Fellow gamers,
in the light of the upcoming ETC 2017 event, I'm opening this topic so that we could present & evaluate our possible lists, as well as rules that follow them.
To kick off this thread, I'll present my Necron list. My army is yet to be built, thereforE all alterations are possible.
+ PLAYER: Mladojko
+ ARMY (Factions used): Necrons
+ TOTAL ARMY POINTS: 1845 pts
== Primary detachment: Necron Combined Arms Detachment == [900pts]
HQ1: Illuminor Szeras [110] - WARLORD
HQ2: Cryptek [65pts] The Veil of Darkness [25pts] = [90]
TROOPS 1: 5 Immortals [85], gauss
TROOPS 2: 5 Immortals [85], gauss
TROOPS 3: 5 Immortals [85], gauss
TROOPS 4: 5 Immortals [85], gauss
ELITE 1: 10 Deathmarks [180]
ELITE 2: 10 Deathmarks [180]
== Secondary detachment: Codex: Necron, Formation Detachment, Judicator Battalion == [945pts]
FA1: 10x Triarch Praetorian (280pts), Rod of Covenant, TRANSPORT1
FA2: 10x Triarch Praetorian (280pts), Rod of Covenant, TRANSPORT2
HS1:Triarch Stalker [125pts]
TRANSPORT1: Night Scythe [130pts]
TRANSPORT2: Night Scythe [130pts]
[ETC 2017] List Discussion
Re: [ETC 2017] Team Serbia List Discussion
E ovako da konacno napisem nesto, nikako da stignem. Prvo ne znam sta radi formacija, drugo mi pretorijance nikad nismo videli na tabli (bar ja), kazu ljudi da rade :D
Drugo mislim da si generalno prespor.
Trece svidja mi se sto imas avione mislim da su oni dobri i da ne treba vise od dva a uvek ce isplatiti poene i bas mogu takticki da budu neprijatni
Cetvrto mislim da treba da probas ako mozes na brodu do jaja ako ne kad se vrnes ionako ti volis da skupljas sve modele
Peto mislim da dve liste koje rade idalje su wraithwing sa max 15 wraithova ali sacekaj pre nabavke modela jer rulespack glasanje je sad do 22 pa da vidimo da li ces moci da ponavljas canpotek harvest vise od jednom, a druga lista je sa starom koji ne moze da umre sa svim karakterima i 6 wraithova
Sesto i najbitinije obrati paznju na njihove bike ove mislim da su bas bas jaki i da ti oni dosta trebaju pogotovu sto ce se misije vise igrati na kartice
Da, vidis, nisam objasnio sta radi formacija.
Znaci, formacija daje 'target aquired' pravilo. Svi modeli iz formacije dobijaju reroll To hit & To Wound / Armor Pen protiv jedne izabrane neprijateljske jedinice (ili modela) koja je u "line of sight" Triarch Stalkera na pocetku muvmenta. Ovo je simpatichno zbog aviona. Pretorijanci, sa dva karaktera koji im dizu reanimaciju na 4+ (jer bolje ne moze) imaju dobru shansu da maltretiraju protivnika tokom cele partije.
Deathmarkovi su tu da ulaze sa protivnickim dip srajkom. Da li ce odmah pucati po jedinici koja je usla, ili se skloniti negde zavisi od partije do partije.
Razmishljao sam i o Tomb Blade-ovima, kao i o Wraight-ovima. Neki CAD sa puno Blejdova i Distrojerima. Jedino sto mi tu smeta jesu misije koje dobijaju ekstra poene za fast & heavy jedinice. To mi je nauk od 'ovogodishnjih' turnira, jer mi se vojska sastojala mahom od FA i HS jedinica.
VIdecemo kako ce razresiti glasanja, pa cemo listu uchiniti smrtonosnijom.
Hvala za kritiku i sugestije.
I da naravno destroyer cult je dosta dobar isto cisto da znas :D
To imam!RatGod wrote:I da naravno destroyer cult je dosta dobar isto cisto da znas :D
Kakve su vesti sa glasanja? Sta sme, sta ne?
MIslim da se gubi cela poenta pravila formacije kada ti neko ubije tog jednog Triarch stalkera na pocetku - a mislim da hoce.
Kao sto luka kaze, dosta ce zavisiti od novog rules pack-a. Mislim da ce dobitna kombinacija biti jedan unit wraithova sa 4-5 karaktera i 2-3 unita bajkova. Ostalo popuniti po zelji.
Re: [ETC 2017] List Discussion
One can field a CAD and a Decurion Type Detachment or a Formation from the same faction within a given roster. None of those Detachments may be duplicated however, except when they are part of a Decurion or Craftworld Warhost type Detachment, in which case they may not be duplicated outside of said Detachments.
- U prevodu, jedna formacija sa isim imenom.
U svakom slucaju, ja i dalje radim na potencijalnim listama. Pokusavam da napravim lisu sa Royal Court i CAD, kako bi svaki HQ imao svoj bataljon. Za sada mi neuspeva. Nego...
Da vam pokazem cisti CAD. 24" threat range, sa JAKO puno pucanja. I Warrior-ima koje Barze popravljaju svaki krug i samo dodaju na tabli.
Dajte komentare.
+ PLAYER: Mladojko
+ TOTAL ARMY POINTS: 1850 pts
== Primary detachment: Necron Combined Arms Detachment == [1850pts]
HQ1: Catacomb Command Barge [135pts], Phase Shifter (25pts), Phylactery (15pts), Resurrection Orb (25pts), Voidreaper (30pts) = [230] - WARLORD
HQ2: Catacomb Command Barge [135pts], Phase Shifter (25pts), Phylactery (15pts), Resurrection Orb (25pts), Staff of Light = [200]
TROOPS 1: 10 Warriors [130], Transport 1
TROOPS 2: 10 Warriors [130], Transport 2
TROOPS 3: 10 Warriors [130], Transport 3
TROOPS 4: 10 Warriors [130], Transport 4
HS 1: Doomsday Ark [170]
HS 2: Doomsday Ark [170]
HS 3: Doomsday Ark [170]
TRANSPORT1: Ghost Ark [105pts]
TRANSPORT2: Ghost Ark [105pts]
TRANSPORT3: Ghost Ark [105pts]
TRANSPORT4: Ghost Ark [105pts]
Dajte komentare.
+ PLAYER: Mladojko
