August Event
What do you fancy for an August Event?
Poll ended at Sun Aug 02, 2009 9:16 pm
The 500 point simple event
6
35%
The 500 point scenerio event
5
29%
The 3 match masters event
6
35%
Total votes: 17
FGSerbia
Re: August Event
Post by FGSerbia »
Pendargon wrote:Better to predetermine. That will give players time to test them out, and avoid stupid situations like :" Ooooooh, so THAT'S how this scenario works... but we played it differently now for 4 turns... ummmmm what should we do...?", and : " We are playing a scenario?", and " What scenario?"
Without trying to be rude (and therefore being rude without trying :P ) the WM/H community is not great at making up it's mind. The fact that we have a tournament format that most people are willing to play is a f**king miracle, let's not rock the boat by suggesting scenerios. It'll be decided on the day and we'll take an extra 5 minutes to explain everything VERY VERY clearly. This will be the format for September (if it goes ahead) and so it's best to get people used to it.
PainBringer
Re: August Event
Post by PainBringer »
I also agree with Shunka and Dule - it would be better to select the scenarios before the tournament.
mladjano bugarce
Re: August Event
Post by mladjano bugarce »
Izabrati scenarije pre turnira i postaviti na ovaj forum da budu dostupni svima. Scenarije ne birati po glasanju nego Sunka jednostavno postavi tri scenarija iz stimrolera na ovaj topik.
Takodje bilo bi dobro odrediti finalni set pravila za turnir sto pre.
Re: August Event
@Rick
The point of discussions is not to determine the options that everyone likes (because it's impossible), but the one that most people find acceptable, even if they have preferences. In the end someone has to make a firm decision - we play so-and-so, and those who don't like it are free not to participate. And hope that enough people turn up.
So, I think we can agree upon these:
We play on 9. VIII. 2009.
There will be three rounds, first will be 500 points, the second 625 points and the third 750.
Each round is to be played with a different list, and the three lists must include different warcasters/warlocks.
We'll be playing Steamroller 4 scenarios - link.
I have no objections to any choice of scenarios - exept those mark in the rules as not suited to games under 1000 points. I'd still pick those three I marked earlier - Process of Elimination, Mosh Pit and Break the Line. Most of the scenarios are quite similar anyway.
Edit:
It would be nice to have some casual play this Sunday in order to test scenario rules.
Re: August Event
Okay, i'm all for it.
I'm calling dibs for : 500 pts Iron lich
625 Deneghra
750 EGoreshade
And methinks no baneknights for me in any of lists :-)
Will try scenarios out these days :-D
FGSerbia
Re: August Event
Post by FGSerbia »
Shunka wrote:@Rick
Cool and it's great that someone else is making those decisions, it'll be nice just to be a player for once.
FGSerbia
Re: August Event
Post by FGSerbia »
For any new players this podcast has some interesting advice for creating tournament lists and also tournament tactics;
http://www.boosteddamage.com/
Click on Episode 4
The first half is pretty unimportant but it gets to the point after about half an hour.
Resurrection
Re: August Event
Post by Resurrection »
Samo nemojte da odredite u kojoj rundi se igra koji scenario sve ostalo je svejedno.
Re: August Event
Sto ne?
Re: August Event
Slazem se sa nikicom
Evo da objasnim : Ako se zna u kojoj se rundi igra koji scenario, onda ce za mosh pit, npr, svi kadoranci spremiti svoju listu sa vladom i devastatorom, svi cygnarci dariusa, svi mercovi gortena i svaki circle baldura. To dovodi do mirror matcheva koji nikada nisu zabavni. Zato sam ja lepo napisao sa kim igram koju rundu, da se nikica, stef i ja (potencijalno), ne uduplamo sa casterima, varijetea radi. Redosled scenarija bi (po mom skromnom misljenju) trebalo odrediti na random, pre pocetka turnira, kada ljudi predaju liste :-D
FGSerbia
Re: August Event
Post by FGSerbia »
Shunka wrote:Pri cemu da se igra prvo Process of Elimination, pa Mosh Pit, i na kraju Break the Line.
Which is why I said decide on the day. Predetermining scenerios doesn't help noobs it helps experienced players. In larger steamroller events the scenerios are published before hand but players must have submitted their two lists before the scenerios are published and if they don't they can be penalised tournament points. In Mosh Pit facing Deneghra with Bile Thralls is extremely difficult and it is impossible if you're facing a good player and Cryx goes first.
Re: August Event
Aj onda da ne igramo Mosh Pit ako je taj scenario problematican
stefaz
Re: August Event
Post by stefaz »
Ako je turnir 9. VIII, ja na zalost necu moci igrati... :-({|=
Re: August Event
@Stefaz
A 8.?
Koliko sam ja razumeo pravila za GenCon, odredi se ko sa kim igra, igraci izaberu listu za taj mec (prema protivniku), a onda se vuce scenario.
FGSerbia
Re: August Event
Post by FGSerbia »
Zekina banda wrote:Aj onda da ne igramo Mosh Pit ako je taj scenario problematican
No I don't think that's the solution. I think the best option is to pick 6 scenerios and roll a d6 before each event to decide which is played for example;
1 Mosh Pit
2 Contested Ground
3 Destruction
4 Process of Elimination
5 Assassins
6 Break the Line
That way each scenerio can be planned for but each list has to be a little rounded.
Re: August Event
Samo da proverim. Pravimo tri liste od 750 poena sa tri razlicita vorloka/vorkastera, pa ih srezemo pred bitku na 500/625.
