Spoilers...
Re: Spoilers...
Kaya FTW. I'm in love.
Re: Spoilers...
stanis je dojaja.....a i anastazija je cool, bash shpiunska poza,..nishta flashy :D
Re: Spoilers...
Noooooooooooooooooo!!!! Why, God, Why!?!?!?!?!lost the amulet and the scroll
Stoopid Privateer Press - World Ender my arse!
Re: Spoilers...
Steta sto anastazija ne radi za Khador,tj mrzi ga,bas bi mi lepo isla za advance deployment modele
Re: Spoilers...
Please also note :Quote:
His axe better be REAL good. On the other side, no more 2-fury-warlock jokes... :D :Dwe lost Guided Hand, Sure Foot, the Scroll, AND the Talisman... but kept Stone Fall.
- Resurrection
Re: Spoilers...
Niko nije primetio da Morgl ima spell za all terain?
- Resurrection
Re: Spoilers...
Uh, ove stvari su mnogo do jaja!!!
Ruski carobnjak je tako dobar! Must have!!!
I bice minion warlocka! Jeeeeeej! Ja sam sakupio sve minione sem Swamp Gobbera. Treba mi jos samo par blistera.
Re: Spoilers...
Izasla pravila za Epic Goreshadea i E Severiusa (neka nepotpuna, doduse). Fear him, o enemies of cryx, fear him!!!!
Goreshade
POW 15 attack
critical decapitation- my bad. they renamed it and i didnt notice
(*attack) if he passes command check, he rolls and addtional attack and damage die. models besides goreshade within 2" of hit model arestationary for a round. if he fail CMD check goreshade is stationary for a round.
elite cadre- bane thralls get a bane thrall when they destory a living enemy model.
terror
siphon
undead
spells
models in goreshades battlegroup have darkshroud and stealth
target model may see through EVERYTHING and may decalre charges without LOS
POW 13 attack. if u damage a model u may move it up to 3" and choose its facing
when someone casts a spell in his control area they take a damage point and he gains a health. when someone casts an animi same thing.
POW 13 AOE 3 models hit cannot cast spells or animi
a 2 focus upkeepable , offensiveable spell that makes a model not be able to make free strikes, and any model able to make it completely past its base. i mean i can see some sort of assasination run with this but, its not that usefull.
2 focus upkeepable
if a nonfriendly model ends its normal movement anywhere within 6 inches and line of sight, of a model that isnt engaged in a friendly cryx unit can charge the model , if u do charge, the guy that charge is removed from play and the unit under the spell ignores formation
feat
Goreshade may bring back one or more friendly cryx destroyed warrior model. for each model brough back, remove from play one friednly model. they may activate normally
I, NAPOKON, jedan warcaster koji smara sve SEM cryxa (bilo je i vreme, s obzirom na sav taj cryx hate koji je PP slao konstantno.). Inace, epic Sevy je beast i jebe ...vu, cak mi se cini da je potencijalno bolji od E Goreshadea, mada sumnjam....
Sevy
first of all his staff is the same attack.
his ranged weapon is range 8 POW 10 nd it may b channled through arc nodes
when sevy makes a melee or ranged attack d3 models with 5" suffer a POOW 10. (i said POW 8 before)
he has absolute authority
he has CMD 9 which is a command range of 18!
his warjack bond allows him to allocate an additional focus. Once per turn, when the warjack is hit by an attack, it may spend a focus to suffer no damage or effects from the attack
staff hasreach
his staff gets +1 to the damage roll for each fury on the model hit
Spells
1) call of the creator, Cost 1, range 8. target living enemy nonwarcaster/warlock warrior model makes a command check. if it fails sevy gains control of him and immidetaly makes one normal attack, then the spell expires
2)courage of faith, cost 2, range CTRL. friendly protectorate models do not suffer the effects of filed command checks. when a friendly protectoate model/unit passes a command check caused by an enemy, that model/unit may make one normal attack each
3)creators wrath, cost 2, range self. sevy gains and additonal die on melee attack and damge rolls. sevy may damage models ony affected by magic, sevy ignores spell effects that add to targets ARM or Def. sevy may chage incorpeal models.
4)fear of god, cost 2, range 8. target model/unit must pass a command check or forfeit is movement or action during its next activation. WHILE THIS SPELL REMAINS IN PLAY, AFFECTED MODELS CANNOT GIVE OR RECIEVE ORDERS.
