"Honoured Imperium" Warhammer 40.000 Tournament- 24-25. Maj
Full Rulespack v1.0:
https://docs.google.com/file/d/0B8VDc53 ... dvMUU/edit
*Rulespack ce biti blagovremeno update-ovan kako budu izlazili novi Codexi, Dataslateovi i ostali Supplementi.
Re: "Honoured Imperium" Warhammer 40.000 Tournament- 24-25.
Zeleli bi da podsetimo sve zainteresovane da je ostalo jos malo manje od mesec dana za prijave! :)
Da otvorimo sezonu onda?
Prijava, Tyranids.
Ostalo je jos 2.5 nedelje za prijave... entuzijazam na zavidnom nivou.
Dobro me podseti...
Verovatno neka varijacija sa Čika Cassius-om i drugarima...
:twisted: :twisted: :twisted:
u pravu si. Prijava
u rulespacku u force organisation chartu stoje recimo formacije, ali u pravilima pise da nema dodatnih knjiga tipa escalation i sl. znaci, ne mogu formacije da se vode?
Prijava!!
Zamolio bih sve zainteresovane da pogledaju Rulespack.
Prijave funkcionisu na sledeci nacin:
++REGISTRATION++
• You can register for the WARHAMMER 40.000 TOURNAMENT by sending an e-mail with the subject "40K TOURNAMENT REGISTRATION" to the following email address: [email protected]
• All registrations must be sent till May 14th, 2014.
• Please include your full name, as well the 40K army list you'll be bringing to the tournament, so our referee could verify that list is legal.
• Army lists should be submitted in the format presented at the end of this Rulespack, or in the 3.2 Armybuilder file.
• All accepted lists will be published on May 17th at http://forum.klubzmaj.org/viewforum.php?f=7, and our FB page: https://www.facebook.com/KlubLjubitelja ... astikeZmaj
@Joggy: Formacije su Dataslates, i dozvoljeni su samo oni koji su navedeni u Rulespacku.
FoC na kraju Rulespack-a dat je samo kako biste imali uvid kako to sve zajedno izgleda, i kako se ponasaju oni Codex-i koji se "dodatno" mogu ukljuciti kao saveznici, poput Inquisition i Legion of the Damned.
Tu stoji i Lords of War slot, ali on nije dozvoljen.
Hvala. :)
Ota
Post by Ota »
Prijava.
Djenrale uzalud te traze,
cuvaju te sve bozije straze.
Tek sam sad provalio da se nisam prijavio.
dakle, primera radi, dozvoljena je formacija koja se nalazi u knjizi militarum tempestus?
Bice update-ovan Rulespack koji ce sadrzati tu informaciju u narednih 2-3 dana.
Ali nacelno, ne vidim zasto ne bi bila. :)
Generalno gledano, dok god nije "apocalypse formation", formacije iz knjiga koje su na spisku u rulespacku su dozvoljene.
Za sad:
1. Dusan Vasic SW/GK
2. Nemanja Dojkic CD/CSM
3. Predrag Vasiljevic Tyranids
4. Igor Uzelac Farsight/Eldar
5. Dejan Milinovic Space Marines
6. Nikola Nikolic - Nije poslao listu
7. Miljan Otovic - Nije poslao listu
8. Nenad Nikolic - Nije poslao listu
9. Bojan Kavedzic - Nije poslao listu
10.
Hajmo reprezentativci - prijavljujte se mailom za turnir! Nemoj da vas nema. :)
Prijave, neka kombinacija Garde, Sisterki i Inkvizicije.
Za sad:
1. Dimitrije Stevanovic - Dark Eldar
10.Predrag Urosevic - Nije prdeao listu
11.Milan Popovic - Tau Empire/Farsight
12.
Sudeci po tome da je ostalo jos 8 dana za prijavljivanje i slanje listi, nesto nisam optimistican :/
Dellamorte
Post by Dellamorte »
Prijava :) Dimitrije Stevanovic javim u dogledno vreme da li cu igrati sa BA ili DE
CheMilan
Post by CheMilan »
Prijava :)
...pa i nisi bas najbolji...
Prijava.
Za sad:
12.
Posto na turnir nece doci stranci bice pomeren za 31.05-01.06 jer tako dobijamo jos 4 igraca sigurno a mozda izgubimo jednog.
Ja ne mogu 31.
Ni ja ne mogu 31.. Cim je izasla najava na za turnir, ja sam trazio da te da ne ne radim da bih mogao ucestvovati.. i zato vikend posle (31/1) radim..
Ok. Jos ovo nije definitivno.
+++CANCELED+++
Usled nedovoljne zainteresovanosti, turnir "Honoured Imperium" se otkazuje.
Izvinjavamo se svima koji su se prijavili i odvojili svoje slobodno vreme za taj vikend.
Kao simbolicna nadoknada, bice organizovan Mini turnir u nedelju, 25. maja. Poentaza ostaje ista, ofarbanost nije obavezna, ali WYSIWYG jeste. Igrace se 3 bitke i ucesce se placa 200 dinara. SVI su dobrodosli, prijave unapred nisu potrebne.
Hvala svima.
P.S. Klub Zmaj vise nece organizovati "velike" WH40k turnire, dok zajednica ne pokaze dovoljnu kolicinu zainteresovanosti. Do tada, bice organizovani samo Mini turniri na svaka 2-3 meseca.
EDIT by Megabaja:
Mrzimsvee wrote:Mini turnir "Zbogom sesta edicijo!", nedelja 25.05., pocetak u 12h, 3 bitke, ucesce 200din, nista ne mora da bude ofarbano, WYSIWYG je pozeljan, max 20 ucesnika. Prijave ovde.
