Samo prate liniju koju imaju ostala marinacka vozila. To rade sa svima. Marinacka vozila su cetvrtasta pa su im i takvi avioni. E sad meni se genrealno svidja koncept svemirskog Higins camca, ali kada je model veci, kao onaj FWov, onda ima nekog smisla, ovako je kretenski.
Forge World-ov Caestus Assault Ram...mator model.
http://www.forgeworld.co.uk/Warhammer-4 ... T-RAM.html
Mrzelo ih da dizajniraju novi. :D
Ovaj ima jos vise resetkica :D.
ugust 2nd: Stormwolf/StormFang Combo-kit
August 9th: Dreadnought/Bjorn Combo-kit (includes new "freeze/cold" cannon and DCCW weapons)
August 16th:
- WolfLord (Frost axe/pistol)
- IronPriest (Servo-harness w "freeze/cold" weapon, T-hammer, pistol)
August 23rd:
- Codex Space Wolves
- Artbook
August 24th:
- Long Fangs ("freeze/cold" cannons)
- Rune Priest (Termy, (helmet/bare heads) Force staff, SB)
Hm....freeze/cold oruzija....to sam negde vec video....a da! :D
https://www.youtube.com/watch?v=SRH-Ywpz1_I
ako blood angels posle dobiju neko blood-spitting oruzje... :roll:
Detaljnije o novim Space Wolves:
General Information about Codex: Space Wolves
Sagas are out, replaced with Warlord Traits
6 new Space Wolves Tactical Objectives
New Space Wolves Psychic Discipline: Tempestas (Source didn't get any actual rules though)
'Space Wolves Unleashed' Detachment FOC:
Identical to standard FOC, except may take up to 6 HQs
May re-roll Warlord Traits
Each unit joined by an Independent Character rolls a d6, on a 6+ that unit gains Outflank. Troops choices get +2 on this roll.
Great Company Formation:
1 Wolf Lord
1 Wolf Guard Battle Leader
1 unit of Wolf Guard
5 units of Grey Hunters
1 unit of Wolf Scouts
5 units chosen from [Blood Claws, Swiftclaws, or Skyclaws]
2 units of Long Fangs
Grants two special rules, source did not get them
Space Wolves Relics (Source didn't get rules, just name and type of item)
Armor of Russ (Armor)
Bite of Fenris (Bolter with two fire modes)
Black Death (Frost Axe, Rule: Whirldwind of Death)
Helm of Durfast (Wargear)
Fangsword of the Ice Wolf (Frost Sword)
Wulfenstone (Wargear)
Logan Grimnar - Lord of War - Points = Land Raider
Epic new model, comes with a sort of grav-chariot called 'Stormrider' pulled by two enormous Fenrisian wolves, but he can be used without it as well.
Stormrider - Points = Land Speeder + 20
Treated as a vehicle, didn't get AVs, has a 4+ Invulnerable save and cannot suffer Penetrating hits (all Pens are reduced to Glances).
Gives Logan 4 S5 Ap- attacks on a turn when he charges.
Logan loses Deep Strike if he takes Stormrider
Lots of other cool rules, but didn't get those.
Njal Stormcaller
No new model shown in codex
Looked to be mostly the same, no specific information
Ragnar Blackmane
Also looked to be mostly the same, no specific information
Ulrik the Slayer
Canis Wolfborn
Again, looked to be mostly the same, no specific information
Harald Deathwolf
The resin Thunderwolf Cavalry character model assigned a name
Didn't get the rules/stats.
Bjorn the Fell-Handed
Epic new plastic model, part of a box that makes a regular SW Venerable Dreadnought, Bjorn, or a new special character Dreadnought named 'Murderfang'.
No longer becomes a VP objective when he dies.
Wolf Lord
Mostly the same, no specific information.
Rune Priest
Mostly the same.
Specifically noted as starting at Mastery Level 2.
No other information.
Wolf Priest
Blood Claws Pack
12 points per model
Wolf Guard Leader upgrade available
May take a Stormwolf as a Dedicated Transport
Lukas the Trickster
No specific information, probably the same.
