INFINITY - PRAVILA
INFINITY - PRAVILA
EDIT
PRAVILA ZA INFINITI, DOTERANA, ISPOLIRANA, PRILAGODJENA ENGLESKOM GOVORNOM PODRUCJU
http://members.iinet.com.au/~tenabrae/i ... ty2_2b.pdf
Ubacena su sva pravila iz obe knjige.
Navali narode :wink:
EDIT
Evo jedne stvarcice koju do sada nismo igrali po pravilima. Kada figura postane unconcious, automatski dobija prone marker. Zbog toga, posle lecenja, mora prvo da potrosi kratku akciju da bi ustala, pa onda moze dalje. Naravno, moze da ostane prone i da puzi okolo :D
Re: INFINITY - PRAVILA
ova Human Sphere knjiga šta mu to tačno dođe?
To je druga knjiga za Infinity - nove jedinice, sektorianske liste, nova pravila, i citava gomila novog flafa :) Sve osim flafa imate na linkovima
Izasla pravila prilagodjena Engleskom govornom podrucju (manje flafa u samim pravilima i drugacije grupisana) koja ukljucuju obe knjige. Za link pogledaj prvi post.
PS U neko doba ovaj topic ce postati sticky
Za one koji znaju "2 ediciju" :twisted: , evo kako rade mine:
Mines are variable Template Weapons which can
use a Circular Template or Small Teardrop Template, as
the player prefers during the game. They are activated by
proximity, by any enemy miniature or Marker penetrating
or acting in the radius of the Circular Template or in the
equivalent radius of the Small Teardrop Template, but
they act only in the Template area.
Ili pojasnjeno u Q&A:
Q: Does a Mine Explode if a model moves in its Area of Effect because of a failed Guts Roll?
A: Yes. As said by the rules, Mines are activated by the declaration of an Order or ARO but also by
any enemy figure that penetrates in its Area of Effect
Q: How can I exactly manage the use of the different templates when playing with the Mines?
A: OK, letʼs see an example:
1- Player A activates with an Order a model inside the area of effect of the Teardrop Template of
Player Bʼs Mine.
2- Player B decides to wait and donʼt make explode the Mine.
3- Next Order of the Player A, this miniature is activated again inside the area of effect of the
Teardrop Template of Player Bʼs Mine.
4- Again, the Player B decides to wait and donʼt make explode the Mine.
5- New and different Order of the Player A, the figure enters the area of effect of the Circular
6- Player B decides to make explode the Mine using the Circular Template.
Ili na srpskom:
Mina se aktivira kad neku udje u njeno podrucje ili korosti ARO u istom. Kad se aktivira, vlasnik moze da odluci dali hoce da eksplodira ili ne. 8-)
Pogresio sam, lako se zaborave pravila kada ih jedini citas. A ti si dragi moj daleko od znalca. :lol:
Return to “Infinity”
