Histericni Istoricar wrote:Ko tvoje dupe rekao bih.
Hvala na komplimentima ali moje dupe je ipak vece od toga, a i mislim da mi ne bi ste dozvolili da radim deepstrike sopstvenom guzicom na sto ;)
no, nazad na temu, na onim slikama se vidi da je baza taman marginalno veca od standardne ovalne, i skroz okrugla. pitam se sta ce jos staviti na ovu bazu...
Hypodermic wrote:10 cm baza... sta bre?! koliko je to cudo?!
two releases next week for 40k and the rest is hobbit and some bases.
Shield of Baal box set $125 25 miniatures, campaign supplement, and rules
Shield of Baal: Deasthstorm $24 hardback 125pgs
Contents of the box set
Small Rulebook with Blood Angels on Front
Campaign Supplement -40pages
3 missions, rules and dataslates for each model, two formations- Strike Force Deathstorm and Phodian Annihilation Swarm
Blood Angels Strike Force- 12 models
Captain Karlean, 5 terminators, 5 deasth company, and a death company dreadnought
Phodian Annihilation Swarm- 13 models
Spawn of Cryptus, 8 genestrealers, 3 warriors, and a carnifex
The Spawn of Cryptus is a very large Broodlord towering over the height of warriors. Both the Spawn of Cryptus and Captian Karlean are new models.
Petar
Post by Petar »
Behold! The mighty Stormhammer!
yeah, it's nice, ali je samo za 30k ;)
Petar
Post by Petar »
A znam da je za 30k. Ipak, tenk je tenk, kako god okrenes :-)
Kao što već znate nova kampanjsa limited edition kutija:
The set will be roughly £80/$120/€100 and comes with 25 miniatures in total:
•Captain Karlaen
•5 Terminators
•5 Death Company
•Death Company Dreadnought
•Spawn of Cryptus (Broodlord)
•8 Genestealers
•3 Warriors
•Carnifex
ma da li on to ima vampirske zubice...
Hej BA igraci, sta kazete na to da menjate baze od vasih 30-ak, 50-ak jump packera za nove? :P
ah, to su te nove 35mm baze... yeah, right, pazi kako cu da menjam baze na svojim jump modelima - not :P ako ikada bude bilo bitno prosiricu im donji edge glinom i to je to :)
edit:
vise me zanima da li ce to biti samo za death company jumppackere, za sve jumppackere (onda moraju svi oni boksovi da se resizeuju takodje od svih marinaca :mrgreen: ) ili nesto trece... cisto sumnjam da ce te terati na gw turnirima da menjas baze, doduse ;)
Navodno iz neke nove kampanje.
Beta to ti je iz ove gore navedene kampanje Shield Of Baal: Deathstorm...
And some new things, WH od sledeće nedelje...
Sa sve novim :?: Tactical Squad-om..
tactical squad box koji ima heavy flamer... odd, but interesting. i da li ja to vidim gravgun na jednom? I 35mm baze na svima? 8O
Navodni Cover Page za novu BA knjigu...
Limited edition knjiga
I novi sveštenik...
Meni je mnogo znacajnije to sto vidim da u tactical squadu dolazi tri beaky heads za SM... koje mnogo volem.
Da se Boca ne plaši
The Response from Games Workshop
Thanks for the email.
The new 32mm bases were a design choice made by the sculptors, to make the Death Company look more imposing. There is no specific base that you have to use for the Death Company, so should you wish to mount them on the smaller 20mm bases this is fine, but if you would rather have the slightly larger 32mm base, this is also fine.
Petar
Post by Petar »
Primarh Konrad Curze.
Novi BA
Mislim da je ovo ono što je bolje
+1I when charging, all the army, any turn.
Sanguinary Priests costs about the same as a Wyvern, are HQ, and units they joins get +1WS and FnP. The are IC btw. (sad ako uzima slot onda je to loše, 3 za 1 je OK)
Mephiston is HQ and IC
All units have now Furious Charge
Dante's Axe is +2S, AP2, mastercraft and NOT unwieldy, and he's Eternal Warrior
Jump packs are now only +3 points for DC
Corbule gives to all BA units at 6" +1WS & +1I. Not accumulative with an standard chalice bonus. 120 points, 3 wounds
Bike units can take grav guns. Bike command squads do not exist.
