Pocetnicka pitanja tj. kako poceti sa Warmachinom/Hordama
Danas smo naucili jos par stvari koje smo radili pogresno, a vezano za skornu :
Erratum: Color Card : Martial Discipline
Replace the first sentence of Martial Discipline with the following:
"While in Xerxis’ command range friendly living Skorne small and medium-based warrior models, including Xerxis, benefit from Martial Discipline."
Feroxi ne slusaju Xerxa, on je previse mali... :lol: :lol: Tako da mi je quartermaster stradao zadzabe.
Evo za kreu, da se shunka uveri :
Erratum: Primal p.133 : Paralytic Aura
Replace with the following:
During its activation, the Basilisk Krea may be forced to activate Paralytic Aura. Enemy models currently within 2” of the Basilisk Krea move at half rate and suffer –3 DEF. While within 2” of the Basilisk Krea, friendly models, including the Basilisk Krea, gain +2 DEF and ARM against ranged attacks. The effects of Paralytic Aura and Paralytic Field are not cumulative. Paralytic Aura lasts for one round. The Basilisk Krea can only use Paralytic Aura once per activation.
I na kraju, cetrati dobijaju +2 na DEF a ne +2 na armour od chargea, kako je miroslav rekao, sto bi im verovatno vise znacilo u zivotu nego + na armor...
Erratum: Primal p.140 : Set Defense
Add the following ability to the War Spear:
Set Defense – A Cataphract Cetratus gains +2 DEF against charge and slam attacks originating from his front arc.
- PainBringer
- PainBringer
- Resurrection
Re: "kako poceti sa Warmachinom/Hordama" continued....
Pre nego se upustim u kupovinu Stevinih napustenih Kriksića, da li je neko raspoložen za tutorijal partiju i time me potencijalno vrbuje?
Postoje li negde pravila on-line (ne računajući ona Quick rules sa PP sajta) ili da mi ih neko posalje na mejl ako ih ima u elektronskom formatu?
Kao prvo i osnovno quick start rules su sve sto ti treba... Veruj mi to sto pise u njima kada naucis igraces dovoljno dobro... Sve ostalo su finese koje ce te najbolje nauciti Dule, sa obzirom da on igra Cryxe...
A na Danima fantazije ja sam kao i ceo x tamo, i igracemo samo warmachine pa dodji sa figurama (ili bez, pa cemo ti mi damo da se igras )...
Poz ...
Poz ...
dodji bilo koju Nedelju do Sigila (Rickovog kluba) pa tjesh da vidish... a mozhda i da se naigrashResurrection wrote:Pre nego se upustim u kupovinu Stevinih napustenih Kriksića, da li je neko raspoložen za tutorijal partiju i time me potencijalno vrbuje?
P.S. mozhda ne bi bilo loshe da se svi ne-rickovi postovi sa ovog threada sklone, chisto da ostane samo puna tutorijala i predloga, a ovaj nash OT da se skloni negde drugde, npr u onu staru "kako pocheti..."
Re: Pocetnicka pitanja tj. kako poceti sa Warmachinom/Hordama
@mladjano bugarce
Djidali smo Stevu (nije da je bilo bitno) -
Iirc is the mini-feat worded "after all IFP have completed their combat action". You don´t have a combat action if you choose to run - so no shieldwall after running for IFP.
Mislimda je to prvi ozbiljan bag u pravilima. Pocelo je sa Vilimonom, a u poslednjem betl riportu u No kvoteru dzek koji je nokdaunovan ustaje i trci (sto je direktno u suprotnosti sa pravilom da ako trcis nemas kombat akciju).
Zasto je Vilmon bag? Trcanje je movement akcija, on se odrekne combat akcije... To sto ne moze imati kombat akciju posle trcanja ne znaci da je se ne moze odreci.
Zar ne kaze pravilo za KD da nema trcanja nakon ustajanja? Ne vidim kako se pravilo koje se odnosi na trcanje i combat akciju odnosi na KD...
