Hordes MK2
Re: Hordes MK2
Dodatak za field test:
http://privateerpress.com/files/HORDES% ... te%202.pdf
Od sada sa bistova se moze skinuti fjuri posle njihove frenzi aktivacije
http://privateerpress.com/files/Model_Update.pdf
Kamencici opet lece konstrukte, a ne mogu da uocim sta su Krugeru promenili.
FGSerbia
Re: Hordes MK2
Post by FGSerbia »
Hmmm,
I think the word "update" should be replaced by the sentence "rubbing salt into Skorne's already grevious wounds".
Hexeris: +1 MAT, a completely redundant change on a completely useless caster.
Absolonia: 2 new spells and some new abilities, a complete overhaul and now she's fecking brilliant.
Bojan.... feel like collecting another army...? As a great selling point - now they're really challenging.
mladjano bugarce
Re: Hordes MK2
Post by mladjano bugarce »
Skorne is really not that bad after few readings. The only problem they have is that they have very few competetive lists and it`s not much fun to play the same list all the time.
FGSerbia
Re: Hordes MK2
Post by FGSerbia »
No they are. Their warlocks have all been hit whether they were competitive or not.
FGSerbia
Re: Hordes MK2
Post by FGSerbia »
The latest update is out.
Mulg was this week's jackpot winner with extra spd, str and damage boxes and usefulness in his animus. Molik Karn was this week's held down against his will and gang raped. Rhyas and Kromac were revamped and are slightly less than utter rubbish now; Kromac's feat is independent of FOC or Fury and Rhyas has 'sprint' instead of 'turn incoporeal' and get butchered by any of the 3 million magic weapons there are now in the game.
Re: Hordes MK2
Ima li neki link?
BoltaFodda
Re: Hordes MK2
Post by BoltaFodda »
G-de je tu Rhyas?
Resurrection
Re: Hordes MK2
Post by Resurrection »
Rijas je u updejtu od pre nedelju dana.
FGSerbia
Re: Hordes MK2
Post by FGSerbia »
I see Skorne got nerfed again...:whistle:
mladjano bugarce
Re: Hordes MK2
Actually, they got really improved.
FGSerbia
Re: Hordes MK2
Post by FGSerbia »
I know - but tell anyone!!! We're trying to keep it quiet.
Resurrection
Re: Hordes MK2
Jopet updejt.
Mrzi me i da igram protiv hordi kad mi treba 4 otvorena pdf-aa da bih ispratio sta se desava.
http://files.privateerpress.com/hordes/ ... 091223.pdf
Re: Hordes MK2
Meni ne pomazu ni 4 PDFa :?
Mislim da cu sacekati finalnu varijantu. Dotle cu da se igram cudnih igara :D
Resurrection
Re: Hordes MK2
Sad je sve u ovom jednom samo sto sad ljudi ne znaju sts se sve izmenilo.
EDIT:
Calandra, Long Riders, Kromac, Morvahna, Mohsar, Morghoul, Makeda2, Hexeris, Xerxis, Mordikaar, Bronzeback, Gladiator, Ancestral Guardian, Extoller Soulward, Lylyth2, Thagrosh2, Warmongers, Warspears, Dahlia, Brine, and Snapjaw.
Mladizmaj
Re: Hordes MK2
Post by Mladizmaj »
http://privateerpress.com/files/Hordes_Jan_29.pdf
Mislim da je ova konacna verzija na kraju fild testa.
Gledao sam samo legiju i bas je bilo nekih neocekivanih nerfova. Mnogo stvari su nerfovali, a samo po nesto boostovali. Vayl je opet prosecna, shredderi su losiji ( nikad nisam kapirao da su bili nebalansirani ), deathstalker je mnogo losiji itd.
Re: Hordes MK2
First glance:
Legija i circle dobili kick in the groin, skorna i trolovi ojacani, i sada se svi igraju lepo i ujednaceno, i zaista ne bih mogao reci da je neka Hordes frakcija, na prvo citanje, mnogo jaca od drugih.
Sto naravno znaci da su sve zajedno, cini mi se, jedan stepenik ispod warmachinea...