Sternguard and Vanguard as per codex SM but with FC
No special Terminator units
Thyco now does not ingore armour saves. His comb¡ weapon cannot use special ammo anymore.
1 Heavy Flamer for tactical squads, 2 for veterans and no Heavy Flamers in Devastators
Banner allows to reroll failed moral and pinning tests. 12" bubble
Honor Guard is gone from the codex.
sangujnary priests can buy a bike, but not a Terminator armour.
Gabriel is a LoW. Basically the same, but lost his special attack. Now he causes +1 hit, for any 6 to wound.
Furiosos: Same cost, but the claws now cost +10 points. Getting additional attacks rule is gone. Now claws are Sx2, Shred, AP2.
The +1 initiative works always on charge. The Detachment is very nice. As I said before, the I bonus is for the whole army and works every turn.
No FoC unlocking in the codex. Not even the command squad, which is Elite now.
Sanguinor has the cost of a Stormraven. Isn't IC.
The rules are basically the same, but he does not improve the stats of a character anymore. This rule is gone.
Sang guard - the max unit size is now 10. 33 points per model.
No Reclusiarchs
Priests only in hq now, so no lesser version in elites, Priests bolster only for his unit,
COrbulo is HQ, Lemartes is and IC that can only join DC units. Uses an Elite slot. But no use foc when is take for DC.
standard Predators can buy Fast vihicle special rule at 10 points.
Mephiston!
Mephiston has changed a lot:
W3 I5 A4 2+sv
Warlord trait: Adamantium will
Lvl 3 Psyker
Special rules: FC, IC, Fleet, No Fear, Hypnotic Trance: Roll 2D6 if fighting in a challenge: If result is the L of the opponent or more, Mephiston hits on 2+. (Transfixing Gaze?)
Has one unique power: Blessing, he gets S10. He’s an HQ AND Independent Character!
His sword is AP3 he costs about the same as a Heldrake (reduction FTW?)
No Inv for Meph. S and T as a Centurion
Dante and Gabriel Seth are LoW.
Dantes Axe is +2F, AP2, mastercraft and NOT unwieldy.
BTW he id now eternal warrior
No, no jump units as troops
Tactical marines as usual + new options. They can get anti-air missiles BTW. And no more LR as dedicated transports for everybody, just for termies.
No squadrons for Dreads. "Standard" dreads are now Elite, Furiosos and DC dreads too. Librarian dreads are HQ.
o terminator armour for DC. But there are good news, Jump packs are now only +3 points. On the other hand their WS has been downgraded to 4.
No new units. No Centurions and no talons.
Only troop choices are Tactical squads and scouts.
Some changes are:
- Death Company is now elite as DC dreadnought
- Predator Baal is Heavy Support
- Librarian Dreadnought is HQ
- Mephiston is HQ and IC
Chalice gives +1WS
1. Vanguard Veterans cannot charge after DS
2. Only rule is combat squads
3. As I see in the pictures of the codex there is nothing coming after the termi Kit. Lib is separate.
BONUS:
Warlord traits are:
1. Warlod gets Rampage
2. Warlord gets +1 I
3. One warlord's weapong gets mastercrafted
4. Warlord gets Adamantium will
5. Warlord gest Descent of the Angles (Dante's trait)
6. 12" fearless bubble
Relics:
- One jump pack that allows the bearer and his unit re-roll when DS and when other units Intercept -> Snapshots. (25)
- Gives Fear, and fear tests are done with -2 L (10)
- One item that gives an additional warlord trait strategic table. (15)
- One physic weapon +2S, AP4, bearar may re-roll 1 in the psychic phase. If rellod die is a 1, bearer takes one wound. No saves allowed. (10)
- One Master-crafted plasma pistol, that does not get hot. (25)
- One AP2 power sword. (25)
Physic powers are:
Primaris: Blessing. +D3 to A and I to psyker or target character at 12"
1. Malediction. Target unit at 12" takes a Moral test with -2
2. Blessing. Target unit at 18" gets Rage. If they had already that rule, they get +1A instead
3. Blessing. Psyker and his unit get 5++
4. Focussed witch fire. Target makes 2 T tests. Take one W for each failed test. If targed dies, place 5" blast with S4 and AP5.
5. Beam.12" S8, AP1 Lance
6"Blessing. Targe infantry unit, moves 12" in the psychic phase. No charging after this movement.
