POCETNICKA PITANJA
Re: POCETNICKA PITANJA
da
Q: Does a Flying Monstrous Creature that arrives via Deep Strike
count as arriving in Swoop mode? (p49)
A: Yes.
swoop: letenje, nije jump infantry. Nema biranja, mora da uleti u tom modu.
Giga
Post by Giga »
Q: When making a Shooting attack against a unit, can Wounds
from the Wound Pool be allocated to models that were not within
range any of the shooting models when To Hit rolls were made (i.e.
half the targeted model are in the shooting models’ range, and half
are not)? (p15)
A: No.
Kako se ovo odnosi na blast oruzja koja scatteruju izvan dometa? Da li i dalje mogu da ubiju samo modele koji su u dometu ili kako? Ako recimo pucam na 10 modela od kojih mi je samo 4 u dometu pita scatteruje i ubije 6, da li se sklanjaju svih 6 (dakle i 2 koja su izvan dometa) ili samo onih 4 u dometu dok one dve rane viska ,,nestanu"?
Sklanjas 4 jer su ti samo cetvorica u dometu.
Sva Blast oruzja imaju domet, napr. Plasma Cannon ima domet od 36", i to je radijus u kome mozes da alociras rane.
Nisam trenutno pri knjizi, ali mi se cini da za blast oruzja pise da mogu da se scatteruju (i time ubiju) i ono sto im je van dometa. Ponavljam - nisam 100% siguran.
Giga
Post by Giga »
Evo sta kaze u rulebooku:
Note that it is possible,
and absolutely fine, for a shot to scatter
beyond the weapon's maximum or
minimum range and line of sight. This represents the chance of ricochets,
the missile blasdng through cover and
other random events. In these cases, hits
are worked out as normal and can hit
and wound units out of range and line of
sight
(or even your own units, or models
locked in combat). If the shot scatters so
that the hole in the centre of the marker
is beyond the table's edge, the shot is a
complete miss and is discarded.
Meni deluje da to znaci da blast weaponi ne upadaju u taj "samo modeli u dometu mogu da umru" faq odgovor.
Ali s druge strane u istom pravilu:
Once the number of hits inflicted on
the unit has been worked out, roll To
tilZound and save as nonnal. Any unsavec
\founds are then allocated on the unit ar
for a normal shooting attack.
Po ovoj logici se opet hvatamo na standard wound allocation i ispada po FAQ-u da ne mozemo da ubijemo modele izvan dometa. I onda ne kapiram uopste u cemu je poenta gore rulinga da blast moze da zvizne modele izvan dometa/line of sighta.
Sta se onda recimo desava ako blast odleti izvan dometa i pogodi totalno drugi unit neki? Je li se te rane ne racunaju jerbo jedinica je izvan dometa? To bi mi bilo uzasno glupo jer onda mogu bez frke da stavljam sopstvene jedinice u blizinu i dok god su izvan dometa bas me briga ako blast scatteruje na njih.
Ja mislim da se doticno pravilo ne odnosti na blast oruzja, iz prostog razloga sto blast dozvoljava da bude scatterovan van dometa i da se rane ti modeli. Sad, ako tvoj devastator squad ima Hboltere i plazma cannone, bice glavobolja za alokaciju rana jer Hbolteri mogu da ubiju ono sto je u 36 a plasme ono sto rane.
Da budem iskren, do sada smo uvek igrali da ako blast oruzje ima domet samo do prvog modela, cak i ako rola hit, pogodjeni su svi ispod blasta, i umiru svi ispod blasta, ne samo taj prvi model ;)
Tako i treba da se ruluje. Pogresno citas drugi deo pravila. Dakle scatter koji promasi metu, ode van dometa i zakaci nesto, ubija sve sto je zakacio.
A sta ako ne scatteruje, i samo model koji je bio ispod centra je bio u dometu? sta onda? :D opet gine jedan? pa sto sam pucao blast onda? da se nadam scatteru? Znas da nikada nisam bio ljubitelj RAW-a, i taman sam se ponadao da ce ga ova edicija eliminisati... a ako ovde moram da se nadam scatter-u, to je cist primer RAW-a jer je eksplicitno napisano da moze da rani jedino ako dobijes scatter. Mislim, come on, sad moramo da cekamo sledeci FAQ jer ljudi ne umeju da shvate da GW NECE da pise RAW vec hoce da se ljudi igraju.