Grey Hunters Pack
14 points per model with a Bolter and Bolt Pistol
Any model may add a Close Combat Weapon for +2 points
One Special weapon per full five models still, but costs raised to same as C:SMs
Wolf Guard Upgrade available
Dreadnought
Not sure, but might have an option for a Helfrost Cannon
Otherwise similar to old codex, no other information
Murderfang - Points = Vindicator + 20
Crazy-awesome special character Venerable Dreadnought
Wolverine + Dreadnought + Extra Insanity = Murderfang
WS5 BS3 S6 F12 S12 R10 I4 A4 HP3
Wargear:
Searchlight
'Murderclaws' with underslung Storm Bolter and Heavy Flamer
Special Rules:
Furious Charge
It Will Not Die
Rage
Rampage
Murderlust
Options:
May take a Drop Pod
'Murderclaws' - A pair of enormous, even for a Dreadnought, Lightning Claws made of 'alien ice that never melts or loses sharpness'
S7 AP2 - Melee, Master-Crafted, Shred, Specialist Weapon
Definitely has an option for a Helfrost Cannon
Can also have an enormous Power Axe and Storm Shield, said to look incredible.
Some special rules, but didn't get them
Iron Priest
Options appeared to be nearly identical to old codex, probably a couple points changes though
Can take a unit of 1-5 Servitors, rules also looked the same as old codex
Lone Wolf
Rules nearly identical to old codex, didn't get points cost
Owning player no longer gains a VP if they die
Wolf Guard Pack
This unit is just for Wolf Guard in Power Armor.
Same cost per model as before
Have a similarly wide array of options as in the old codex, couldn't get specifics though
Wolf Guard Terminator Pack
What it says on the tin, Wolf Guard in TDA
33 points per model with Storm Bolter and Power Weapon base
Options (any model in the unit can take these, this isn't all of the options though):
Thunder Hammer & Storm Shield - 15 points
Pair of Wolf Claws - 15 points
Power Fist - 10 points
Frost Axe - 5 points
Frost Sword - 5 points
Combi-weapon - 5 points
Heavy Flamer - 10 points
Assault Cannon - 20 points
Cyclone Missile Launcher - 25 points
Arjac Rockfist
Wolf Scouts
Source totally forgot to look at them. Sorry guys.
Swiftclaw Pack
-5 points per model from old codex
Skyclaw Assault Pack
-3 points per model from old codex
Thunderwolf Cavalry
-10 points per model from old codex
As noted previously:
Stormwolf - Fast Attack - Points = Land Raider minus 35
BS4 - F12 S12 R12 HP3 - Vehicle (Flyer, Hover, Transport)
Wargear:
Twin-linked helfrost cannon
Twin-linked lascannon
Two twin-linked heavy bolters - May be replaced with a Skyhammer launcher for free, or two twin-linked multi-meltas for 20pts
Ceramite Plating
Special Rules:
Assault Vehicle
Power of the Machine Spirit
Transport:
Transport Capacity - sixteen models
Fire Points - none
Access Points - One ramp at the front of the hull
Stormfang Gunship - Heavy Support - Points = Land Raider minus 30
BS4 - F12 S12 R12 HP3 - Vehicle (Flyer, Hover Transport)
Wargear:
Helfrost destructor
Two twin-linked heavy bolters - May be replaced with a Skyhammer launcher for free, or two twin-linked multi-meltas for 20 pts
Two Stormstrike missiles - May be replaced with a twin-linked lascannon for 15 pts
Ceramite Plating
Special Rules:
Transport:
Transport Capacity - six models
Fire Points - none
Access Points - One at rear of the hull
Helfrost cannon
dispersed - R24" S6 AP3 Heavy 1, Helfrost, Blast
focussed - R24" S8 AP1 Heavy 1, Helfrost
Helfrost destructor
dispersed - R24" S6 AP3 Heavy 1, Helfrost, Large Blast
focussed - R24" S8 AP1 Heavy 1, Helfrost, Lance
Helfrost - If a model suffers one or more unsaved wounds from this weapon, it must pass a separate Strength test for each wound suffered or be removed from play
Land Speeder Squadron
Same as Codex: Space Marines
Fenrisian Wolf Pack
Nearly identical to old codex, no specific information
Long Fangs Pack
Couple of new options for squad leader, who is now called a 'Long Fang Ancient'
Source did not get if they had an option for Flakk Missiles
Might be able to take a Stormwolf/Stormfang as a Dedicated Transport, not sure about this though
Otherwise nearly identical to old codex, no other information
Predator
Whirlwind
Vindicator
Land Raider and variants
Rhino and Razorback
No Helfrost Cannon option for the Razorback, same as Codex: Space Marines
Drop Pod
Notable Exclusions from Codex: Space Marines
No Stormtalon
No Storm Raven
No Hunter or Stalker
Space Wolves AA options: Stormwolf, Stormfang, ADL gun emplacement, and Allies
Saturday 9th July sees the release of the New Space Wolves Codex
Codex: Space Wolves
•104 page full colour hardback codex containing new Warlord Traits and Relics, new Space Wolves Detachments, Formations and Tactical objectives. Along with new background material, art work and miniature show case.
