Menoth
14 : Bjelajac
15 : Luka
16 : dzon vejn
Bold Horizons
Prijavljeni :
1. Ota
2. Steva Krkelic
3. Boltafodda
4. Rick
5. Stefaz
6. CheMilan
7. Shunka
8. Serbianraven
9. Zekina Banda
10. Stoka
11. Zerglord
12. TakasunMc
13 : Dejan - Menoth
14 : Bjelajac
15 : Luka
16 : dzon vejn
![Image](http://i35.photobucket.com/albums/d177/Pendargon/Magnus.gif)
![Image](http://i35.photobucket.com/albums/d177/Pendargon/disc_dominate.gif)
![Image](http://i35.photobucket.com/albums/d177/Pendargon/disc_potence_s.gif)
![Image](http://i35.photobucket.com/albums/d177/Pendargon/disc_celerity_s.gif)
![Image](http://i35.photobucket.com/albums/d177/Pendargon/obf.gif)
![Image](http://i35.photobucket.com/albums/d177/Pendargon/disc_quietus_s.gif)
Re: Prvi qualifier 2016 : 23.01.
Prijava (ukoliko se ovde prijavljuje)>
Djenrale uzalud te traze,
cuvaju te sve bozije straze.
Prijava :D
Me too - Everblight
Znači sad karakteri mogu da budu u više od jedne liste?
U svakom slučaju, ajd prijava - Retribution of Trollls
Janissa can be in all listsPendargon wrote:Character restrictions apply to battlegroups
Ipak ne mogu 23-ceg
Ako nekim slucajem pomerite za 24-ti dolazim ...
![Sad :(](./images/smilies/frown.gif)
Postoje sanse da tada budem slobodan.
Prijava.
Ipak nista od mene, Mikanov sin slavi rodjendan
DUle, da je je warlock/warcaster attachment deo betlgrupe ili deo "ostatka" liste ?
Pa Battle Group bi trebalo da čine WarCaster/Warlock sa svojim WarJack-ovima/WarBeast-ovima i WarCaster/Warlock Attachment-ima, zar ne?
![Image](http://i188.photobucket.com/albums/z285/mdeka/milinovic-signature_zpsfa1a024e.jpg)
![Image](http://i188.photobucket.com/albums/z285/mdeka/BannerMKII_khador_sorscha_zpsa95ea7ef.png)
- TheSerbianRaven
Prijava - Menot
Apparently they are not - see Dule's next post.Knight wrote:DUle, da je je warlock/warcaster attachment deo betlgrupe ili deo "ostatka" liste ?
Squire NIJE deo battlegrupe, nit hierophant, niti Kadorski kera, niti Silly Willy i svi ostali attachmenti. To je u osnovnim pravilima, a i u pravilu attached :
Attached - Before the start of the game, attach this model to a friendly Faction warcaster for the rest of the game. Each Faction warcaster can have only one model attached to it.
Kao takvi, ne benefituju od battlegroup buffova, i NISU deo battlegroupa. Stoga, idu iz non-battlegroup dela poena.
http://privateerpressforums.com/showthr ... attlegroup
I've played that format in the UK last year and they got it wrong too. Apologies - I genuinely thought it was.
Prijava.
I da pojasnim (ako sam dobro razumeo): attachmenti idu u deo battlegroup liste ali na njih ne deluju stvari koje deluju na battlegroup.
![Image](http://i203.photobucket.com/albums/aa8/jaijkija/neweng10.png)
Zekina banda wrote:Prijava.
Pendargon wrote: Kao takvi, ne benefituju od battlegroup buffova, i NISU deo battlegroupa. Stoga, idu iz non-battlegroup dela poena.
Oto, lose smo procitali - MOZES da imas vise od jednog unita u supporty ![Happy :)](./images/smilies/smile.gif)
Naravno da mozete, samo morate da se uklopite u 15 poena za 2 unitaKnight wrote:Oto, lose smo procitali - MOZES da imas vise od jednog unita u supporty
Da li warcaster/warlock moze da se ponavlja (sa razlicitim battle group-ama) ili moraju da budu dva ili tri razlicita warlocka u zavisnosti od broja grupa kohe se vode?
Da se nadovezem na Milosevo pitanje, da li mogu da se vode razlicite verzije jednog kastera?
Battle group lists must be between 20 and 35 points plus WJ/WB points and support lists must be between 0 - 15 points. Character restrictions apply to battlegroups.milosh wrote:Da li warcaster/warlock moze da se ponavlja (sa razlicitim battle group-ama) ili moraju da budu dva ili tri razlicita warlocka u zavisnosti od broja grupa kohe se vode?
Znaci, nema ponavljanja warlocka/warcastera, i nema ponavljanja character zveri/jackova
stefaz wrote:Da se nadovezem na Milosevo pitanje, da li mogu da se vode razlicite verzije jednog kastera?
Sta su razlicite verzije jednog kastera? Ne razumem pitanje
To nisu razlicite verzije jednog kastera :-D.
Da , dozvoljeno je koristiti , na primer, commander Coleman Strykera u jednoj listi, Lord Commander Strykera u drugoj, i Lord General Coleman Striker u trecoj.
To nisu isti kasteri, to su razliciti kasteri
Prijava.
- TheSerbianRaven
Meni ce za turnir trebati na zajam vassal of menoth i hierophant.
- BoltaFodda
Prijava