Re: Hordes MK2
Okay, scratch that. Circle is back in black, samo ce da se igra poprilicno drugacije nego na stari nacin. Kao mamojebna all melle frakcija sa druidima i overseerom. Uh, i baldurom i mohsarom.
Re: Hordes MK2
Verovatno bi sa 4 knjigom horde trebalo da se izjednace po snazi sa masinama. Jedino se bojim da ce masine stalno da beze za jednu knjigu :(
Knight
Re: Hordes MK2
Post by Knight »
Circle je zapravo jedina frakcija Hordi koja ima sta da trazi u partiji protiv Warmachina, ostali mogu eventualno da ti jednom prodaju foru i to je to...
Moshar ispade veliki bog rata u Hordama, armor debuff je realno jedino sto im je nedostajalo kao frakciji, and guess what - sada zapravo mogu da gase debele dzekove. Naravno, kako to izgleda u praksi videcemo za mesec - dva...
BoltaFodda
Re: Hordes MK2
eLylyth nema vise bullseye i arcane amplifier. A ja je igrao na skorasnjem turniru oslanjajuci se prvenstveno na te dve osobine, i dobio dobre savete od Bojana i Duleta na tu temu... a sad cvrc. Pa, bar sam je igrao takvu.
pThagrosh >> eThagrosh.
Angelius dobio vrlo utilitaran animus, Seraph dobio jos poen fury...
Jel ovo konacna verzija?
mladjano bugarce
Re: Hordes MK2
Naravno da nije,zato dok ne izadje knjiga ja to nista ne bi kupovao. :D Usput,sto ne dodjes neki put nedeljom da se igras ili subotom kada smo kod toga. Trenutno najkompetetivniji kasteri Legije su e Thargosh i Sajrin.
BoltaFodda
Re: Hordes MK2
Hmmm... potrudicu se, ali zivot + posao mi nesto zakidaju na vikendima.
eThagrosh je dobio samo ono autoobaranje kroz scourge, dok pThag ima mnogo sta vise... animus za dz i slicno...
Mladizmaj
Re: Hordes MK2
Post by Mladizmaj »
BoltaFodda wrote:Hmmm... potrudicu se, ali zivot + posao mi nesto zakidaju na vikendima.
EThag nije toliko dobio koliko su svi ostali izgubili. Nacin igranja legije se skroz promenio od mk1. Po meni licno jedini caster koji je imalo kompetitivan je EThag, Saeryn se toliko promenila tokom fildtesta da joj nije ostalo nista od starih dobrih fazona, svi kazu da je i dalje druga po jacini od svih legiskih kastera ali meni to neizgleda tako. Vayl je bila kandidat za drugo mesto u toku testa ali su i nju na kraju nerforali gde je bila najaca a pri tome je zadrzala svoj crap feat. Posto su sve nerforali EThag je ostao superiorno da vlada kao najkompetitivnij od svih castera iz everblitovog stada.
Re: Hordes MK2
10 poena za fury 4 treshold 9 zver 8O :?: :!:
Re: Hordes MK2
ovaj vredi svaki poen, dalibore... jaci je od nightmarea, a to svasta govori, jos kad circle nabaca buffove na njega, i on ima reach, i ode kad ubije...
jede i pesadiju a resava stari circle problem o ubijanju heavija... jednostavno obicni warpwolf je prevazidjen sa ovim cudom, cini mi se...
Knight
Re: Hordes MK2
Post by Knight »
mat 6 je jedina zamerka (i to samo protiv hordasa) ali da, ovaj momak ce se itekako igrati.
Re: Hordes MK2
Ima sada dosta stvari koje nabacuju fjurije.
Naravno da cu ga voditi :)
Re: Hordes MK2
Nove jedinice za Circle
Re: Hordes MK2
Novi minionski kaster i solo
Re: Hordes MK2
Dooobrrrooo, Baldur je malo dete, OVAJ cika sadi sume :D :lol: 8-)
The enigmatic Circle warlock Cassius the Oathkeeper is bound to serve the ancient Wurmwood, Tree of Fate. Wurmwood passes harsh judgment on all who fall beneath its branches, harvesting their souls to fuel Cassius’ magic. Those who stand against the Circle Orboros face an unpredictable battlefield, as whole forests spring fully-grown from the earth, entrapping enemies within their deadly green depths.
