Age of Sigmar turnir na festivalu epske fantastike 19.09.
Drugari na festivalu epske fantastike u Domu omladine u subotu 19.09.2015. odrzace se turnir u Age of Sigmar igri.
Pravila za pravljenje vojske i po kojima ce se igrati razlikuju se od originalnih i mozete ih naci na ovom linku:
http://www.docdroid.net/20f5WZr/aos-pla ... k.pdf.html
sa sledecim izmenama na ova pravila :siren: :
Igra se u 1500pts
ERRATA
Page 2 - BATTLE ROUNDS
Remove Initiative from the Game.
Page 3 - COMMAND ABILITY
Change the section to read:
In your hero phase, your general can use one
command ability. All generals have the Inspiring
Presence command ability, which they may
use any number of times per battle. If they
have one, your general may use each printed
command ability on their Warscroll once per
game.
Page 4 - PICKING TARGETS
Add the following section:
If the attack is being made with a Ranged
Weapon in the Shooting phase additional
requirements apply:
Units with any models engaged with enemies
(within 3” of an enemy model) may
not perform shooting attacks in the shooting
phase. Special Rules which specifically allow
for Shooting Attacks to be made in the Combat
Phase (such as the Skull Cannons’ Grind their
Bones, Seize their Skulls ability) circumvent
this limitation.
When targeting an enemy unit with models engaged
with allied models, only those which are
greater than 3” of an allied model are eligible to
take Wounds. These models must be the closest
to the firing unit, who cannot shoot through allied
models. When assigning the Wound Pool,
should the closest model to the firing unit be
within 3” of an ally, or be an ally, all remaining
Wounds are discounted and the attack ends
Look Out Sir!: Hero models without the
Monster keyword within 3” of an allied unit
cannot be targeted by ranged attacks unless
they are the closest model to the firing unit.
When attacked by a ranged attack and spells, after rolling
to wound, but before making saves of any kind,
the Hero may make a Look out Sir! Roll. On a
4+ an allied unit within 3” (who is not engaged
in close combat) immediately takes any saves
they are required to take as though
Ucesce je 500din(za nagradni fond) + cena ulaznice.
Igra se 5 rundi u svakoj ce biti jedan od 3 scenarija:
http://www.fantasiaspel.se/Fantasia/Age ... narios.pdf
Okupljanje od 11h
Prva runda od 11:30h do 12:30h
Druga runda od 12:45 do 13:45h
Pauza za rucak od 13:45h do 15:00h
Treca runda od 15:00h do 16:00h
Cetvrta runda od 16:15h do 17:15h
Peta runda od 17:30 do 18:30h
Proglasenje pobednika u 19:00h
Ako imate neka pitanja postavite ih ovde.
Prijave isto na ovoj temi ili na nasoj stranici na Facebok-u.
Vase liste treba poslati na email: [email protected] do 17.09.
Hvala unapred.
Re: Age of Sigmar turnir na festivalu epske fantastike 19.09.
Baze mogu okrugle i kvadratne, kao i mesano? Se gleda ofarbanost vojske?
Kako ide bodovanje, za pobedu odredjen broj u slucaju istog rezultata na kraju ko je imao vecu razliku u victory poenima?
p.s. Prijava - Tomb Kings :)
Baze nisu bitne ali moras da ih imas. Ne gleda se ofarbanost vojske.
Za pobedu 20pts, i poraz 10pt. Pogledaj scenarije kako se pobedjuje u bitkama.
ja bih samo predlozio da se umesto ova 3 uzmu pet scenarija iz steamrollera. Ovi na netu nisu smeli to da bukvalno prekopiraju zbog copyright-a, ali mislim da nas nista ne sprecava da se igra po tome
joggy wrote:ja bih samo predlozio da se umesto ova 3 uzmu pet scenarija iz steamrollera. Ovi na netu nisu smeli to da bukvalno prekopiraju zbog copyright-a, ali mislim da nas nista ne sprecava da se igra po tome
Posalji mi link
Fala
eh da takodje sam video u nekoj errati na turnirima ona silly pravila rade na 5+ umesto da se kreveljis
A ja počeo da puštam bradu :wink:
joggy wrote:eh da takodje sam video u nekoj errati na turnirima ona silly pravila rade na 5+ umesto da se kreveljis
Bolje neka ostane na tome da se kreveljis :grin: :grin: :grin:
joggy wrote:... ona silly pravila...
To su neka Pvastevinkova pravila :?: :?: :?:
PfcParatrooper
Post by PfcParatrooper »
Moje je misljenje da ta pravila treba da rade automatski samo je objasnjenje postavljeno u saljivom kontekstu...
Prijava - Bretonci.
PfcParatrooper wrote:Moje je misljenje da ta pravila treba da rade automatski samo je objasnjenje postavljeno u saljivom kontekstu...
Bravo, upravo tako. ;)
Drugari jel mogu neke prijave za ovo ili da otkazujemo?
Dorian
Post by Dorian »
Prijava!
Mislio sam da sam se vec prijavio, ali izgleda da je to bilo samo za 40k.
Woody Allen
prijava
Znaci ovako:
1. Igor
2. Zerg
3. No1
4. Dorian
5. Nikola
6. Bojan D.
7. Pera
8. Wyrus
9. Boldrik
10. Lasica?
11.
Prijava.
BoldrikBoldrik
Post by BoldrikBoldrik »
Prijava- Woodstock vilenjaci.
BoldrikBoldrik
Jedno pitanje: pošto u AoS moš voditi kombinovane armije bez nekih penala (koliko shvatam), da li za ovaj turnir armije moraju biti čiste ili bih, na primer, mogao da ubacim nešto od drugarovih dark elfova?
Mozes I da mesas.
Wyrus
Post by Wyrus »
Prijava - Orci
Jel može neki izveštaj sa AoS turnira, utisci, igrivost, itd....
Joggy?