Fast vehicles are:
Rhinos, Razorbacks and Baal Predators
Special rules for DC: FC, Fearless, Relentless, FnP, Rage. They cannot reroll to wound if chaplain in the unit. Only Astorath gives them this ability.
Detachment is nice:
Mandatory 1 HQ, 1 Elite, 2 Troops
Optional: as usual, but 3 additioanl Elite (Total 4)
Special rule: +1I when charging, all the army, any turn.
New rules in the Codex:
Army Special Rules:
Furious Charge
FOC Changes:
HQ: Librarian Dreadnought
Troops: Tactical Squads, Scout Squads
Elites: Death Company, Dreadnoughts (Death Company and Furioso), Command Squad (Honour Guard are gone)
Heavy Support: Baal Predator
Baal Strike Force Detachment:
Optional: as usual, but 3 additional Elite slots (Total 4)
Special Rule: +1 Initiative when charging, all the army, any turn.
Warlord Traits:
1. Red Rampage: Warlord gets Rampage.
2. Speed of the Primarch. Warlord gets +1 Initiative.
3. Artisan of War: One of the warlord's weapons is mastercrafted.
4. Soulwarden: Warlord gets Adamantium will.
5. Descent of Angels. (Dante's trait)
6. Heroic Bearing: Warlord has a 12" Fearless bubble.
Psychic Powers:
Primaris: Blessing. +D3 to Attacks and Initiative to Psyker or target character at 12”.
1. Malediction. Target unit at 12" takes a Moral test with -2 penalty.
2. Blessing. Target unit at 18" gets Rage. If they had already that rule, they get +1 Attack instead.
3. Blessing. Psyker and his unit get 5++.
4. Focussed witch fire. Target makes 2 Toughness tests. Take one Wound for each failed test. If target dies, place 5" blast with S4 and AP5.
5. Beam. 12" S8, AP1 Lance
6. Blessing. Target infantry unit, moves 12" in the psychic phase. No charging after this movement.
Relics:
1. One jump pack that allows the bearer and his unit re-roll when Deepstriking and when other units Intercept must fire Snapshots. Cost: 25 points.
2. Gives Fear, and fear tests are done with -2 Leadership. Cost: 10 points.
3. One item that gives an additional warlord trait strategic table. Cost: 15 points.
4. One physic weapon +2S, AP4, bearer may re-roll 1s in the psychic phase. If rerolled die is a 1, bearer takes one wound. No saves allowed. Cost: 10 points.
5. One Master-crafted plasma pistol, that does not get hot. Cost: 25 points.
6. One AP2 power sword. Cost: 25 points.
Characters:
• Dante: LoW. Eternal Warrior. Axe is +2S, AP2, Mastercraft, and strikes at Initiative. No longer unlocks Sanguinary Guard as Troops.
• Seth: LoW. Lost his special attack, but now does +1 hit for each 6 to wound.
• Mephiston: HQ. WS6 BS5 S5 T5 W3 I5 A4 L10 2+ Special Rules: Furious Charge, Independent Character, Fleet, And They Shall Know No Fear, Hypnotic Trance: Roll 2D6 in a challenge. If you roll equal to or above their Leadership Mephiston hits on a 2+. Warlord trait: Admantium Will. Level 3 Pskyer w/ unique blessing giving him S10. Sword is AP3. Points: 175
• The Sanguinor: Pretty much the same with a 4++. Rerolls to hit and to wound rolls in challenges. Not an Independent Character.
• Sanguinary Priest: HQ. Independent Character. The unit joined gains +1WS and Feel No Pain. Can buy a Bike, but no longer has access to Terminator Armour. Points: 60
• Corbulo: HQ. Grail gives all units within 6” +1 WS and +1 Initiative. Not cumulative with the standard chalice. 3 wounds. Cost: 120 points.
• Lemartes: Can only join Death Company and takes an Elite slot.
• Tycho: No longer ignores armour saves. Combi-melta can no longer use special ammo.
Units:
• No new units. Terminators and Librarian are separate kits.
• No access to Storm Talon or Centurions.
• Tactical Squad: Usual options from Codex: Space Marines plus new options. They do have access to Flakk missiles.
• Furioso. Same cost as before. Blood Talons are +10 points.