•Features Background, rules and artwork for all new Space Wolves miniatures
•A great follow up sale to Sanctus Reach: Stormclaw.
• RRP £30
Space Wolves Venerable Dreadnought
•A fantastic new Space Wolves multipart plastic kit that makes either a Space Wolves Venerable Dreadnought, Bjorn the Fell-Handed or Murderfang (a new special Character, a Wolfen in a Dreadnought)
•Each Miniature has masses of details, Space Wolves iconography and a range of weapons (several totally new)
•RRP £33
Warhammer 40,000 Datacards: Space Wolves
•Contains 7 new Space Wolves Tempestas disipline Psychic cards and 36 tatical objective cards including 6 new Space Wolves themed ones.
•RRP £5
•Available while stocks last
Tom Kirby, CEO of GW, stepping down from position...
http://investor.games-workshop.com/wp-c ... e-2014.pdf
CheMilan
Post by CheMilan »
Kul mozda vrate vukovima Jaws :D
...pa i nisi bas najbolji...
Bata Bole
Post by Bata Bole »
Pitanje za magove:
Koji bi varijantu trebao da uzmem ako bi uzimao 3 flyer-a za vukove:
- koliko transporter varijanti a koliko ovih sto kao pucaju?
- koliko sam razumeo oni svi idu u heavy choice pa ih može samo tri u standard foc?
- jel treba uopšte tri flyer-a?
EDIT: sta sve neću da radim ne bi li izvukao nereseno protiv subota koji sedi iza ogradiće i puca :geek:
Istorijski wargame ;)
Mislim da niko od magova :D jos nije analizirao nove vukove, posto ce se na ETC-u igrati stari. Sacekaj jos koji dan, pa cemo ti reci sta da uzmes protiv poganih robota ;).
Ridcully
Post by Ridcully »
Ne znam sta da mislim o modelu, za sad mi deluje smesno.
Mada Deda Logan izgleda cool. :)
Deda Mraze, Deda Mraze...ne skreci sa staze...
Odlican je!
Imam novi Space Wolves codex, pa koga zanima link neka mi posalje pm.
Izgleda da se sprema novi Grey Knights codex...
http://descansodelescriba.blogspot.com/ ... l?spref=fb
Nije izgleda nego 100%. (insajd informejsn) ;)
White Dwarf - Issue No. 30 - 36 pages of everything that is exciting and new in the Hobby this week. RRP £2.40
•Codex: Grey Knights - contains all new Grey Knights Warlord Traits and relics, plus Detachment and Formation along with unique Tactical Objectives. Background and rules for the full range of Grey Knights miniatures. RRP £30
•Warhammer 40,000 Datacards: Grey Knights - Available Whilst Stocks Last - If you require this item you will need to order it from the Games Workshop webstore as soon as it is available for pre-order on Friday 15 August at 7.00pm UK time. This is due to the very limited numbers that are available.