Mozda bi bilo interesantno da liste u stvari budu od 800 poena? (Iz razloga sto neke stvari ne rade protiv Hordi, a neke ne rade protiv mashina).
Re: August Event
ne.
napravis jednu listu od 500, jednu od 625 i jednu od 750.
to je to.
Re: August Event
Onda ne mozes da biras kastera pre svake runde, a koliko se secam, u Gencon pravilima je naglaseno da se kaster bira pre svake runde (kad vec znas protiv koga igras).
Re: August Event
Ne, ne mozes da biras kastera pre svake runde, nego unapred odredis sa kim igras koju poentazu :-D
Ne , ne radi tako ni na genconu, tamo je dozvoljeno da imas dve liste, pa onda biras koju ces listu kada vidis sa kojom ARMIJOM igra protivnik
8)
edit : a kakve veze ima, posto se ne takmicimo za titulu gospodara univerzuma :-D ?
Re: August Event
Nema veze, nego htedoh da pravim liste :D
Re: August Event
Evo, ponovo sam procitao za Gen Con. Prave se dve liste sa razlicitim kasterom za svaku poentazu, pa pred rundu odlucis sa kojim ces da igras.
DA ne bi zbunjivao ljude, dakle:
Tri liste, tri kastera, 500-625-750
Knight
Re: August Event
Post by Knight »
My only regret is i will get to play only one Epic Warcaster that day :)
This should be one cool tourney.
Resurrection
Re: August Event
Koji su scenariji u opticaju na kraju, oooo organizatori?
Re: August Event
Sutra cemo malo da se igramo scenarija, pa cemo odluciti posle toga.
Resurrection
Re: August Event
Und?
Re: August Event
Poslao sam Ines mail sa propozicijama turnira. Ona treba da se bavi zvanicnom objavom.
Ukratko, igraju se tri od 4 scenarija (koja tri i redosled utvrdjuje se na licu mesta, nakon sto svi predaju svoje liste):
Mosh Pit
Destruction
Break the Line
Potrudicu se nekako ove nedelje da napravim objektive za Destruction (nesto mi se cini da ce to biti gomila kartonskih kutija na kojima pise 'unutra je warjack'). I bicu tuzan ako se ne bude igrao.
Od ostalih stvari:
Pobednik se gleda prema broju Tournament Poena aka pobeda. Racunace se i VP razlika (na kraju svake partije dobijas broj VP-a koje si ubio, pa oduzmes VPe koje je protivnik ubio tebi), za razvrstavanje igraca sa istim brojem pobeda.
Vreme za partiju je 90, 105 i 120 minuta. Kad istekne vreme igra se do kraja kruga.
Vreme poteza nece se strogo kontrolisati, ali apelujemo na ucesnike da sami paze da ne odugovlace, i da se drze na oko 10-15 minuta po potezu.
Sta jos ima bitno da se utvrdi?
Resurrection
Re: August Event
Ne kraju je 8.8 ili 9.8 i koliko sati?
Re: August Event
9. VIII 2009.
Za sate nisam siguran. Ono, ne bi bilo lose da pocnemo oko 11h, dakle najaviti pocetak sat vremena ranije da bi ljudi dosli...
FGSerbia
Re: August Event
Post by FGSerbia »
Shall we say a 12.15 start as the club opens at noon?
Just as an aside. The voting for the tournament actually listed as many votes for the 500 pt simple event as it did for the 3 match "masters" event. I think the Masters is a much better idea but for those who may turn up and wanted something a little less heavy I do still suggest we include the Assassins scenerio into the mix so first time tournament players have a chance of playing a scenerio they have already practiced.
Re: August Event
Rick, every scenario also plays as caster kill. I played three games with Bojan the other day and the scenario played no impact at all, since all matches were over by turn three... Basicaly scenarios are used to resolve the winner if both casters survive...
Resurrection
Re: August Event
Shunka wrote:Rick, every scenario also plays as caster kill. I played three games with Bojan the other day and the scenario played no impact at all, since all matches were over by turn three...
Iznenadjenje?
Narano da ce biti cesce pobede na kill ali je interesantnije kad postoji i drugi nacin da pobedis i sprecava bezaje protivnika po stolu.
mladjano bugarce
Re: August Event
Par nedoumica koje imam vezano za trunir :
Sta je bolje za Epic Vlada - Kajazu Assasins ili Iron Fang pikemen?
Sta ide bolje uz P. Vlada - Devastator ili Beast?
Re: August Event
1) oboje :twisted:
2) devastator za scenarije, beast za pure killines :twisted:
Resurrection
Re: August Event
Ocemo rezultate!
FGSerbia
Re: August Event
Post by FGSerbia »
Clarification on the Black 13th stacking damage;
http://www.privateerpressforums.com/ind ... ack+damage
mladjano bugarce
Re: August Event
What is the strengh of the B13 first hit?
How far was that troll you hit?
FGSerbia
Re: August Event
Post by FGSerbia »
Pow 10+2d6 first hit.
Pow 11+2d6 2nd hit.
Pow 12+2d6 3rd hit.
Pow 13+2d6 4th hit.
Pow 18+2d6 chain attack.
Distance was about 20" away.
mladjano bugarce
Re: August Event
That`s the way things work concerning power of the hit. Thank you for the clarification.
Did you use long shot or only snipe + movement for that shot?
Resurrection
Re: August Event
Resurrection wrote:Ocemo rezultate!
FGSerbia
Re: August Event
Post by FGSerbia »
When I zapped painbringer's impaler it was snipe plus long shot.