• Reclusiarchs and Honour Guard are gone. Honour Guard replaced by Command Squad.
• Vanguard Veterans cannot assault after Deep Strike.
• Death Company: Furious Charge, Fearless, Relentless, Feel No Pain, Rage. Cannot reroll to wound rolls if a Chaplain is in the unit (that is now Astaroth’s ability). No options for Terminator Armour. WS dropped to 4. Jump Packs are +3 points per model.
• Blood Chalice: +1 WS and Feel No Pain. No longer a bubble just affects the unit.
• Rhinos, Razorbacks, and Baal Predators are Fast.
• Predator Annihilator/Destructor can upgrade to Fast for +10 points.
• Land Raider: No longer a Dedicated Transport.
• Tactical/Sternguard Squad: Gain access to Heavy Flamer (max 2 per unit).
• Sanguinary Guard: 33 points per model. Glaive Encarmines are still mastercrafted. Max unit size is 10.
• Terminators: Access to a banner which allows reroll of failed morale and pinning tests within a 12” bubble.
• Bike squads have access to grav-guns.
Rumors on new rules in the Codex:
• Librarian is the same as Codex: Space Marines. Base 65 points with the following stats: WS5 BS4 S4 T4 W2 I4 A2 L10 S3+.
• Terminators are the same as Codex: Space Marines. Base 200 points with the following stats: WS4 BS4 S4 T4 W1 I4 A2 S2+.
• Captain is base 90 points just like Codex: Space Marines (I’m noticing a trend here).
• There is something weird going on with the Blood Angels FOC on the Games Workshop website. The new Sanguinary Priest is listed under HQ while Brother Corbulo remains under Elites. Death Company are now listed under Elites while Chaplain Lemartes is listed under Troops.
• Land Raiders are still Dedicated Transports (speculation based on the fluff text from page 9 of the PDF preview).
• Dante and Seth are the Blood Angels Lords of War (based on a picture of Force Requisition).
• Seth is 155 points (confirmed via a picture of Force Requisition).
• Librarian Dreadnought can be your Warlord (confirmed via Blood Angels Codex preview).
• Descent of Angels is now a Warlord Trait (confirmed via Blood Angels Codex preview).
• Sanguinary Guard: Have Fearless and Furious Charge. 165 points base. Can add up to 5 more marines for 35 points each. Equipped with Encarmine sword and can upgrade to Encarmine Axe for free. Can upgrade to Deathmasks for 1 point per model or take a Chapter Banner for 25 points. Can still take Power Fists, Plasma Pistols, and Inferno Pistols.
• Death Company: Drop to WS4. Retain all previous USRs. Upgrade to Jump Pack appears to be 5 points per model. Still listed in the Troops slot.
• Death Company Dreadnought: Drop to WS4. Loses Fleet. Still ignore Shaken and Stunned results. 6 attacks on the charge (3 base + 1 for dual close combat weapons, +2 for Rage). Point costs appear to be the same. Still listed in the Troops slot.
• Blood Talons: Strength x2, AP2, Melee, Shred, Specialist Weapon*
• Magna-grapple: Move Through Cover, Reroll failed Assaults vs. vehicles*
• Deathstorm Formation: Fearless to all models in the formation. If the model was already fearless, they gain counter-attack instead. Once per game, in the assault phase, Karlaen can call a "Bloody Toll" and all models in the formation reroll failed to wound rolls.*
• Captain Karlaen: WS6. 160 points. Terminator Armour with Iron Halo, Storm Bolter, and Hammer of Baal: Melee, Concussive, Master-crafted, Specialist Weapon, Unwieldy. Warlord Trait: Strategic Genius: +1 Seize the Initiative, and can re-roll any reserve roll.
• Sanguinary Guard: 165 points. Max unit size is now 10.**
• Dreadnoughts: 100 points. Elite Slot.**
• Blood Angel Primaris Power: The Quickening. Blessing that effects either the Psyker or another character within 12". The target gains Fleet, D3 Initiative and Attacks. Roll once and apply both the result to both Initiative and Attacks. Warp Charge 1.
* - Confirmed via White Dwarf 44.
** - Probable. Images from White Dwarf 45 provide this info (see above), but the text is difficult to read.
Izgleda da su DC 29 poena, liči mi da će BA tek sad retko ko igrati.