Odoh da rantujem negde, ne morate da citate moje gluposti :)
Mislim da je opet problem wording. Jer i hit je "scatter". Jedino sto ne mozes, jeste da pocetna meta bude van max dometa. Sve ostalo moze.
Giga
Post by Giga »
Mene najvise buni da po FAQ-u ako recimo centar blast templatea ide na sam kraj dometa oruzja, automatski to znaci da bar pola same pite biva izvan dometa i ne moze da ubije modele koje taj deo pite dokaci. U cemu je onda poenta pite uopste?
Pa mislim da upravo to pogresno tumacite.
Giga
Post by Giga »
Bilo bi lepo kada bi imali neki ruling za to, cisto da znamo sta da radimo ako se slicna situacija desi na turniru.
Samo da proverim na vreme :D:
CSM knjiga kaze:
"An Independent Character with a Mark of Chaos may not join a u nit with a d ifferent Mark of Chaos."
To znaci da npr. Khorne bike lord ne moze da joinuje nurgle squadu, ali moze da joinuje squadu koji nema nikakav mark (ili ima mark of khorne)?
U prevodu, khorne bike lord moze da joinuje chaos spawnovima koji nemaju nikakav mark?
Dzon Vejn wrote:To znaci da npr. Khorne bike lord ne moze da joinuje nurgle squadu, ali moze da joinuje squadu koji nema nikakav mark (ili ima mark of khorne)?
Da, da, da.
E malo nubovsko pitanje :D
Forge world modeli tipa marinci/terminatori/dred sa oznakama MK II-III itd kao i dredovi sa oznakom CONTEMPTOR PATTERN - jel to sve moze da se koristi kao *neki* marinci ili kao grey knigtovi?
Naime mnogo mi se svidjaju modeli i pokusao bih da napravim neku listu sa 6 dreda (prelepi moodelii) - pa me zanima jel mogu bez problema da se koriste u igri? (uz pravila odrednjenih marinaca ofc).
Posto nisam citao knjige - a spominje se nesto pre heresy oko tih modela. Moze neko da mi da detaljnije malo kako sta je to, ko sme da koristi, kako da se farba itd :D
Onda pitanje oko dredova - koje sve armije mogu da ih stave u drop podove? :)
Mogu da proxiraju bilo koji marine model bilo kog chaptera. Realno, to su samo starije verzije oklopa, to su i dalje marinci ;) Contemptor pattern mogu cak i da se igraju sa svojim pravilima, pise u nekoj FW knjizi koji chapteri mogu da ih imaju i koji slot zauzimaju.
Ridji
Post by Ridji »
Da li burne u protivnickom krugu svoje napade mogu koristiti kao power weapon-e ( ap3 ), nakon sto su u mom krugu iskoristili template napade ? Znaci pitam za isti potez, ali protivnicki krug...
ne
Koje je tacno pravilo oko starijih modela i baza - pitanje u vezi starih modela broadside (crysis modeli). Jel po pravilu moram da ih stavim na nove vece baze po kojima stizu novi plasticni modeli?
I jos bitnije koji je nase kucno pravilo oko toga :)
p.s. kolike su tacno te nove baze u mm? Da narucim sa Ebay. (ako treba)
Broadside sada idu na monster baze, ili ti 60mm.
PeraNekron wrote:Broadside sada idu na monster baze, ili ti 60mm.
Thx, tako sam i mislio po slici.
Sada ostaje jos pitanje kako glasi tacno pravilo za baze i stare modele.
Mislim da ces za turnir morati da ih prebacis na 60mm baze. Negde u rulebooku (nije mi pri ruci) pise (ili je barem pisalo u petoj) da moras da pitas protivnika ako je model na bazi koja nije za njega da li smes da ga koristis.
