The Belgrade Open - Warmachine/Hordes Tournament - Sept 2008
FGSerbia
Re: The Belgrade Open - Warmachine/Hordes Tournament - Sept 2008
Post by FGSerbia »
Friday 350pt Mangled Metal/Tooth & Claw
Entrants;
1. FGSerbia_________9. Shark_______
2. Hrvoje Jurak______10. Dawngreeter
3. Shunka__________11. Knight______
4. Miroslav_________12.____________
5. Srdjan__________13.____________
6. Pavle Kutlesic____14.____________
7. Damjan__________15.____________
8. Shukaku_________16.____________
Saturday 500pt Steamroller
1. FGSerbia_________9. Aleksandar Stef___17. Dalibor______
2. Marko Crnic______10. Damjan__________18._____________
3. Hrvoje Jurak_____11. Shukaku_________19._____________
4. Shunka_________12. Petar Dublerius____20._____________
5. Nikica___________13. Nikola (SR)______21._____________
6. Miroslav_________14. Arbor Somniorum__22._____________
7. Momcilo_________15. Knight__________23._____________
8. Pavle Kutlesic____16. Kruno Kovacevic _24._____________
Sunday 750pt Hardcore
1. FGSerbia
2. Shunka
3. Dule K.
4. Bojan D.
5.____________
6.____________
7.____________
8.____________
Mind Uploader
Post by Mind Uploader »
Hmm, it's a bit tricky for khador to put an army of near 350pts with only jacks, because we don't have light jacks... So it will be either 380 or 300pts... Oh, well...
FGSerbia
Post by FGSerbia »
@minduploader
Faction: Khador
Army Points: 343/350
Victory Points: 13
Karchev the Terrible
Destroyer
Kodiak
Faction: Khador
Army Points: 344/350
Victory Points: 15
Kommander Sorscha Kratikoff
Berserker
Berserker
Juggernaut
:geek:
Resurrection
Post by Resurrection »
Koliko trajue svaka runda ili potez u 350 i 500 poena?
arborsomniorum
Post by arborsomniorum »
Ok, idem ja, ide i Nikola TSR, ali neka se on ipak sam izjasni, ide i Aleks, Stormknight, i verovatno Sale, i Pera malkovian. To je pet ljudi iz Nsa, ako ih sve prikupim. No neka se oni ipak svako za sebe sam prijavi, da ne bude posle, ja reko, pa poreko...
mladjano bugarce
Post by mladjano bugarce »
Za nedelju sam siguran za ostalo videcemo...
Shark
Post by Shark »
otju i ja u taj jack-only turnir :)
dublerius
Post by dublerius »
evo stefan me je vec prijavio dolazim kada i oni sigurno a za ostale dane bi isto dosao ali to zavisi od moje halavosti za kupovinu novih pirata i svega drugog :D
tj ako spicim pare necu doci drugi dan :D ali bolje da me ne prijavite za ostale dane turnira da nebi bilo da sam ispalio :D
arborsomniorum
Ok, Rik, then put Petar Dublerius, Nikola The Serbian Raven, and me, Arbor Somniorum, at Saturday event...
A ko ce sa cim igrati, da li to mora da se najavi nekoliko dana ranije... Ipak, apsolutno ne znam sa cime cu doci, jer nijednom nisam igrao po steamrolleru, cak nisam ni procitao ta pravila...
i'll play 350, and 500....probably pirates...
FGSerbia
Post by FGSerbia »
By my calculation we currently have;
Cryx 3
Cygnar 1
Khador 4
Menoth 2
Pirates 1
Trollbloods 2
Come on Hordes - no Orboros, Skorne or Everblight showing?
A few more Cygnar would be nice and where are the Mercs?
Come on people!!
PainBringer
Post by PainBringer »
Here's one Everblight player.
Resurrection
FGSerbia wrote:By my calculation we currently have;
Cryx 3
Cygnar 1
Khador 4
Menoth 2
Pirates 1
Trollbloods 2
Come on people!!
3+1+4+2+1+2=13 - nedostaje ti jedan.
Ako ti nije frka napisi pored svakog prijavljenog igraca sta igra (mozes i skraceno).
I onako se pri prijavi kaze s kojom frakcijom seprijavljuje tako da nema potrebe da to bude tajna.
Khador
Cryx
Protectorate of Menoth
Mercenaries
Cygnar
Trollblood
Legion of Everblight
Scorne
Circle of Orboros
I'm still not applying, because I'm still not sure if I'll be avaible at that time...
I'm applying my Orboros dudes for Tooth & Claw. I'd apply for Steamroller if I was sure I'd able to field 500pts. worth of Orboros dudes, which ain't certain at this point.
arborsomniorum
Dawn, sta ti fali, mozda imam...
Nije toliko pitanje dal' fali nego dal' ce ono sta imam biti gotovo do tada... a i ako ne bude, mozda budem isao sa Skorne vojskom, k'o zna. Al' vidim da je kategorija vec skoro do kraja puna pa necu da izvodim gluposti. Kad budem siguran kakvo mi je stanje, ako bude slobodnog mesta upadam, ako ne nikome nece smetati sto nisam upao.
dublerius
Post by dublerius »
ako mogu da dokupim pre turnira sta mi fali za bolju vojsku na 500 onda vodim pirate ako ne onda je menoth (svakako hocu da dokupim samo vreme dokupljivanja je pitanje :D)
FGSerbia
Post by FGSerbia »
We've also got the gatormen at the club etc
arborsomniorum
Dawngreeter wrote: Kad budem siguran kakvo mi je stanje, ako bude slobodnog mesta upadam, ako ne nikome nece smetati sto nisam upao.
Pa meni ce smetati, a kategorija ne moze da se prepuni, kao sto vidis da je Rik stavio jos jednu kolonu...