•Grey Knight Strike Squad - a great value new box set containing 10 existing Grey Knight Purifiers. RRP £37.50
•Space Wolf Sky Claws - a new multipart plastic box set that combines existing components from the Space Marine Assault Squad and Space Wolves pack that creates 5 Space Wolf Sky Claws with multiple weapon options. RRP £22.50
•Space Wolf Long Fangs - a new multipart plastic box set that combines existing components from the Space Marine Devastator Squad and Space Wolves pack that creates 5 Space Wolf Long Fangs with multiple weapon options. RRP £22.50
•Warriors of the Fang - Available Whilst Stocks Last - contains 1 x Space Marine Commander; 5 x Space Wolf Sky Claws; 5 x Space Wolf Long Fangs; 20 x Space Wolves; and 1 x Drop Pod - a great way to turn your Sanctus Reach Space Wolves into a bigger army. This box set gives about 20% added value against purchasing everything separately. RRP £105
•Sanctus Reach: Hour of the Wolf - Available Whilst Stocks Last - this 112 page, full colour hardback narrative campaign supplement is part of the Sanctus Reach series of products. It details the Imperial counter-attack to reclaim Alaric Prime, led by Great Wolf Logan Grimnar and includes 5 Planetstrike missions. RRP £30
A kada ti stize nova knjiga GK?
Sad
Kad bre sad?
cek, nema inkvizicije? oce oni mozda da dobiju zasebnu knjigu??
oni imaju zasebnu knjig...zicu codex:inquisition
U ponedeljak ću naručiti.
Space Wolves : Champions of Fenris supplement detalji :
http://bloodofkittens.com/blog/2014/08/ ... t-details/
Ja koliko vidim novi Svemirski vuci sada imaju drop pod u fast attack izbor, e sad sta to znaci pa evo recimo da mozete da uzmete 3 centuriona i tigurijusa ili chapter mastera koji dolaze iz DS, SUCK THAT XENO SCUM :D
Ala radi Torrent of Fire, sve u sesnaes'! :D
(Inace, ne samo Drop Pod-ovi, vec i Rhino-i i Razorback-i)
Luka, ajd' malo da se odmorimo od power gaming-a, please...
Daj bar do nove godine da se igramo bez suludih kombinacija u listama...
Probaj malo da igraš nešto fluffy, što nije ultimativno jako, što ti ne garantuje pobedu i pre početka partije, i što nema više od 9 WC (i to sa 6 na D6)
Pri tom nisam video tamo, tek sad vidim da su i oni to izbacili, sto bi rekli mogu i neki paladini sa Dragom kad vec nemaju Mordraka vise cisto da nam Sutic ne place :D A umesto nekog dreadknighta koji skace moze neki dreadnoght sa stitom i sekirce :P
"Dear Logan,
I would like to extend my thanks for your loan of a drop pod in our last battle. My battle brothers in the Centurian Devestator Cadre were most greatful. It allowed me to extend my focus into other matters besides their transportation.
Our troop reported hearing the heretics screaming obscenities such as "totally OP" and "fucking bullshit" but truely these are but the rantings of madmen. And all true servants of the Emperor find delight in such nonsense.
I look forward to our next deployment together. Sincerely
Chief Libarian Tigurius"
Warhammer Visions magazine will end publication at year end.
Dugo im je i traj'o... :lol: :lol: :lol:
Ej, sekiracijo vranjanska, eno izasao ti model oca vulkanskog....
Bice jedan u Srbiji obecavam.
Milinovicu, cela GK armija sad radi kao tvoj dataslate od danas...
pa da... zasto bi padala jedna jedinica, kad mozemo da napravimo da pada cela vojska na 3+, i jos da trci i puca. A FoC iz snova...jedna trupa i 4 elite.
Oni su majstori teleporta, brzog udara i uz sve to su elitna armija. Ovo je logicno, zar ne? I bice jeftinija armija uz sve to.
dada, i glupo je da ih pogodi neka pita dok su onako skupljeni posle deep strike-a, sto se ne bi malo rasirili :wink:
Ajde Debeljko samo ti krivo sto ce neko drugi da se igra sa njima, a ne ti.
"Neko drugi" se raduje :)
Histericni Istoricar wrote:Ajde Debeljko samo ti krivo sto ce neko drugi da se igra sa njima, a ne ti.
nemoj to dvaput da kazes :)
predpostavljam samo da ce draigo biti lord of war, sto je ok. Draigo, baneblade, sve mu dodje na isto :roll:
