[VtES] Ovladavanje pravilima...
Sta smo bese rekli za karte koje na minor i superior disciplini imaju razlicite efekte?
pitam sada konkretno i za akcije, i za reakcije i za action modifiere. Evo i primeri:
-Da li vampir moze da igra govern na superioru, untap (recimo freak drive-om) pa govern na minoru? ako se dobro secam ne moze.
-Sence the savage way - igram ga na superioru da bih se odtapovao i blokirao, da li mogu da ga igram ponovo samo na minoru da bi dodao i jedan intercept?
-Cat's guidance - Igram prvo na superioru za intercept, i onda posle combata igram na minoru ponovo da bih se odtapovao?
thezgag
Post by thezgag »
Hypodermic wrote:Sta smo bese rekli za karte koje na minor i superior disciplini imaju razlicite efekte?
nemože. Jedino za Govern nisam siguran, ali mislim da niti to.
Resurrection
Post by Resurrection »
Ne moze:
NRA rules
minion cannot:
* bleed twice in a turn
* take a political action twice in a turn
* use the same action card twice in a turn
* take the action allowed by a card in play twice in a turn
Ne moze:
1.6.3. Minion Cards
Reaction cards: A ready untapped minion can play a reaction card in response to an action taken by another Methuselah's minion (an action taken by one of a Methuselah's minions cannot be reacted to by any of her own minions). A minion cannot play the same reaction card more than once during a single action. A reaction card does not tap the minion using it.
Resurrection
Kad se glasovi cancel-uju s Demonstration ili Quentinovim specialom ponisteni su svi glasovi i trenutni i buduci.
LINK
Demonstration
Type: Master
Requires: Ventrue antitribu
Cost: 1 pool
Unique master.
Put this card in play. Tap to cancel the votes of any vampire during the referendum of a political action.
Quentin
Clan: Ventrue antitribu (group 2)
Capacity: 9
Disciplines: AUS DOM FOR cel obt
Sabbat bishop: Once each political action, Quentin may burn 1 blood to force a vampire to abstain (this can cancel that vampire's votes).
Resurrection
Promene u pravilima za turnire.
Vaze od 1.1.2008.
http://www.white-wolf.com/vtes/index.php?line=veknRules
* 3.7.5 All non-winning finalists tie for 2nd place.
* 4.1 Added three cards to the banned list: Edge Explosion, Memories of Mortality, and Protect Thine Own.
* 161 Splitting prizes is prohibited.
* Ratings Each tied-for-second finalist receives the same number of Ratings Points: 30. (The winner still receives 90).
Resurrection
Fizlovanje akcije :
LSJ wrote: Ambush cannot be used to enter combat with an untapped minion.
If the target is untapped, then the target is no longer a valid
target and, if the action isn't blocked, it will fizzle at
resolution (that is, the "enter combat with a tapped minion"
will not occur)
LINK
Tako da Bjelajac je bio u pravu, tj. dobro je odigrano.
Resurrection
LINK
> Does Escaped Mental Patient burn when the opposing vampire play S:CE ?
No, since he doesn't get to strike.
LINK
> I am succesfully blocking an action with my Escaped Mental Patient, vs
> Vampire X. During my strike phase, i decide to go for +1 aggravated
> hand damage, and then i play Rotschreck.
> 1) Do i have to burn him (EMP) at the end of combat?
No, since he didn't strike.
> 2) If i was striking instead, with a White Phosphorous Grenade,
> should i burn the grenade?
No; it is only burned after use.
> 3) And if i was using Dragon Breath Rounds, do i have to burn the gun?
Likewise, no.
Resurrection
Tension in the Ranks
Type: Master
Unique master.
Put this card in play. Whenever a ready minion is burned or sent to torpor, the controller of the minion burns 1 pool. Any Methuselah can burn this card by discarding two master cards as a master phase action.
Sto ce reci da dijablerija nece prouzrokovati gubitak poola.
Ignjacio dek je postao jos beskorisniji :(
he,he.. ali minion su i prokjurer i karlotn i milan...
Resurrection
Znam, znam.
Tekst karte je oduvek bio isti nego sam ja terao ljude da spaljuju pool kad ih dijablerisem pa selucajno naleteh na kontra primer na newsgrupi pa ko velim da objavim otreznjenje :)
Resurrection
Za nevernog Krleta:
LINK
LSJ wrote:
Daneel wrote:
> On 15 Nov 2005 14:18:30 -0800, unforgiver <[email protected]> wrote:
>> Vampire A plays Carrion Crows and as his strike he chooses Aid from
>> bats. He manevour to long. Vampire B (with superior FOR) strikes hands.
>> In strike resolution Vampire B takes 2 env dmg (via Carrion Crows) and
>> 1 strike dmg. Can he play a single Soak at superior to prevent 3 dmg?
>> Even if 2 dmg is from one source and 1 dmg is from another source?
