Tag Team Terror
FGSerbia
Re: Tag Team Terror
Post by FGSerbia »
Teams so far;
1 a. Miroslav (Everblight)
1 b. Alex (I think) (Khador)
2 a. Shark (Menoth)
2 b. Rick (Highborn Born Covenant)
3 a. Shunka (Khador)
3 b. Dawngreeter (Orboros)
That leaves;
1. Stef - Cryx
2. Momcilo - Menoth
3. Ratgod - Orboros
4. Stevo - Cygnar
5. Vedran - Khador
6. Dalibor - Orboros
7. Nikica - Cryx
8. Dule - Pirates/Mercs
and we only need two more players to complete the line up. Dule do you fancy playing my Skorne or Trollbloods to help things out a bit?
Re: Tag Team Terror
If it's on Sunday, i believe that Bojan is also in. But i thought that you are teaming up with Shark?
Re: Tag Team Terror
i'll probably be playing...depends on my exam schedule...
so probably pirates, but i can play everblight shreder horde if you need horde players...
Mind Uploader
Re: Tag Team Terror
Post by Mind Uploader »
Rover wrote:i'll probably be playing...depends on my exam schedule...
We can play together... Khador and Everblight...
mladjano bugarce
Re: Tag Team Terror
Post by mladjano bugarce »
Ako bude u nedelju(sto vas iskreno molim) Khador/Everblight
Re: Tag Team Terror
S obzirom da je za mene, trenutno, i 9. oktobar daleka buducnost, a o 9. novembru i da ne pricamo, ja cu se prijaviti uz rezervu. Ako se niko drugi ne prijavi, ja cu se potruditi da dodjem. Ako se bilo ko prijavi (posto postoji limit od 16 igraca), neka zauzme on moje mesto.
FGSerbia
Re: Tag Team Terror
Post by FGSerbia »
I am playing with Shark - but would you play with my trollblood or Skorne models if we needed an extra Hordes player?
Re: Tag Team Terror
Nah... I simply don't like hordes... And I don't feel comfortable with all that excess fury. I can always fill in the hordes gap, as i have both Shae (who can go with any horde), and Magnus (who can go with anyone but cygnar)....
Re: Tag Team Terror
Team of Bojan/Kador, Dalibor/Orboros is in for 9th.
Resurrection
Re: Tag Team Terror
Post by Resurrection »
Previse zainteresovanih a premalo mesta.
Resenje?
Re: Tag Team Terror
kako to mislish previshe zainteresovanih?? zar ne pishe tamo 8 timova( a ne 8 ljudi)
Resurrection
Re: Tag Team Terror
Pise.
Zbunjen sam.
EDIT:
Damjane, hos da se utimujemo?
Lagija sredera i 3 cice vjestice?
Ne moze da propane.
Re: Tag Team Terror
Do novembra vremena ima, racunam da cu do tada imati i svoje patuljke... Mogu uvek da igram i Skornu, i Trollbloode... Nego cisto mi deluje najprirodnije da se udruzujem sa Dawngreeterom (pri cemu se sa istim nisam ni konsultovao, sram da me bude), a Khador/Orboros kombinacija mi deluje najzabavnije (naravno bilo bi kulje kada bi vodili Epic modele, pa onda recimo ESorscha i EKaya). Mada ako bude bio problem oko udruzivanja, pretpostavljam da mozemo i drugacije - npr. moji Trollbloodi i Stevin Cygnar, a Skorna ode sa Menotom... Evo neka se Dawny sam izjasni kako bi on najvise voleo?
Re: Tag Team Terror
Nikica je u pravu, 16 ljudi u Sigilu, jos ako se igra na 6*4 stolovima ...(4*4 imaju tendenciju da se zakrce u 1000 poena)
Re: Tag Team Terror
Zekina banda wrote:Nikica je u pravu, 16 ljudi u Sigilu, jos ako se igra na 6*4 stolovima ...(4*4 imaju tendenciju da se zakrce u 1000 poena)
U subotu je bilo 14 ljudi, pa smo preziveli. Jeste da ce ovako biti vise zakrcenja stolova, ali ce zato samih stolova biti samo 4, a mislim da za toliko prostora ima (ako ne i vazduha za 16 ljudi).
Edit: tek sam sada skuzio da se pominju 6*4 stolovi. Ne. 1000 poena se komotno igra na 4*4.
stefaz
Re: Tag Team Terror
Post by stefaz »
Ja sam jos uvek otvoren za bilo kakve saveze...ako je neko uopste ostao slobodan :(
Resurrection
Re: Tag Team Terror
Ja sam se istripovao da je turnir za 8 ljudi pa da je ostalo jos jedno mesto samo.
Stacemo; na turniru nas je bilo 14 igraca + par ljudi sa strane i ok je bilo.
Malo ce biti guzve oko stolava ali verujem da ce ih Rik postaviti kao za prosli turnir - po sred kluba.
U svakom slucaju najkomotnije ce biti onome ko igra sa mnom jer sam najmrsavjii ;)
stefaz
Re: Tag Team Terror
Post by stefaz »
Resurrection wrote:U svakom slucaju najkomotnije ce biti onome ko igra sa mnom jer sam najmrsavji ;)
Reklamiras se, a? :D
Re: Tag Team Terror
Shunka wrote:Evo neka se Dawny sam izjasni kako bi on najvise voleo?
Ja sam planirao da moji grlioci drveca trce sa tvojim prokletim crvenim imperijalistima. Naravno, ako smo u deficitu sa Hordes igracima, u principu bih igrao sa kim god a ti uzmi Skorne.
FGSerbia
Re: Tag Team Terror
Post by FGSerbia »
We'll arrange the tables so that there's plenty of room for all the players and tables.
It'll be a long day, lots of standing etc etc etc but I think it'll be easier than last saturday.
When you know your team please let me know. It is limited to 8 teams - so get in early and book.
Stevo (Cygnar) could join Ratgod (Orboros) or Dawngreeter (Orboros) or Shunka (Trollbloods)
Stef (Cryx) or Nikica (Cryx) or Momcilo (Menoth) could join Dawngreeter (Skorne) or Shunka (Skorne or Trollbloods) - I could lend an extra Krea, Agonizer, Paingivers and/or Cetrati if needed.
Current teams are;
Damjan (Legion) & Srdjan (Khador)
Bojan (Khador) & Dalibor (Orboros)
Miroslav (Legion) & Vuk (Khador)
Shark (Menoth) & Rick (HBC)
Pavlik Vladansson
Re: Tag Team Terror
Post by Pavlik Vladansson »
RatGod an me will be teaming up, so sign us up. I'm Cygnar, he's Orboros.
Fiat iustitia et pereunt mundi.
Re: Tag Team Terror
Magnus , in the end, realized that the only true way of reinstating Vinter as a true king is through mercy of one true god, Menoth!!
Tag team : Moma (menoth)/ Pendargon (4 star)
Re: Tag Team Terror
So spoketh Pendargon! Amen!
Mind Uploader
Re: Tag Team Terror
Odjavljujem ucesce...
arborsomniorum
Re: Tag Team Terror
Post by arborsomniorum »
Shunka wrote:@Dawny
To mu ga dodje u prevodu?
NEce proci...
Shunka wrote: Uzgred, moli se dezurni moderator da pobrise poslednjih nekoliko oftopicarskih postova. Valjalo bi da se zavede makar malo reda na ove prostore virtuelnog nam kluba.
Ja mislim da ne, zato sto koliko je meni poznato turnir je 9 novembra, ili ste pomerili za 9 oktobar...
9 novembar je dan pobede nad fasizmom, pa je takodje problematican...
Sve ovo je korisno, da bih znao da mozda i ja dodjem... Sta da ponesem, imam sve sem orborosa u 500 poena (imam i orborosa, ali ima dosta konverta, pa mi je glupo sa tim da igram)...
POmazite, i da li bi se neko tagovao samnom...
Re: Tag Team Terror
arborsomniorum wrote:Ja mislim da ne, zato sto koliko je meni poznato turnir je 9 novembra, ili ste pomerili za 9 oktobar...
8O
I am dumbfounded. All this time I figured it was October, which is to say in a couple of days... Didn't even bother to check the dates to see that the 9th of October wasn't even on a weekend... Jeeez. ](*,)
arborsomniorum
Re: Tag Team Terror
I knew it, that's why I said it.
dublerius
Re: Tag Team Terror
Post by dublerius »
evo stefane ja bi igrao sa tobom ako moze jedan tim iz ns-a da se ubaci i ako ima mesta :D
FGSerbia
Re: Tag Team Terror
Post by FGSerbia »
Pendargon wrote:Magnus , in the end, realized that the only true way of reinstating Vinter as a true king is through mercy of one true god, Menoth!!
Just as long as you don't do a cheesy Kreoss/Magnus & 2 Obliterators list =; - I don't want to have to wheel out the brick
We're starting to get up to the necessary numbers. PLEASE only apply if you can definitely play.
I have 2 Cygnar and 2 Cryx players looking for love any Everblight, Skorne, Trollblood or Orboros players still out there?