5)hex breaker, cost 3, range 10, AOE 3, POW 13. models damaged by hex breaker cannot cast spells and loses it animus for one round
6) holy ward, target friendly gains +2DEF and cannotbe targeted by spells or animi.
7) immolation. we all know
8) light of truth. cost 3, range self, AOE CTRL. the front arc of friendly menoth warjacks in sevys control area extends 360 degrees/ affected models ignore intervening moels, cloud effets, and forests when determing LOS. light oftruth lasts one round.
Feat
either d3+3 undead models in sevys control area chosen by sevys controller suffer a POW 12 damge roll, or sevy takes control of d3+3 LIVING ENEMY NON-CHARACTER WARRIOR MODELS chosen by sevy in his control area. controlled models become friendly solos and may activate normally this turn. fires of communion lasts one turn.
i know were all disappointed with the feat but i still think he rocks hard.
Goreshade
POW 15 attack
terror
siphon
undead
spells
2 focus upkeepable
feat
Sevy
staff hasreach
Spells
Feat
Re: Spoilers...
Ej, bre drustvo, pa gde ste vi dosao GENCON, a vi nista ne gledate...
http://www.privateerpressforums.com/ind ... =0&start=0
Eto da se zabavite...
Re: Spoilers...
Cini mi se da je cryx dobio deblji deo motke... opet. Nakon klarifikacije egoreshadeovog feata, od njega se bas i ne ocekuje mnogo, a od legendi smo dobili... paaaa... blighted trollkine i njihovog soloa, i to je to. Nasi caracter jackovi smrduckaju poprilicno, a ostali uniti su ...meh. e, da, i nemamo caracter attachmente. Sa druge strane, od apsolutno spektakularnih stvari
Cygnar ima : Jeremiju (kao da im nije trebao JOS JEDAN superjack caster). Arcnod koji ignosrise intervening models i chaneluje iz melea, i moze da ode bez da mu se ista desi. Malog idiota za 18 poena koji posramljuje skarloka
Khador ima : Beast 09 koji je hands down najbolji jack u igri
Great bears, koji bi bilo bolje da kostaju 50 poena po modelu za to sto rade
Jos jednog glupog ciku na konju, koji sam ubije 523523 modela pre nego umre
Protectorat ima : Hierophanta!!! (jer njima stvarno, stvarno, stvarno treba jos jedan solo koji automatski ide u harbinger godmode...//sarcasam off)
Exemplar bastions : Ma daj... weapon masteri sa reachom, koji ako dodju do tebe sa punim healthom udaraju sangom 16, a gazda 19. I rasporedjuju rane medjusobno kako vole. I ne mozes ih knockdownowati...
I nadam se da ovo nije tacno... Honor guard "Unit models get +3 ARM, cumulative, for each other model in B2B.
Fearless "
A cryx dobija... blighted trollkine, piratski top i jos undead pirata... A, da i svi dobiju milion stvari koje povredjuju inkorporeale.
I da, coup de grace, solo koji , naravno, opet , nasilno maltretira primarno cryx - epic eyriss
Stvarno, stvarno, stvarno bih volep da se PP malo potrudi i da nama cryxianskim igracima izbor koji se ne svodi na : uzmi warcastera, skarlocka, deathjacka, pilice i popuni ostalo baneovima, mechanittralovima i bileovima. Jer je to , cini mi se, sve sto smo dobili za 5 knjiga. Vise nego kod ostalih frakcija, imamo onaj.... mnjh- rubbish bin osecaj.
Kukanje over :D :D :D
Fearless "
Re: Spoilers...
Pola od toga se nece ni videti kod nas.. (u stvari Rick ce uzeti sve za trolove, Bojan za Khador i Dalibor za Cygnar). Hmmm, pa eto racunaj da pola tih stvari za Menoth neces ni videti..... Uostalom WM je uvek insistirao na prejakim jedinicama, doduse za sve frakcije.
Mozda je ovo pokusaj a'la GW da pojaca prodaju neke frakcije, pa posto su malo zajebali stvari sa Gravusom i Heavy warjack karakterom, sada pokusavaju da promene situaciju, sa stvarno megajakim (i megaskupim u parama,pretpostavljam) jedinicama.
A posto Harbie loves gangbangs eto i Hierofanta
- PainBringer
Re: Spoilers...
Pa ni Cankerworm nije los...?
Re: Spoilers...