- dublerius
- Location: novi sad, vojvodina, srbija, balkan, europa, stari svet, zemlja, solarni sistem, mlecni put
kd kaze da ustanes odrices se ili kombat akcije ili muvmenta
... sto znaci da si se dvaputa odrekao kombat akcije.
Pravila kazu da posle trcanja model ne moze da radi neku akciju. Ne pise da je odricanje od akcije cena za trcanje.
Iako nikako nije za porediti, imao je slucaj u Magicu povodom odricanja od faze napada...
Postojao je bag, da se igrac moze odreci mnogo puta jedne faze, a onda su promenili da se prenosi svaki put na sledeci krug, tako da igrac koji se odrekne dva puta, ustvari odrekao dve faze napada, u ovom i sledecem krugu...
U trcanju se nigde ne koristi terminologiaj "odricati". Posle trcanja model ne moze da ima akciju. Nista dubokomisaonije od toga.
Mislim da je u duhu igre da ako je cena za trcanje da nemas akciju onda kada moras da se odreknes akcije nema trcanja... Ali slazem se sa svim sto se dogovorimo, mada meni recimo juce nije ni palo na pamet da probam da trcim sa warjackom koji se odrekao akcije...
jbg, nisi dovoljno veliki cheater ni rules-lawyerMind Uploader wrote:Mislim da je u duhu igre da ako je cena za trcanje da nemas akciju onda kada moras da se odreknes akcije nema trcanja... Ali slazem se sa svim sto se dogovorimo, mada meni recimo juce nije ni palo na pamet da probam da trcim sa warjackom koji se odrekao akcije...
Ali ne u trcanju, vec u specijalnim pravilima na modelima... Mislim da nisi shvatio poentu...Dawngreeter wrote:U trcanju se nigde ne koristi terminologiaj "odricati". Posle trcanja model ne moze da ima akciju. Nista dubokomisaonije od toga.
Znaci, ako posle trcanja nemas akciju, kako onda mozes da se odreknes necega sto nemas (pragmaticari ce reci lako, a patriote nikako 8) )
Ne funkcionise bas tim redom, kolko ja kapiram. Odrekao si se akcije kada si odluci oda ustanes. Onda trcis. Zavrsis trcanje i tada ne smes da upotrebis akciju. Koju nemas, sto je nebitno za wording trcanja.
EDIT: apropo odricanja onoga sto nemas, ja imam samo jednu stvar da kazem. Ne damo Tibet! :lol:
Ako je Jack ustao iz knockdown-a i trcao to je greska jer u pravilima jasno pise da ne moze da trci. Sto se ostalih tice vodili su se time da ako negde eksplicitno ne pise da model nesto ne moze da radi taj model to moze pa otuda se Vilmon odrekne akcije i veselo trci(Verovatno jedno od njihovih slabijih pravila ali sta je tu je)
Bojan je u pravu (kao i uvek)
Ne bio ja lenj pa pogled'o u knjizi... Na 49 strani pod knockdown pise:
"...A model that forfeits its combat action to stand can advance but may not run or charge..."
Odakle vam uopste ideja da moze da trci posto je ustao iz knock down-a?
@Edit@: Inace, identicna stvar pise i u Hordama...
To sam i ja rekao na prosloj strani - ne mozes ustati i trcati jer tako pise u pravilima za KD. Forfeitovati akciju i trcati mozes, zato sto nigde ne pise da ne mozes.
str 35. No quater 17, srednji stubac
Wow. Cak sam uzeo knjigu, procitao knockdown, i ovo nisam primetio. Blago meni sa tako snaznim perceptivnim sposobnostima...Mind Uploader wrote:"...A model that forfeits its combat action to stand can advance but may not run or charge..."
](./images/smilies/eusa_wall.gif)
Znas, nekada su i white dwarfovi imali sjajne battle reportove, po kojima su ljudi ucili pravila. Posle su se ti battlereportovi iskvarili i propali jer su postali dirigovani. Nije nemoguce da je PP posao tim putem... 8) :? :?Zekina banda wrote:str 35. No quater 17, srednji stubac
Kako se postavljaju kossite woodsmeni? Kaze moraju biti u skirmis formaciji 3 inca od ivice table...blablabla...