Mozda nam se blizi novi Nekronski codex...
http://astropate.blogspot.it/2014/12/ru ... -2015.html
Ostali su jedini sam mekim koricama :)
CheMilan
Post by CheMilan »
...pa i nisi bas najbolji...
dare89a
Post by dare89a »
Ok malo rumora:
All the current rumors in one easy place:
EARLY - MID JAN
Skaven (confirmed)
LATE JAN
Necrons
EARLY - MID FEB
Harlequin
LATE FEB - MID MAR
Endtimes : Archaon
LATE MAR
CSM Suppliment
EARLY - MID APR
Adeptus Mechanicus
LATE APR - MID MAY
Warhammer Fantasy 9th (or a new Game called "Warhammer")
LATE MAY
Maybe Sororitas
EARLY JUN
New Warhammer Starter Set
31. januara...
Valjda onaj "Decurion" sta vec nece biti jedini nacin sastavljanja vojske...
Nece, ono je njihov unique detachment, koji je bas... cudno kompleksan >.> kombo detachmenta i formacije, koliko vidim.
Moar dakka marine style:
1. Reanimation protocol changed like Fantasy's ward save. Can be used at Instant Death.
2. Resurrection orb now gives reroll of current phase's protocol. One use only.
3. Lychguard and Praetorian guard's point value almost halved.
4. Invul save of lychguard now same as storm shield. But no reflection.
5. Praetorian's magic stick's range increased to 12"
6. Triarch stalker now have ability which increasing nearby unit's BS.
7. At start of Each turn, Nemesor Zandrek pick one of the Warlord trait of Codex or rulebook and use it until next turn.
8. He still applies nearby enemy unit's special rule to himself.
9. All the fliers nerfed. Point increase and Weapon's power decrease.
10. Cryptek is now HQ slot.
11. Mss got serious nerf.
Eh, Mindshackle Scarabs...pamticu vas po dobrome. :cry: 8-)
Some stat changes I noticed:
Overlords (and the othet special character overlords)- WS and BS 5 instead
of 4
Lords - 2 wounds instead of 1
Cryptek - 2 wounds instead of 1
Orikan the Diviner- once the change in stats happens, it remains for the
entire game!
Flayed ones - same stats but now have 2 weapons (flayer claws, AP5, shred)
so have 4 attacks total.
Triarch praetorians - 2 attacks instead of 1.
Canoptek Wraiths - Toughness 5 instead of 4
Destroyers (both versions) - 2 wounds instead of 1 (finally)
Obelisk - 14 AV all around, instead of 12.
The Phase shifter, which is now 4+ inv save instead of 3+, states
specifically that it doesnt work on the catacomb Barge, just the Overlord,
so no more jackass rules interpretation.
Death Ray - now is 24" S10, AP1, Heavy 1, Blast, Lance
Doomsday cannon, +1 strength to both profiles (so 8/10)
Necron Special Rules
Reanimation Protocols are for whenever a model suffers an unsaved wound and can be used against "no saves of any kind" as RA is not a saving throw. It also works against instant death weapons, but not destroyer or removed from play. Standard is a 5+ and can never be improved better than a 4+. If you have fnp, and RA, you must choose which one to use., but not both.
Living Metal ignores shaken results but still loses a hull point. On the roll of a 6 at the end of the round, regain a lost hull point.
Warlord Traits
1. Warlord has Eternal Warrior
2. Warlord has Zealot
3. Warlord and friendlies within 12" re-roll failed morale, pinning and fear
4. While warlord is alive, add or subtract 1 to reserve rolls and seize the initiative after the roll is made
5. Warlord and friendles within 12" have relentless and crusader
6. Warlord must accept challenges and re-rollls all failed to hit rolls in challenges. If an enemy refuses a challenge the Warlord gains hatred for rest of game.
"This set of Datacards contains 7 large-format cards detailing the Powers of the C’tan, the psychic powers from Codex: Necrons. There are 6 powers on individual cards and the seventh card explains how to use them."
jos ako je ovaj prvi set gusenica velik kao rhino ili land raider... ovo je onda vece od baneblade-a >.>
Harlequin Psychic Powers :
http://imgur.com/a/Y0n3X
Mislim da su poslednja 3 spella samo mokre zelje :D.
Izgleda d asu se mokre zelje ostvarile :)