Knight
Post by Knight »
Kada pocinje mangled metal u petak? Ja bih mogao da pocnem oko 17h, a rado bih ga igrao.. :)
DOlazim u subotu na 500 pts sigurno, a za nedelju cu jos videti.
Dawny G, hajde ti da igras Orboros na 350 a Skornu na 500. Uostalom, stagod ti treba, do turnira bice gotovo. Zafarbacu ja licno, znas da mogu da stignem ako treba. Ili, da igras Skornu na 750!!! Hajde!!! Moras!!! Ima nas malo!
Nisam hteo u 750 da se mesam jer realno ne igram ni priblizno na nivou ostalih prijavljenih. To bi trebalo da bude kategorija na nekom nivou, valjda, pa ne bih mesao moje prljave male prstice bez preke potrebe. Skorne na 500 se i ja sve vise razmisljam, u glavnom zato sto imam nula iskustva sa Orborosom...
Tuzna je moja prica, bre :-({|=
Ama kakve ima veze! Ja isto slabo igram na nekom ozbiljnom nivou (fali mi taj sahovski momenat planiranja vise poteza unapred), i moja lista u 750 ce biti neka vesela. A i meni nekako ta kategorija deluje najopustenije, iako bi kao trebalo da je najozbiljnija.
a) svi su tu sa svima odigrali milion partija, i nece biti nikakve napetosti
b) u 750 poena imas prostora da izvedes uglavnom sve sto zelis da uglavis
c) svi ce imati lepo ofarbane armije
d) mnogo manje ljudi - znaci vise prostora, vise vazduha
e) imam 4 armije, ne mogu ja sam sve da ih vodim
f) itd.
Edit:
g) eto ja da pobedim nekoga u toj kategoriji
P.S. Verovatno igram Trolove u 350, Skornu u 500 i Khador u 750. Mada mozda Skornu budem igrao u 350, a Trolove u 500. Ili poludim pa u 500 povedem Searforge Mercove.
Shark
Post by Shark »
eto shta bude kad chovek ima pet armija ... ne zna koju da vodi :)
decisions, decisions ...
Je'l bi neko ko ima dobar internet search-fu mogao da okaci link ka steamroller 2 pravilima. Ja sam ih nekada davno downloadovao, a sad da me ubijes ne mogu da ih nadjem, + mislim da ce biti korisno svim ucesnicima...
arborsomniorum
http://www.gfmailorder.nl/events/Steamr ... 47ccb11e28
A sta ne valja ovom linku, sto ga je Rik dao...
Dule se zaglupeo, Dr. Iggy mu je veceras isprao mozak... :lol: :lol:
arborsomniorum
Premda sada kada ja trazim odakle sam izbunario ne mogu da nadjem, izgleda da je neka magija posredi... Mozda ja dodjem sa Menitima, da ne budem crna ovca...
Edit: Ko zna mozda se i Scyrah u medjuvremenu pojavi, pa se nesto i uradi po tom pitanju...
Last edited by arborsomniorum on Fri Sep 05, 2008 1:51 am, edited 1 time in total.
Shark
Post by Shark »
bitje menota, makar na tom od 350 ... :)
Resurrection
Shunka wrote:Ama kakve ima veze! Ja isto slabo igram na nekom ozbiljnom nivou (fali mi taj sahovski momenat planiranja vise poteza unapred), i moja lista u 750 ce biti neka vesela. A i meni nekako ta kategorija deluje najopustenije, iako bi kao trebalo da je najozbiljnija.
Sunak, tvoje vrle plandze tesko da ce stati u 7minutni potez ali srecno :)
Jel niko nije primetio da nema timelimita na trajanje poteza u Steamroller 2: samo pise da partija traje 60 min za 500 poena i to je to?
DA bi ogranicili "plandze" koje traju 324256326 sati da se osmisle, Rick i ja smo se nacelno dogovorili da potez u steamrolleru ce biti ogranicen na nesto izmedju 10 i 12 min. videcemo jos, kada testiramo...
Resurrection
Pendargon wrote:DA bi ogranicili "plandze" koje traju 324256326 sati da se osmisle, Rick i ja smo se nacelno dogovorili da potez u steamrolleru ce biti ogranicen na nesto izmedju 10 i 12 min. videcemo jos, kada testiramo...
Eh, ali vidis, to ondak nije Steamroller 2 :)
A ako je u redu modifikovati turnirska pravila onda je bolje da smo igrali SR4 i batalili predefinisane mape (terene).
Vidi ti to s Rikom, joste.
PainBringer
Steamroller 3 pravila i mape (cini mi se da se za ove mape imamo sve potrebne terene), sa oficijelnog PP forunma:
http://www.privateerpressforums.com/ind ... pic=115844
Resurrection
PainBringer wrote:Steamroller 3 pravila i mape (cini mi se da se za ove mape imamo sve potrebne terene), sa oficijelnog PP forunma:
Imamo 2 zidica i jednu vodu i jedan plato.
Nemamo shallow water koja ide celom duzinom table.
Mislim da ostalog ima ali da li je u dovoljnim kolicinam ne znam.
Najvise fali zidica (linear obstacle).
Steamroller 4
PainBringer
Imam ja jos dva zidica, brdo, rusevine i dve male sume.
na jednoj tabli ima reka celom duzinom, a trebao bih i ja negde da imam jednu onu reku za sklapanje(shallow water)
Resurrection
Blago nasem organizatoru kad mi organizujemo mesto njega :)
Shark
Post by Shark »
vala bash, ne znam gde bismo drugde mogli da odigramo turnir ...
pa mozda bi dobri penzosi na kalishu mogli da nam ustupe par klupa i tabli ;)
