9th Age
Moderator: teclis
kgkid
9th Age
Post by kgkid »
Pozdrav, društvo!
pošto nema više WHFB dela na kom bi se pisalo, pretpostavljam da je ova tema za pod "ostalo".
Ekipa koja radi deveto doba zamolila me je da na nacionalnim forumima podelim ovaj poziv:
Tiny wrote:Dear players
The way work is done on the 9th Age is very different to what many gamers have been used to in the past. So we are compelled to give a few explanations to ensure understanding with the community, for whom we are doing this.
The 9th Age is currently in, what is known in the gaming industry as, pre-beta testing stage, and will soon enter the beta testing stage once the army book development teams get selected.
The current stage in the development of the game is a period when the product is almost always kept from the scrutiny of the public and these initial drafts are always prone to sudden changes. In contrast to most game developing projects we have decided to keep the public in the loop from the very begining, and it is this process that you are currently observing and participating in.
During this initial period before the beta army documents are drafted the imput of the community is valuable as a failsafe mechanism. All input is appreciated but the one optained through playtesting carries greater weight. Here we depend upon you as the community to help us out in the playtesting process (to suplement our own internal playtesting) so that we may produce the best game possible.
The current TAC document is here to provide a stop gap measure that allows players to play with their models in the 9th Age and is far from a finished product. In addition the TAC army lists will serve as a skeleton for the initial drafts for the future army books. Currently the TAC lists lack certain rules players have been acustomed to, due to streamlining. Most if not all of these will return in one form or another in the army books.
So we ask the community to help us out by testing the drafts we present you. Also don't be alarmed if you playtested an earlier version of the document, as this will also provide us with valuable information, showing us if the change made was validated or not.
At the moment we are focusing on the units far more than one characters because the latter are easier to balance, in order to help us out we would like to ask you if you could play with more units than usual in your games. When selecting army lists for you playtest games we would be thankful if you would take only the necessary characters and focus on the meat of the army, which is the units. Also through current playtesting it has been shown that the army size of 2000 points is best suited for testing units, since at that size of the game it is easier to notice if a certain unit is weaker or stronger than it should be compared to its cost. That said we are not telling you to not play your average sized games (at whatever points size they may be) as different sizes of the game are prone to providing different data. For the moment we are focused on balancing our game in the 2000-2999 point range which is an average game that would take an evening to play and is most often encountered in tournaments.
What is important is that you report your experiences from these games so that we may have appropriate data needed to produce a quality product for the benefit of all. So please remember all of this will be very hard to achieve without you, the playtesters.
As a final note we would like to thank you on all the feedback, and help you have already provided, and invite you to continue on this game developing journey with us.
The 9th Age team
Hvala unapred i ako ima ikakvih spornih pitanja, javite se!
Link za forum devetog doba:
http://www.the-ninth-age.com/
Re: 9th Age
Procitao sam pravila za magije podrobno, i same magije ovlas. Koliko ja vidim, magija je i dalje prejaka i presudan faktor u bitkama, posto same magije nisu bitno izmenjene. ok, koliko vidim purple sun dozvoljava ward save, nije misfire na 1 nego na 6 tako da je domet manji malo, neke magije imaju veci casting value sto je nebitno jer ono sto ti je vazno ces prebaciti za mnogo. Medjutim posto caster moze i dalje da baca magije i kada ne uspe magiju, samo ne dodaje svoj nivo na cast, to manje vise ponistava sve te penale. Tako da je ponovo neigrivo bez maga cetvrtog nivoa (osim u slucaju da nemas skroz pucacku armiju), a slucaju da obojca imaju po maga cetvrtog nivoa, onda odprilike odlucuje ko ce pre da baci najjacu magiju.
kgkid
Re: 9th Age
Post by kgkid »
Magija jeste jaka, ali je oslabljena malo.
Dispel je pojacan znatno. Sada se krene od nivoa maga koji dispel radi i doda se +1 za svakog maga koji pomaze.
IF je sada samo dodatak na kasting vrednost, nije automatski prolazak. Moze da se dispeluje skrolom, ili nesto.
Magija je jedan od glavnih predmeta ove runde testiranja. Prikupljanjem rezultata ide se ka proceni snage ne samo magija, vec i raznih armija u upotrebi magija i dispelovanju.
Proces je na svom pocetku i treba ocekivati dodatne korekcije. Ideja tima za pravila je da magija bude bitan element, ali da ne bude jaka kao u osmoj ediciji, da ne bude jedan karakter u stanju da presudi partiju sa par uspesnih magija, nakon sto mu je cela armija zbrisana.
Re: 9th Age
Evo ja cu svoje misljenje o ovom sistemu (i njemu slicnim - nemam ama bas nista protiv njega posebno) predstaviti na malo drugaciji nacin: koliko onih koji se kunu u taj novi sistem (/te nove sisteme) je spremno da otkupi moju imperijalnu armiju (od cirka 10.000 poena, plus/minus nesto) po 50% off sa GW sajta?
Toliko od mene.
kgkid
Re: 9th Age
Post by kgkid »
Ne kunem se u taj sistem. U razvoj sam se uključio zato što mi se u startu nije svideo. Dobro je što sam kroz rad kao Army Support sagledao ideje razvojnog tima, što su mi se svidele i što sam se uverio da svaku sugestiju ozbiljno razmotre i pokušaju da implementiraju.
Nemam parice trenutno, inače bih rado otkupio svih 10k poena. ;)
Re: 9th Age
Dzon Vejn wrote:Evo ja cu svoje misljenje o ovom sistemu (i njemu slicnim - nemam ama bas nista protiv njega posebno) predstaviti na malo drugaciji nacin: koliko onih koji se kunu u taj novi sistem (/te nove sisteme) je spremno da otkupi moju imperijalnu armiju (od cirka 10.000 poena, plus/minus nesto) po 50% off sa GW sajta?
Toliko od mene.
I bid 20% :grin: O:)
Re: 9th Age
To je vise nego sto ce ostali ponuditi ;).
Re: 9th Age
Dzon Vejn wrote:To je vise nego sto ce ostali ponuditi ;).
Da, nazalost. :(
Re: 9th Age
Pazi Igore imam ja dve armije koje prodajem za 60% off
Re: 9th Age
Kada dodje do onih 20% ili ti 80% off GW cene mozemo pricamo :D
kgkid
Re: 9th Age
Post by kgkid »
Pozdrav,
Tim iza devetog doba vas moli i poziva da, ako imate volje, podelite sa njima i date im na upotrebu slike svojih minijatura, kako bi ih koristili u promociji igre.
Skupljaju se slike minijatura koje odgovaraju različitim jedinicama/modelima u igri. Ukoliko ste voljni, sve što treba da uradite je da se ulogujete na forum devetog doba i aploudujete svoje slike u galeriju:
http://www.the-ninth-age.com/gallery/in ... -holds-dh/
Ne znam da li postoji potencijal za samopromociju...