> Sure. As long as a regular strike is not made with First Strike, it can
> be prevented in one chunk with any environmental damage suffered during
> the same strike resolution.
Correct.
Ergo, iz gornjeg se vidi da moze da se preventuje dmg od tudjeg strajka i od sopstvenog (Burst of sunlight) jednom kartom jer sav dmg koji vampir dobija u jednoj dmg rezoluciji dobija odjednom.
thezgag
Post by thezgag »
meni se to čini smislenim jer nigdje ne kaže " prevent 4 damage from one source", kao što na, recimo, superior mettleu piše "from the opponent's strike". Mislim da sam ja to tako igrao ionako.
Resurrection
thezgag wrote:meni se to čini smislenim jer nigdje ne kaže " prevent 4 damage from one source", kao što na, recimo, superior mettleu piše "from the opponent's strike". Mislim da sam ja to tako igrao ionako.
I mi smo igrali tako kad su u pitanju bile vrane + strike i slicno ali sad je bila situacija
Taste of Death + Burst of Sunlight za 3 agg dmg od cega je jedan bio od mog strajka a sve sam preventovao Armor of Vitality pa je gorepomenuti neverni Krle krenuo da kenjka :)
thezgag
Post by thezgag »
Resurrection wrote:
thezgag wrote:meni se to èini smislenim jer nigdje ne kaže " prevent 4 damage from one source", kao što na, recimo, superior mettleu piše "from the opponent's strike". Mislim da sam ja to tako igrao ionako.
Taste of: Death + Burst of Sunlight za 3 agg dmg od cega je jedan bio od mog strajka a sve sam preventovao Armor of Vitality pa je gorepomenuti neverni Krle kreuno da kenjka :)
Krle je onaj simpatični momak koji je igrao huntere? Mogu si ga totalno zamisliti kako se uzrujava... :o
pozdrav
Eh, krle krle.. zaista postaje malo nesnosan u zadnje vreme...
Resurrection
Re: [VtES] Ovladavanje pravilima...
LINK
Charming Lobby:
The vote to be called is played/named when the action is declared, and is
called (by the acting minion) by the resolution of this action. This action
is a political action.
Iliti, moras da kazes koju politiku pozivas.
Resurrection
http://www.white-wolf.com/vtes/index.php?line=rulings
Charming Lobby:
# A bloodhunt vote does not qualify. [TOM 19950921]
Wow! Kave klarifikacije.
Jedna Milka j' sa pirincem druga je sa celim lesnicima.
Dogovorite se.
Demoni.
Krle
Prince of Belgrade
Post by Krle »
Znaci ja sam bio u pravu da Ivan ne moze da zove auto-pass blood hunt?
Resurrection
Krle wrote:Znaci ja sam bio u pravu da Ivan ne moze da zove auto-pass blood hunt?
Ne kaki. Ivan nije hteo da zove blood hunt niti je o tome bila rasprava.
Mladizmaj
Post by Mladizmaj »
Dobro treba priznati poraz :-({|=
Moja ti je sa lesnicima, mada karta je bezveze ako tako radi ( tacnije retardirana ). Mada joj cesto menjaju ruling ( dva puta je promenjen do sada ) tako da nemoze covek da ih pohvata.
PS: i da sto se mene tice vise necu sumljati u tvoje odluke :oops: ( ranije je bilo sumljivih, ali si se popravio izgleda O:) )
Resurrection
Mladizmaj wrote:Dobro treba priznati poraz :-({|=
Nikad nista nije menjano.
Prethodna rasprava za Charmng lobby ti je par postova iznad i nije se odnosila na ovo neg' da li mora da odigra kartu ili da je najavi ili sta vec (naravno Krle je tvrdio da ne mora da kaze nista kad odigra.)
Mladizmaj
Post by Mladizmaj »
Dok sam preturao topike po netu neki lik je postovao sa su joj menjali ruling dva puta( neznam u vezi cega su joj menjali ruling ali to sam procitao ), to je isti lik kome sam poverovao da si ti upravu, tako da nemoj mnogo da pricas nadalje da nebih opet poceo da sumljam. (Koliko je ovo jasnije u magicu, sve jasno stoji na sajtu za svaku pojedinacnu kartu, a nemoram da preturam po nekim topicima da bih proverio pravilo za neku kartu).
Resurrection
Mladizmaj wrote:...Koliko je ovo jasnije u magicu, sve jasno stoji na sajtu za svaku pojedinacnu kartu, a nemoram da preturam po nekim topicima da bih proverio pravilo za neku kartu.
Bla.
Sve jasno pise za svaku kartu.
Sve ostalo pise na karti.
Krle
Prince of Belgrade
Post by Krle »
Cek znaci ja nisam u pravu?
Al ti i dalje jedes 600g cokolade na ex pred nama :twisted:
Resurrection
Krle wrote:Cek znaci ja nisam u pravu?
