Turnir ce se odrzati sredinom avgusta u prostorijma kluba (Budimska 10a) i trajace dva dana!
Ucesce je 300 dinara, 500 za one koji nisu clanovi kluba.
Igrace se ukupno cetiri runde, po dve svakog dana, koje ce trajati po tri sata.
Da ne duzimo mnogo, slede generalne informacije:
Raspored:++BASIC RULES++
• Armies will consist of 1850 points or less.
• Players MUST use the same army list throughout the tournament.
• New codices, supplements, campaign supplements and White Dwarf updates that are released after August 1st, 2015
will not be allowed in this event.
•"Everything goes!"- There are NO restrictions regarding a number of the Detachments that may be used in one army.
• You MUST specify which Detachment is your Primary Detachment.
• Codex specific Detachments from Codices are ALLOWED.
• You may ally together codices (supplements) with the same parent book, but not a book with itself. (example: Tau
Empire can be allied with Farsight Enclaves, or Black Legion can be allied with Chaos Space Marines)
• Fortifications will use the updated rules presented in "Stronghold Assault".
• Lords of War Units from "Escalation" and codices/army books are ALLOWED.
• Formations are ALLOWED.
• Other Dataslates are allowed in this event. (except for APOCALYPSE Dataslates)
• Forge World units, army lists and rules that have "Warhammer 40.000 approved" stamp are allowed.
• Apocalypse units, army lists and rules are NOT ALLOWED.
• Forge World units, army lists and rules that have "Experimental Rules" stamp are NOT ALLOWED.
• Forge World army lists and material from the "Horus Heresy" books WILL NOT be allowed in this event; however
players may still use these Forge World models to represent a unit(s) in their army.
• The Warhammer 40,000 7th Edition Rules and all relevant Games Workshop Errata and FAQs will be used. In the case
of a conflict between a printed version of a Codex and a Digital version the most recent update or FAQ will take
precedence.
• The latest ETC 2015 Errata and FAQ may be used to resolve additional rules disputes.
• Each player should bring a total of SIX (6) tactical markers based on 40mm circular bases. They have no effects on the
game other than to mark a point on the battlefield.
• Each player should bring a Warhammer 40,000 rulebook and the codex (or codices) represented in their army and all
materials needed to play a game/report the results - including dice, measuring devices, templates, tactical objective
cards and a writing implement.
• A separate printed army list is required for the judges and for your opponents (minimum of 2 copies required).
++MISSIONS++
Mission No 1. MAELSTROM OF WAR: THE SPOILS OF WAR
Mission No 2. MAELSTROM OF WAR: TACTICAL ESCALATION
Mission No 3. MAELSTROM OF WAR: CONTACT LOST
Mission No 4. MAELSTROM OF WAR: CLEANSE AND CONTROL
• Mysterious Objectives will not be used in missions.
++SCORING SYSTEM++
• Victory points scored by each player are accumulated from Malestorm of War Objectives (Tactical Objective Cards). An exception is that a "wiping-out" player receives 20 game points, while a "wiped-out" opponent gets 0 game points.
+GAME POINTS (0-80 TP)+
• At the end of each game players should calculate the amount of Victory Points (VP) they scored in this round, subtract VP earned by their opponent and consult the chart below:
VP Difference:
0 / 10-10
1-2 / 11-9
3-4 / 12-8
5-6 / 13-7
7-8 / 14-6
9-10 / 15-5
11-12 / 16-4
13-14 / 17-3
15-16 / 18-2
17-18 / 19-2
19+ / 20-0
TIEBREAKER: VP's scored by player will be used as tiebreaker.
+SPORTSMANSHIP POINTS (0-8 (+2) TP) AND FAVORITE OPPONENT VOTE+
• After each qualifier game, you will be required to evaluate your opponent’s sportsmanship. Secretly, choose one of the
following marks:
-Perfectly Decent Game of Warhammer. This should encompass a majority of your marks. This covers most normal
games of Warhammer. Your opponent was relatively sporting, came prepared to play and put forth a good effort to
amicably resolve rules disputes. Average marks are worth two (2) Sportsmanship points.
-Just A Terribly Awful Game! While difficult to describe, these games are bound to happen. Reserved for the worst of the
worst, you should only ‘award’ this mark in the direst of circumstances. This mark should be an evaluative negative on
your opponent’s sportsmanship only and should NEVER be a reflection on the final results of the game. Negative marks
are worth zero (0) Sportsmanship points. Multiple negative marks can possibly result in disqualification. Giving large
number of these marks may lead to penalty. (look "Refereeing")
• Favorite Opponent Voting: After the 5th game, in tandem with the results for that game, players will have an
opportunity to vote for their Favorite Opponent of the tournament. This vote should be awarded to the player that best
exemplifies the Warhammer 40K hobby and provided a truly enjoyable game. This vote is mandatory and will be part of
your final results sheet. Your favorite opponent will receive +2 TP in addition to his other Sportsmanship points earned
during tournament.
+ARMY APPEARANCE POINTS (0-20 TP)+
• +3 Gaming accessories
The player has all gaming accessories needed (army list, codices, tape measure, dices, templates, objective markers, pen,
paper)
• +8 Painted
The forces are painted. All models have at least three colors painted onto them. (EXCLUDING UNDERCOAT)
• +3 Fully Painted
The forces are FULLY painted. All models in the army are completly painted. (INCLUDING SHADES AND HIGHLIGHTS)
• +3 Based
All bases of the miniatures are painted and textured in some manner. The baseline for texture is flock as a minimum.
Black edges are acceptable, providing the tops are textured and painted.
• +3 Squad markings
All models have had unit details and associated Iconography added to them. Each unit is clearly distinguishable from
others by the use of these markings. In armies or units that do not use formal iconography, the unit is distinguishable by
some other clear marking, such as tattoos, skin striping, uniformly painted trappings or base scenery.
+FINAL SCORE+
• Winner of the tournament will be the person who manages to collect the most TP from these three categories:
1. FOUR GAME ROUNDS 0-80 TP
2. SPORTSMANSHIP POINTS 0-8(+2) TP
3. ARMY APPEARANCE POINTS 0-20 TP
• TOTAL OF 0-108 TP
Subota, 15.8.
Okupljanje: 11h-12h
Prva bitka: 12h-15h
Pauza za rucak: 15h-16h
Druga bitka: 16h-19h
Nedelja, 16.8.
Okupljanje: 11h-12h
Treca bitka: 12h-15h
Cetvrta bitka: 16h-19h
Dodela nagrada: 19.30h
Prijavljeni:
1. Predrag Urosevic
2. Milan Popovic
3. Dusan Vasic
4. Predrag Vasiljevic
5. Dejan Milinovic
6. Petar Jovanovic
7. Igor Uzelac
8. Djordje Sutic
9. Nikola Nikolic
10. Rastislav Vukovic
11. Miroslav Poznic
12. Dimitrije Stevanovic
13. Miljan Otovic
14. Nemanja Jovicic
15. Nemanja Dojkic
16. Nikola Radojcic
17. Milos Djurovic
18. Miljenko Jurjevic
19. Nemanja Zebeljan
20.
PITANJE ZA IGRACE - pogledati poll
(molimo igrace da ne menjaju svoju odluku neposredno pred turnir, kao i da ne glasaju oni koji ne planiraju da se prijavljuju)
P.S. Ukoliko Vas jos nesto zanima, pitajte me na PM.