Ali zasto tako mislis?Bathory wrote:Pola od toga se nece ni videti kod nas..
Re: Spoilers...
Govorim u svoje ime, a ostali (tu pretezno mislim na mlade nade) nisu ni na 50% ofarbanih i skupljenih figura. Voleo bih da gresim, posto, istina, nisam neko vreme igrao pa ne znam kakvo je tacno stanje sada. Sto se mene tice, prvo cu morati da vidim modele, pa da odlucim....
Re: Spoilers...
Paaa sad, zavisi od funkcije.... na tabletopu je beskorisan, ali sam siguran da ima izvrsnu funkciju kao jako lep teg za papir...Pa ni Cankerworm nije los...?
Please. Gravus je odvratno-odvratan model, ali je ubica iz dimenzije x. A ako mislis da su vasi charater jackovi losi, baci pogled preko granice do cryxevaca... a onda svrati do kadora da vidis sta su beast 09 i Old Rowdy. A onda ofarbaj sve modele crveno i proglasi ih rusima.Gravusom i Heavy warjack karakterom
I sta nama undedima staje (osim ako blighted trollkini stvarno imaju rane, onda smo redeemed), osim povika : More banes, more nodes...? :? :?
Re: Spoilers...
POtpuno se slazem sa Duletom, kao da im je ponestalo volje da se pozabave sa undeadima, jer je cilj da malo promene vojske i nacine taktika, a ove neefikasne stvari kod Cryxa samo jos vise cementiraju vec oprobane liste...
No ono sto je jako dobro u ovome, je to sto te teraju da igras 750 poena bitke, skuplje stvari, vece opcije, pa samim tim i veci izbor, a i izazov...
- Resurrection
Re: Spoilers...
Pendargon wrote: ...
Ako nista drugo nemam razloga da kupujem gomilu novih stvari ako ne valjaju ič.
dinar ušteđen = dinar zarađen :D
And Lord Toruk had a dog, Bane Knight was his name-o!
@xclub:
Mislis, ne daju mi dovoljno opcija na 500 pa me ucenjuju da igram u vise poena?
Zasto bih igrao ono sto moram a ne ono sto zelim?
Re: Spoilers...
Ne na taj nacin Ress, nego uvode gomilu Epica, i uvode character jackove za imena, pa jos bolje idu uz neke epice...
Npr, Epic Seve i onaj njihov character jack...
A inace opcija je ionako previse, sada se mozes igrati ozbiljnih partija i u 350 poena...
Re: Spoilers...
vala, svidja mi se novi menothski solo
- Resurrection
Re: Spoilers...
Cryx in th closet:
Re: Spoilers...
Iskreno, bio sam spreman da poverujem Kosanovicu u njegovom lamentu dok nisam pogledao sve sto je izaslo.
Kriks je dobio najboljeg drakuna i najbolji karakter unit koji ce vrlo cesto videti polje. Uz njih meni se veoma dopada i Nightmare(heavy warjack sa stealthom, gostly i pray) mada bi njega vodio samo uz denegru.
Kador je dobio jednog korektnog cavalry solo - ne spektakularnog, cini se odlicnog mage soloa - nisu losi ruski jackovi ali ne rade nista sto Rusi vec ne rade odlicno.
Mnoge su jadikovke na ruskim i undead forumima ali tako i TREBA DA BUDE!
Ako realno pogledamo najveci procenat dobro plasiraih igraca na turnirima ima Khador zatim Kriks pa Menot i Signar - upravo obrnuto su deljena pojacanja za novu knjigu!
S druge strane menovorci ogrnuti medvedjim kozama...mmmm.... :D
Re: Spoilers...
Doznao sam da Medjedi zapravo nisu Man-o-warci, nego Iron Fangovi.
Nisam video figure (nisam siguran da postoje slike), video sam samo ilustraciju iz knjige, i to na snimku sa youtube-a...
Imaju valjda velike sikire.
I kako to da niko ne prica o fluff spoilerima?
[spoiler]Koleman je roknuo Hijerarha, Harbingerkinim macom (buduci da se ovaj ogresio o Menota, te je takva bila bozja volja), a Menotovci zamalo da osvoje Kaspiju...
Irusk je osvojio Nortgard, sacekavsi da Nemo ode a onda je bacio sve Ruse koje je mogao da skupi na njega.
Vlad neuspesno ratuje protiv Menotovaca u Laelu (jer mu je Irusk konfiskovao pola vojske), Orsus je poludeo i napao Felig, koji brane Ordovci i Gorten...[/spoiler]
I tako dalje i tako blize, svasta se nesto tu desava. Citajte PP forum.
- PainBringer
Re: Spoilers...
Karakteristike za Slag Troll-a, pravo sa PP foruma.
All stats are in relation to the Pyre troll.
SPD: same
STR: +1
MAT: same
RAT: same
DEF: -1
ARM: +2
Point cost: 70
As for the abilities:
Animus
Acidic Touch - Cost: 2, RNG: 6
When a non-living model hits the target, it suffers d6 damage points.
Abilites
Cast Iron Stomach - When Slag Troll destroys an elemental construct or warjack with a melee attack, it gains boosted melee dmg rolls for one round and may regenerate d6 dmg points.
Regeneration
Vitriol - Can be forced to gain Vitriol for one round. Non-Slag toll models that hit the Slag troll suffer corrosion.
Attacks
Spew Acid - RNG 8, ROF 2
Model hit suffers corrosion
Also, damage against non-living models gets and additional damage die.
Two Claw attacks, P+S = 13.
Ne znam za vas, ali meni ovaj trol ne deluje previse spektakularno. A i model je prilicno... ruzan. Spew acid deluje zanimljivo (posebno zbog ROF 2), ali da budem iskren, ocekivao sam nesto vise. Mislim da mu je upotreba prilicno ogranicena.
Pored ovoga, pojavio se novi solo za Everblight - Warmonger Warchief (do pre izvesnog vremena Cardinal): http://www.privateerpress.com/HORDES/ga ... ure&id=165
Solo mi se veoma dopada. Bas me interesuje kako izgleda "na papiru".
SPD: same
STR: +1
MAT: same
RAT: same
DEF: -1
ARM: +2
Point cost: 70
Animus
Abilites
Regeneration
Attacks
Re: Spoilers...
Jos jedan model koji maltretira Cryx
Re: Spoilers...
Pa nije samo Cryx, svaki jack ce da ima problem sa njim. Roknes ga u bilo koju tournament listu i siguran si da ce se isplatiti.
Re: Spoilers...
Tournament lista + close combat jack koji nije deathjack (a i on se ne racuna...)...?
c,c,c,...
(znam najgori sam) :D :D
c,c,c,...
Re: Spoilers...
Mi iz Hordes zadruge ipak imamo malo drugacije stanje stvari :P
(pravimo se da Warmachine ne postoji kada racunamo konacna mesta, posto od njih i onako uvek izgubimo :D )
- PainBringer
Re: Spoilers...
Ma kakvi. Osobine su mu takve da retko kome moze predtavljati veliki problem. Uostalom, ako ikome bude smetao, sredice ga i... gotovo. Problem sa ovim modelom je u tome sto treba da radi odredjenu stvar, ali je ne radi dovoljno dobro (bar se meni cini da je tako). Troll Impaler i Pyre Troll su i dalje bolji izbor od ovog malise. a i model je ruzan (znam, ponavljm se).Dawngreeter wrote:Pa nije samo Cryx, svaki jack ce da ima problem sa njim. Roknes ga u bilo koju tournament listu i siguran si da ce se isplatiti.
Re: Spoilers...
ak znas da igras protiv cryxa, uvek bih pre uzeo ovog momka od pyre trolla. Mozda i u normalnim listama, kao 4-og warbeasta. On je baja koji se ne da ubiti infantrijem, ili cak i ako ga ubiju, povuci ce 2/3 jedinice sa sobom.
Edit: I see Rick lurking... :D :D :D 8) 8) 8)
Re: Spoilers...
Just reading NQ#19 and the eWarlocks.
I'm not sure about Madrak. He's still a combat monster but has to be played much more tactically. Morghoul, Kaya and Lylyth are A LOT better than their previous incarnations, though Lylyth seems like an overpowered solo rather than a Warlock. Reminds me of Caine.
Morghoul and Kaya really change the method of play for Skorne and Orboros and I'm sure there will be ways of using Kaya and Laris which will raise the cries of broken again for Orboros. Warpwolves are this Autumn's black and Woldwarden's are no longer in fashion.
I still really don't get "World Ender" though. Grim would still kick his ass.
Re: Spoilers...
"World Ender" is the name of his axe, if I remember correctly.
Re: Spoilers...
Arhhh is it? - The Kriels have given Madrak the name now. His axe is also called that but the name by this point has transferred to him. My comment is "World Ender" is a bit strong for a fury 5 Warlock with 3 crap spells and rather situational abilities.Shunka wrote:"World Ender" is the name of his axe, if I remember correctly.
Good news on metamorphosis; not only eWarlocks but also new Warlocks, character warbeasts, dragoons etc. It is pretty much Legends for Hordes, which is a mixed benefit as if it followed Apotheosis there'd be 2 eWarlocks, and Unique warbeast and that would be excellent as well.
Re: Spoilers...
Svasta moze isplivati na PP forumu...Its a long story.... The Summary: Their was a Girl last year that dressed up as Eiryss, she gave a link to her picture site. The List of pictures contained many pictures of anime cons/gaming cons cosplays. It also had a 2 pictures of her Topless.
She apparently hadn't realized this... and got rather annoyed when people made mention of it.
- Resurrection
Re: Spoilers...
Malo detalja:
Bloodgorger Unit
Stats are +/- to a Bane Thrall
Speed - Same
Strength - Same
Mat - Same (On leader/trooper)
Rat - Who cares?
Def - Same
Arm - Same
2 Weapons, a) Equal to Bane Thrall b) -2 Bane Thrall Axe
They are 10 points cheaper than Bane Thralls, 4 more than Knights.
They have a charge order that lets them deal w/ rough terrain but still suffer movement penalties.
When they destroy a living enemy model, mark a Blood Mark on the card.
Blood Marks;
- 2 Marks = 4,5,6 Tough
- 4 Marks = +2 Spd, and Weaponmaster
- 8 Marks = Hey I destroyed something I get to move 3 inches, but stay in formation
Yay, were not fearful.
Gang = +2 attack and damage cuase your engaged by another model in my unit.
Gerlak Slaughterborn
Speed - Same
Strength - +1
Mat - +1 (Comparing to Bane Thrall Leader).
Rat - Who cares?
Def - Same
Arm - +2
Reach, Flying steel, +2 on his Great Axe when comparing to a Bane Thrall axe.
4 points less than Tartarus
Has a charge that lets him deal w/ rough terrain but still suffer movement penalties.
Slaughterborn kills living enemy models, mark a Blood Mark on his card, he gains +1 STR / ARM for each one marked (Max 5)
Commander, same as Rengrave
He gains all abilities from Blood Marks from Bloodgorgers in his command range.
He is a terrifying entity
Bloodgorger Unit
Speed - Same
Strength - Same
Rat - Who cares?
Def - Same
Arm - Same
Blood Marks;
Speed - Same
Strength - +1
Rat - Who cares?
Def - Same
Arm - +2
- arborsomniorum
Re: Spoilers...
Nije mi samo jasno zasto su ubacili undead trolove, kao da im nije dosta gluposti palo na pamet?
Re: Spoilers...
ovo nije tacno, a i nema smisla. Kostaju 12 poena (za nas ne vaze, nadam se, PP konvencije o street dateu i statistikama, obrisacu ako me Rick opomene)They are 10 points cheaper than Bane Thralls, 4 more than Knights.
4 marks +2 spd- 4 Marks = +2 Spd, and Weaponmaster
6 mrks - weapon master
but we are fearLESS :DYay, were not fearful.
but still no weaponmaster... idiot trolls, unable to master their axes... :lol: :lol:Reach, Flying steel, +2 on his Great Axe when comparing to a Bane Thrall axe
edit posto sam video novi post) trollovi nisu undead, vec su zivi, samo blighted
- arborsomniorum
Re: Spoilers...
To mi je i dalje onako, malo gej, mislim imam dosta Cryxa, nisam siguran da bih kupio trolove koji su zaslepljeni,Pendargon wrote:trollovi nisu undead, vec su zivi, samo blighted
i ako su blighted sto nisu kod legije?
- Resurrection
Re: Spoilers...
Mislim da se to odnosi na cenu jedinice od 6 komada.Pendargon wrote:ovo nije tacno, a i nema smisla. Kostaju 12 poena (za nas ne vaze, nadam se, PP konvencije o street dateu i statistikama, obrisacu ako me Rick opomene)They are 10 points cheaper than Bane Thralls, 4 more than Knights.
Kako covek da poslaze 10 medium-based modela po tabli pored ostalih nezivih stitova?
