FAQ - errata - clarification
We need clarification on the following matter.
A psyker, while being inside unit #1, at the start of movement phase, casts invisibility spell from telepathy. So both he and his unit are invisible. Later on, during his movement phase, he joins another unit - unit #2.
While under effect of "invisible", he has shrouded and stealth special rules. Both of those rules state that "A unit that contains at least one model with this special rule...".
Rules for Independent Characters and Ongoing Effects say:
Sometimes, a unit that an Independent Chatacter has joined will be the target of a beneficial or harmful effect, such as those bestowed by the Blind special rule, for example. If the character leaves the unit, both he and the unit continue to be affected by the effect, so you'll need to mark the character accordingly.
Conversely, if a character joins a unit after that unit has been the target of an ongoing effect (or joins a unit after himself having been the target of an ongoing effect) benefits and penalties from that effect are not shared.
The clear part is that WS1 is not shared on unit #2. However, we have disagreements whether shrouded and stealth are applied to unit #2 (due to the "if at least one model..."), or not (due to "benefits and penalties from that (ongoing) effect are not shared").
Thanks!
Re: FAQ - errata - clarification
Ja cu sad postaviti ovo pitanje.
Ljudi koji rade ETC FAQ kažu da je kako mislimo Nenad, Nikola i ja.
Što naravno ne znaci da je to ispravno, ni mi nismo to ni znali nego smo videli na ETC-u.
Mogu samo da dodam da i ja mislim da tvorac tog powera nije hteo da on tako radi, ali wording je wording.
Hvala.
pitacu ja i na Bols-u.
Na kraju krajeva, kako god da su odlucili, bitno je da se zna sta vazi.
Rekao sam ti kako je.........
Jako bitna stvar iz novog rulespacka :
8. Special rules or abilities that automatically affect enemy units and are not strictly speaking a
weapon or an attack (e.g. Tesla Arc, Objuration Mechanicum psychic power or Njal’s Lord of
Tempests special rules) do affect Zooming Flyers and Swooping Flying Monstrous Creatures.
Poslednja strana serpent shield arc :lol:
moje pitanje je - do kada ce tako da menjaju rulspek? ima li na vidiku konacne verzije?
Trebalo bi da je ovo konacna verzija
http://klubzmaj.org/forum/viewtopic.php ... cf#p174283
RatGod wrote:Poslednja strana serpent shield arc :lol:
Ja taj grafik ne shvatam? :oops:
Hull mounted weapon ima arc of fire 45 stepeni, odnosno od ose 22.5 na svaku stranu.
E sad, posto Serpent shield je Hull mounted weapon koji se nalazi na citavom front armoru vozila...da bi sve bilo "by the book" morala je nastati ona abominacija od grafika. :roll:
Ah :roll: . Pomislio sam da im onih 22.5 oznacavaju neko gledanje na dole ili nesto tog tipa (kao sto kod IG letelice ima onih 9" slepog ugla).
Zanimljivo je i sta sve smatraju back arcom. Znatno veci deo letelice nego sto sam ja smatrao (ja sam smatrao da su samo vrata back arc).
Zavisi od oblika vozila. Generalno, kako se najlakse zapamti- oko vozila opises pravougaonik/trapez/kvadrat i njegove dijagonale daju front/side/rear armor.
Zato se uvek u knjizi uzima Rhino, posto on ima taj pravougaoni oblik..dok su recimo, kod DE Ravagera, rear i front znatno uzi od side-a, posto su im skimmeri onako duguljasti.
To nije ono kako su oni prikazali na ovom crtezu (inace se slazem sa tobom da bi to tako trebalo da bude). Oni su na centar modela stavili tacku i iz nje izvukli square dijagonale. Zato i kazem da mi je zanimljivo sta oni smatraju back arcom. Ovo moze da bude poprilicno bitna stavka nekima (meni nije mnogo bitno jer imam puno TL melti, plus gomilu pucanja S7 sa re-roll na to wound, plus riptidea - ali za one sa manje ovakvih oruzja na raspolaganju ovo moze biti prilicno bitno).
Return to “ETC 2014 40K”
