2a Edicija 2010
Re: 2a Edicija 2010
Tutnjava gromova
"HAAAAAAAAAAAAAAAALLEEEEEELUUYAAAAAAAAAAAAAAAAAH"
Pistolj djavli mogu opet da se slobodno seckaju bez straka od fantom seekera :twisted:
Re: 2a Edicija 2010
Re: 2a Edicija 2010
Pokazali su na sajtu nesto od novog arta.
Izmedju ostalog novog Khador Warcastera. U pitanju je neki Assault Kommandos baja.
Svidja mi se kako izgleda.
FGSerbia
Re: 2a Edicija 2010
Post by FGSerbia »
Ooh Shiney!!
Shark
Re: 2a Edicija 2010
Post by Shark »
FGSerbia wrote:Ooh Shiney!!
And they're $90 each.
Re: 2a Edicija 2010
25$ apiece, and with a 10$ discount if you order a faction pack.
Resurrection
Re: 2a Edicija 2010
Post by Resurrection »
The Cygnaran Armory takes pride in its innovation and technological superiority, traits seen in all the battle-tested warjacks built on the classic Ironclad chassis. Armed with a powerful quake hammer, the Ironclad effortlessly smashes lesser combatants to scrap. The Defender employs its long, heavy barrel cannon for unprecedented long-range and accurate firepower without sacrificing its effectiveness in melee. With its dual whirling chain guns, the Cyclone can support sweeping advances across the battlefield while suppressing the enemy under a hail of lead.
One of the first warjacks developed by the Protectorate after the Cygnaran Civil War was the Crusader, a massive warjack boasting heavy armor and capable of crushing attacks. It has served as the foundation for several masterpieces of war. The Templar, for one, smashes enemies with overwhelming force from an unassailable position behind its thick shield. Of more recent production, the Vanquisher wields a great “blazing star” spiked ball in one hand and a flame belcher in the other. This weapon sends an oil-filled cannonball that bursts and ignites on impact.
Khador’s mechaniks build their warjacks to last. The Juggernaut is a hulking mass of plated armor wielding an ice axe that can encase its target in a layer of crippling ice. This sturdy chassis has given rise to other staples like the Destroyer, whose whistling shells arcing overhead portend explosive obliteration. Another is the Decimator, engineered to annihilate well-armored targets with powerful direct fire. This ’jack’s wide-bored cannon smashes its victims to the ground before it closes to tear them apart with its whirling rip saw.
The fiendish inventiveness of Cryxian necrotechs has resulted in many machines perfected to employ the killing arts. The Slayer is a swift, hulking beast of bone and black iron that relishes murdering anything in its path. The Reaper can fire its harpoon to sink deep into flesh or steel before reeling in its victim with frightening speed to within range of its vicious helldriver spike. The Corruptor is the culmination of Cryx’s pioneering work in caustic compounds and necrotic poisons, a helljack armed with venomous weapons designed to consume both body and soul.
FGSerbia
Re: 2a Edicija 2010
Post by FGSerbia »
They all look great though I think Cygnar and Khador look the best. The Menoth one seems a bit vanilla. I just hope the Cygnar one does more than POW 10's.
Re: 2a Edicija 2010
Dakle izlazi plasticni box za svaku fakciju od koga ce moci da se sastavi jedan od 4 jacka sa istom sasijom.
Ja nesto nisam impresioniran redizajnom Juggy sasije... Pogotovo sto ce sada biti veliki kao Behemoth! Mada ima manje kakecu pozu, to je bar nesto...
A i ovaj Decimator pored lepog imena ima prevelike ruke!!!
Resurrection
Re: 2a Edicija 2010
Ne postoje prevelike ruke; samo premale sise.
Re: 2a Edicija 2010
ovaj kadorski dzek je nesto najruznije sto sam skoro video. nogice su mu ko kod pilenceta i nisu detaljno odradjene.
EDIT:
pardon menotski dzek ima pilece nogice, a kadorske noge su samo ruzne do bola i bez detalja...
Re: 2a Edicija 2010
Koliko sam cuo, bice delova da se sastavi jedan od 3 dzeka u kutiji. A s obzirom da je plastika u pitanju, "kakece" i sl. poze ce biti lakse ispraviti :D
Re: 2a Edicija 2010
Nadam se da ovaj ubogi slayerov rodjak ima nesto korisno od tih krakatih ruku da nadmesti arm 17... :roll: :roll: :roll:
Re: 2a Edicija 2010
@Zekina banda
Khador ne voli inovativnu tehniku tako da je za nas 4 - (Juggernaut, Destroyer, Decimator, Marauder). Da su se malo vise iscimali mogao bi i Kodiak - i njegova sasija prati istu osnovnu konstrukciju...