Tri inca od ivice table = celo postolje mora biti u tri inca od ivice table ili deo postolja mora dodirivati liniju koja je 3 inca od ivice table?
Skirmish formacija = moraju biti na vise od 1 inch jedan od drugog (inace su u open formaciji)?
Vec sam ti objasnio za 3 incha... Znaci : Ako kaze " completely within" onda cello postolje mora biti u 3 incha (kao goreshadeov feat). ukoliko ne, onda samo deo postolja mora biti u 3 incha (znaci, efektivno si na oko 3, 85 incha od ivice. E, sad... za formaciju... Skirmish kaze :
"Skirmish formation lets troopers be UP TO 3" apart", ali vec u sledecoj recenici se samoprotivi :"A unit must begin the game with all of its members in skirmish formation or closer". , pa krece da objasnjava sta je open formation. Na osnovu ovoga, ja bih zakljucio da open formation NIJE skirmish formatin, na isti nacin kao sto tight nije skirmish ili open. Stoga , nekako mi se ipak navodi, da kossiti moraju da udju spaceovani malo vise od incha, a manje od 3 incha. Ipak, malo je opskurno, pa cu postaviti pitanje infernalima. Sacekacemo odgovor.
Nisu bas azurni sa odgovorima?
ne nego je dule na uprisingu....
Nasao sam, pise u zvanicnom faq-u na pp sajtu.
linky : http://www.privateerpress.com/FAQ/warma ... category=1
tako da mogu da se dodiruju p**nisima kad udju iz terena.. :DFormations are not mutually exclusive. Models in tight formation also meet the criteria for being in open or skirmish formation. Likewise, models in open formation also meet the criteria for being in skirmish formation.
\:D/ Oni vole da se dodiruju p00000ma kada izadju na tablu... :oops: :D Po ovim pravilima vredi voditi i vecu ekipu...
Hvala za pojasnjenje!
- Resurrection
Stavise, pise i u knjizi pravilaPendargon wrote:Nasao sam, pise u zvanicnom faq-u na pp sajtu.
:tako da mogu da se dodiruju p**nisima kad udju iz terena.. :DFormations are not mutually exclusive. Models in tight formation also meet the criteria for being in open or skirmish formation. Likewise, models in open formation also meet the criteria for being in skirmish formation.
elem, pokupih ja Ad-Razu i chitam i naletim na sledetje stvari..
Circular Strike (* attack) - Amon may make a seperate melee attack roll against each opponent in melee range of hist front and back arcs. completely resolve each attack individually and apply the targets' special rules immediately as each attack is resolved. Determine damage normally.
Crack the Whip (* attack) - If the attack succeds, instead of making a normal damage roll, the target is slammed d6 " .....
Trip (* attack) - If the attack succeds, target model is knocked down. The attack does no damage.
Reach - 2" melee range.
e sad ja pitam, dal mogu da stekujem Crack the Whip / Trip sa Circular Strikeom? normalno je da ne mogu i crack the whip i trip u isto vreme, ali dal mogu uz circular strike? jer mi se tako chini da je to mnogo super fora... uletish u masu i pobacash ih sve u PM
Javice se kasnije neko od autoriteta, ali preliminarno mislim da nece moci dva special attack-a u krugu...
Ne. Samo jedan special attack, i on ti pojede sve osnovne.
znachi ne mozhe da circular strikuje i crack the whipuje one koje je udario? pih...
mada bi bilo skroz profi, bilo bi slichno kreosovom featu, samo na 2 incha
Koja je razlika izmedju Field Allowance C i Field Allowance 1 kada je solo u pitanju?
Poshto uzedeh dva paladina (obichnog i alt) al poshto mi kartica "obichnog" nije tu (a verujem da su iste), pretpostavljam da ih ne mogu obojcu voditi, zar ne?
ili je to neshto erratovano, poshto mi je Rick u vishe navrata rekao da mozhe tako... ?