Re: Tag Team Terror
Oh, come on!!!! :D :D
We're having Sorscha/ Saeryn list (not cheesy at all :roll: ), Baldur/old witch (come into forest/smoke and you die!!), At least one krueger/cygnar (probably striker (i knock you, then krueger fries you...), and god knows what bojan and dalibor are gonna roll...?
And you call a little of nice "sit down" list cheese...? 8) 8) 8)
Injustice, that's what I say!!! :D :D
arborsomniorum
Re: Tag Team Terror
PEro, ne bih se jos prijavljivao, do datuma kada je to neophodno, jer ne bih da opet ispalim... Zasto bih se brinuo... Pa na turnir u septembru, sa Rvatima bilo je 14 ljudi... Ovo ne kazem kao podcenjivanje, vec kao sigurnost da ako budem u mogucnosti da dodjem, bice mesta.
FGSerbia
Re: Tag Team Terror
Post by FGSerbia »
If Momcilo play Severius instead of Kreoss then he can pop his feat and have the warlock not be able to transfer either. :-k
Momcilo I shall get you Reznik with much speed. I could order Amon Radza for you too? O:)
Re: Tag Team Terror
I'll play no Vilmon, no caster, no jack, all zealot army (without the Monolith bearer,of course). :) And Dule will play with a single merc horseman without a horse, pistol, and sword....
That would be nice.... :)
P.S I'm ordering Reznik just for fluff reasons and for a nice friendly game, we all know his usefulness :(
mladjano bugarce
Re: Tag Team Terror
Stvarno mislim da je Reznik jedan od najboljih kastera protektorata.
Re: Tag Team Terror
Narucio sam ga, pa cu poceti polako da ucim kako da igram sa jackovima. Trebace mi malo vremena da se prebacim sa dalekometnog (Severius) na Reznikov nacin igranja menotha.
FGSerbia
Re: Tag Team Terror
Post by FGSerbia »
I disagree about Reznik. I understand why Shark would play him - because of the Jack love but Menoth's primary casters are troop casters and their troops and solos are excellent. A heavy Menoth Jack lists could be a strong, as Momo calls it - 'Friendly list' and looks utterly fabulous, but loses them too much of their strengths. Devouts are almost auto-includes and with Sevy so are Revengers. With Kreoss Redeemers are great but I'm not sure about everything else. If you put Reznik in with a choir, a vassal and lets say 2 heavies all you've got left is a unit of Zealots at 500 points. Better to go for Kreoss and 3 Redeemers. :P
arborsomniorum
Re: Tag Team Terror
Rick, why two heavies?
Vanquisher or castigator is enough. I'll rather put four jacks, and Reznik, than two heavy. Because Reznik has the spell to boost rolls, light jacks are also perfect with him.
Reznik rules, IMO.
Re: Tag Team Terror
When I get Reznik (hurry up, Rick! :) ), play a couple of games, I'll tell if he is a tournament caster or just a modified version of Amon ad Crapza.
For now, Harby, Kreoss, and Sevy (in this order) are the tournament picks for Menoth.
P.S. I would like to play Reznik just for his fluff, with no jacks at all, but then he'll be just another expensive solo.
FGSerbia
Re: Tag Team Terror
Post by FGSerbia »
I've just re-read Reznik and he is very good. It's not him - it's the Menoth Warjacks. They are all only OK to my mind. Now Reznik and a choir would mean that a Crusader could be in my face pretty quickly but there's too many ways to deal with it. Now if Menoth had Centurions or Khador jacks it would be different.
I'm just starting Menoth and my one and only model is the High Reclaimer. I will get some Menoth heavies (Fires of Salvation and the Avatar) but only because they look so good. At 500 points I would play a devout and a revenger (maybe) and at 750 I would have the devout and the blessing of vengeance (ESEVERIUS - YEAH BABY) but with the 3 primary casters (Kreoss, High Reclaimer and Sevy) there is no need. The Harbinger doesn't do Jacks and Feora is only so-so with them. Admon Ad'Raza is a jack caster but he is very difficult to play (imho). Hence I think Menoth is too weighted towards troops to be brought back by a single, albeit, very good jack caster. I think the same is true of cryx. There are some cool cryx helljacks but to convince people to sacrifice their lovely thralls to play Mortenebra is tough - especially in competitve games. Yes Cryx players will always use bone jacks but outside of the DJ do many Cryx heavies get regular play (think back to the tournament)?
FGSerbia
Re: Tag Team Terror
Post by FGSerbia »
Harby's your first pick? Interesting :-k . I thought will Dule dropping 2 obliterators - Kreoss was sure to be 'da man'. Reznik and eSevy were out of stock last week - I'm trying to rush another order for tomorrow 8-[ . The main reason being only 4 Thorn's turned up and I can't have that - mine's the 5th customer order :pray: !!!!