Naravno da nisi.
Ono o bloodhunt je jedina klaifikacija za Charming lobby sto ce reci da si lagao da si video drugacije.
Ti kupi Milku od 300g sa pirincem a ostalo je moja stvar 8)
Krle
Prince of Belgrade
Post by Krle »
Ne ne ili jedes sve na ex ili nista od cokolade \:D/
I mislim skini se sa foruma get a life:P
Mladizmaj
Post by Mladizmaj »
Resurrection wrote: Ono o bloodhunt je jedina klaifikacija za Charming lobby sto ce reci da si lagao da si video drugacije.
Uuuuuuuuu, Krle rekao ti je da si lazac :lol: :lol: :lol:
Krle
Prince of Belgrade
Post by Krle »
Wilt thou provoke me? Then have at thee, boy!
600g milke mmmmmmmmm :twisted:
Resurrection
I just need clarification/confirmation on this:
In order to play Power of all vampire playing it hast to be actually untaped (because of "tap to..." wording)?
When action card is canceled by Power of all acting minon doesn't tap (like when Direct Intervention is played)?
Thanks.
Relevant card text:
Power of All
Type: Reaction
Requires: anarch
Cost: 2 blood
Requires a ready anarch.
Tap this anarch and one other untapped ready anarch you control to cancel a library card as it is played. Usable even if there is no action. Not usable during your own turn.
http://forums.white-wolf.com/viewtopic.php?t=77920
Resurrection
Victor Pelletier se seca da je kupio titulu:
LINK
Zamolio bih Krleta da vise ne postavlja retardirana pitanja...
PS
http://monger.vekn.org/library.html
Krle
Prince of Belgrade
Post by Krle »
Nisu moja pitanja retardirana nego su pravila igre retardirana i proizvoljna....
Mladizmaj
Post by Mladizmaj »
Da da Krle pravila su kriva :applause: :applause: :applause:
Revelations i Monocle
Znate da se na turniru pojavilo pitanje validnosti price, kao i ona vezana za monokl...Evo odgovora na zvanicnom forumu VtESa:
http://forum.white-wolf.com/viewtopic.p ... 98#1424198
Uzivajte
Mladizmaj
Re: Revelations i Monocle
Post by Mladizmaj »
Procitao i bez uvrede svima mislim da je Resurrection u pravu sto se tice pravila, a mislio sam da je to tako i na turniru. Koliko je veliki sportista neko je po meni cudno meriti u igri u kojoj si prinudjen da vecinu dogovora koje napravis u toku partije krsis da bi mogao da pobedis i osvojis gamewin. Nekako mi koncepti junastva,casti i vampirizma nikako neidu uporedo. Na stranu cinjenica da se upropasti partija koja je usustini finale zbog nekih personalnih nesuglasica izmedju dva igraca kao sto je to bio slucaj taj dan vise puta. ( Nikica - zli, covek sa djovanijima - krle, itd )
GoxY
Post by GoxY »
Pa mora uvek neko da kuka(ju). Buhuhuhu failovao sam a da znam sacu sve da zajebem pod nekim bednim izgovorom mwahahahahah kako sam zajeban(bedan)... stagod.
[center]Image[/center]
Krle
Prince of Belgrade
Post by Krle »
Goxy bolje ti ide samo sa violinama bez texta 8)
Mladizmaj
Post by Mladizmaj »
bolje mu je da nauci da svira violinu i da se tako izrazava, bar ce svi misliti da je umetnicka dusa :lol: :lol:
Mladizmaj
Post by Mladizmaj »
ajmo jedno pitanje za naseg svima dragog sudiju:
vampir A radi akciju, moj vapir B toreador blokira akciju. Desi se kombat i moj vampir B vadi snajper iz dzepa (Concealed Weapon). Da li moze da setuje range u toj rundi na long? Da li ako uradi Psyche i pocne novi kombat u tom novom kombatu moze da setuje range na long. (ako kontrolise snajper od pocetka combata i prvi put setuje na long kad blokira, ako pocne novi kombat kartu Psyche da li moze da upotrebi snajper da setuje opet range na long?)
Resurrection
Mladizmaj wrote:ajmo jedno pitanje za naseg svima dragog sudiju:
Sniper Rifle
Type: Equipment
Cost: 2 pool
Weapon, gun.
2R damage each strike. Only usable at long range. If the bearer blocks an action, he or she may, before range is determined, set the range for the first round of the resulting combat to long; if he or she does so, skip the determine range step that round, and the bearer's initial strike that round must be with this weapon.
Ne - ne moze da iskoristi tekst sa Snipera kad ga nije imao u trenutku blokiranja. Ako ima drugi nacin da setuje range niko mu ne brani ali Sniperom ne da radi.
Ne - set the range for the first round of the resulting combat - novi kombat je od Psyche! a ne od bloka.
LINK
