Sta znaci kada na karti pise FRENZY? Kakav uticaj to ima na igru i da li je potrebno nesto specijalno da bi mogla da se odigra?
primer:
Rotschreck (master): Master: out-of-turn. Frenzy.Put this card on a vampire when an opposing minion attempts to inflict aggravated damage on him or her, whether the damage would be successefully or not. Combat ends. This vampire does not untap as normal. During this vampire's next untap phase, burn this card.
vtes: pitanje u vezi sa pravilima - tip karte
Q3A je zakon!!!
Ne treba nista specijalno i sam termin nema poseban efekat. Keyword tu samo stoji zato sto ga referenciraju neke druge karte. Na primer, svaka karta koja koristi Abombwe disciplinu moze da se diskarduje da bi cancel-ovala Frenzy efekat.
- Resurrection
Re: vtes: pitanje u vezi sa pravilima - tip karte
Kao sto rece Griter.abadrozin wrote:Sta znaci kada na karti pise FRENZY? Kakav uticaj to ima na igru i da li je potrebno nesto specijalno da bi mogla da se odigra?
primer:
Evo ti primer nekih karat koje korite keyword FRENZY:
Tranquility
Type: Combat
Requires: Dominate
Only usable by a ready vampire not involved in combat.
[dom] Cancel a frenzy card as it is played (no cost is paid).
[DOM] As above, and the target of the frenzy card gets an optional press, only usable to end combat.
Sire's Index Finger
Type: Equipment
Unique equipment.
The vampire with this equipment is immune to frenzy cards (including Brujah Frenzy, Drawing Out the Beast, Frenzy, Rötschreck and Terror Frenzy).