Ja planiram da se igram malo sa pinovima ili magnetima pa da mogu po potrebi da menjam ruke/glavu...
Re: 2a Edicija 2010
Novi Rhulic Jack - Basher!
Izgleta totalno kretenski i neverovatno mi se dopada!
Jedva cekam da mi padne saka!
Re: 2a Edicija 2010
ovaj izgleda bas,bas dobro...
Re: 2a Edicija 2010
I meni se dopada... izgleda da cu morati kupiti gortenov battlebox samo da bi igrao preraslog gunbunny-a :-)
Resurrection
Re: 2a Edicija 2010
Sa kukom za prikolicu :)
Resurrection
Re: 2a Edicija 2010
Resurrection
Re: 2a Edicija 2010
Few soldiers are as hated and feared by the Motherland’s enemies as Kommander Viktor Strakhov.
With each engagement, Strakhov changes the face of warfare in the Iron Kingdoms to match his vision of bloody excellence.
Resurrection
Re: 2a Edicija 2010
Knight
Re: 2a Edicija 2010
Post by Knight »
Siege pod Arcae Shieldom u FOx Hole-u :
http://www.privateerpressforums.com/ind ... pic=191918
(Postavilo se kao pitanje dal on to ima 2 friendly spela na sebi)
mladjano bugarce
Re: 2a Edicija 2010
Post by mladjano bugarce »
Sada sam pogledao, malo je nelogicno ali ima jos takvih kastera - npr. Baba Jaga i njen dim
Resurrection
Re: 2a Edicija 2010
Veil of Mists i Infernal machine/Occulation
Re: 2a Edicija 2010
Nove karte... za novi minion unit i novog rulic warjacka.
Warjack je sladak, idealan da ga thor jackmarsalluje...
A ovaj unit... 'nako. Mislim da su za 4 pts ayana i holt bolji buy
Resurrection
Re: 2a Edicija 2010
The Ripjaw’s pincer-like jaws are used to hold its victims in place while its bone saw cuts them into mangled and unidentifiable bits. Necrotechs take particular delight in using the Ripsaw, as the ’jack efficiently dismembers its victims into component pieces. Regardless of these lethal armaments, the Ripjaw remains quick and agile like its brethren and serves its master by maneuvering its arc node to wherever required to disrupt the plans of the enemies of Cryx.
Nooood!
Kostace verovatno 4 poena :(
Re: 2a Edicija 2010
Hoce li to da izbace plasticne kitove i za light warjackove?
I sta ce Khador dobiti - alternativnog Berzerkera?
Re: 2a Edicija 2010
Jeeej, noda!!!
Bas me briga sta radi, ako je 3 poena, ima da ih kupim 6...
Resurrection
Re: 2a Edicija 2010
^igzekli.
Resurrection
Re: 2a Edicija 2010
Jebeni smarach.
Re: 2a Edicija 2010
A koji behu tamariti?
mladjano bugarce
Re: 2a Edicija 2010
Za sada samo morska vestica
Mladizmaj
Re: 2a Edicija 2010
Post by Mladizmaj »
Nije mi jedino jasno sto nece da radi za menoth.
Resurrection
Re: 2a Edicija 2010
Jer je nakad radio za njih pa je dobio otkaz.
Re: 2a Edicija 2010
Zato sto Menoth-ovci ratuju protiv Morrow-anaca.
Osim u Khadoru, gde nacionalna pripadnost ima prioritet nad verskom.
Doduse Starac Severije je i kod nas poceo da pravi pizdarije.
arborsomniorum
Re: 2a Edicija 2010
Post by arborsomniorum »
Izgleda super, ali ne bih dao tolike pare za njega. Mada, vec balavim za njim...
stefaz
Re: 2a Edicija 2010
Post by stefaz »
Bre, ne znam, malo mi ovaj topuz prevelik...ili su klipovi koji ga drze premali. Posle prvog pucanja bi ostao bez pola ruke, osim ako nije u pitanju neki super-bestrzajni top. Ipak mislim da su malo preterali. :?
Re: 2a Edicija 2010
Novi plasticni jackovi svi imaju preterano velike gornje udove.
Ne brinite, izgledace manje groteskno uzivo nego na fotkama.
Re: 2a Edicija 2010