Hypodermic wrote:Mislim da ces za turnir morati da ih prebacis na 60mm baze. Negde u rulebooku (nije mi pri ruci) pise (ili je barem pisalo u petoj) da moras da pitas protivnika ako je model na bazi koja nije za njega da li smes da ga koristis.
Hmm cudno.
Posto znam da je u fantasy ovako 100%:
Model se koristi sa bazom na kojoj je dosao kada je izasao.
Primer: stari zmajevi na 50mm, novi na 50x100mm..
Am, da, ta semanticka zamka. Actual wording je "the base the model came with", a ne "when the model was published". Nigde se ne spominje da li je retroaktivno na predhodne edicije ili ne. U svakom slucaju, na turnirima se trazi baza od trenutne edicije modela.
A sto se rulebooka tice, u 6oj ediciji je da, i citiram:
"The rules in this book assume that models are mounted on the base they are supplied with."
Nigde se ne spominje edicija modela. Ovo je jako otvoreno za tumacenje, i zagovornici RAW-a su da mozes da koristis stare baze (po kojoj logici, terminatori bi trebalo da mogu da idu na 25mm baze a dreadnoughti na cetvrtaste baze, sto je debilno).
Takodje:
"you should always feel free to mount the model on a base of appropriate size if you wish, using models of a similar rype as guidance."
Drugim recima: PITAJ TORUNAMENT ORGANISERa.
kako na kom. meni nisu pravili problem da imam terminatora na manjoj bazi, a terminatorska baza je pre 7-8 godina prva "narasla"... ako mene pitas, baza modela sa kojom je kupljen je definitivna do zvanicnih FAQ. Drednoti su, inace, jedno vreme dolazili i bez postolja, kao ostala vozila.
Malo cudno pitanje:
Dam unitu od 3 crysis suits tl. flamere i obicne flamere. Stoje na 6 inca od npr fire warriora - koje charguje nesto.
Moji crysis suits kazu support owerwatch - dal moze svaki suit da radi support owerwatch sa oba oruzja?
I dal ima neke logike da moze uopste da radi SUPPORT owerwatch sa flejmerima? :roll: :roll: :roll: :roll:
Nesto mi tu nema logike da ovi pucaju bacacima plamena kroz ove. :|
1. da, mozes sa oba oruzja ako bi inace mogao sa oba oruzja (ako imaju relentless svi suitovi, a mislim da imaju, zar ne?)
2. domet oruzja se i dalje gleda. mislim da to vazi i za flamere, iako isti rade d3 automatskih pogodaka.
3. da li mozes overwatch kroz svoje... pa mislim da bi to dalo cover ovima, i dalje se gleda LoS, zar ne? dunno?
Nemaju relentless suitovi.
Koji je domet flejmera onda u owerwatch??
Zar nije flamer no cover - jel mu je onda i owerwath no cover :)
da, flemeru jeste no cover, i u overwatchu mu je, i onaj templet je 8 incha, ali ne secam se da li se gleda da li je to u dometu, znam da se za sve ostalo gleda. Inace flamer radi auto d3 pogotka, i ne znam zasto sam pitao za relentless, mislio sam za neko pravilo koje im dozvoljava da inace pucaju dva oruzja (multi-tracker? to bese?). Ako imaju to, onda onoliko oruzja koliko mogu normalno da pucaju, toliko pucaju i u overwatchu.
EDIT:
HOLY F*** ne meri se domet za template overwatch, flameri uvek rade auto d3 hitova bez obzira koliko je meta udaljena. Ouch? Dok ne izadje FAQ, to znaci da svi tvoji koji su u 6 incha od uchargovane jedinice, ako imaju flamer rade d3 hita jer, eto, moze im se. Kako su tacno pucali i kroz sta, totalno nebitno! 8O 8O 8O
Nece izaci FAQ za to. Mi koji smo procitali pravila smo to vec znali O:) O:) O:)
Zaista mislis da nece izaci FAQ za tau da nece moci da pucaju flamerima tako? Ajd da vidimo.
A za ovo, iskreno, zaboravio sam, proveravao sam da li mora da se postavi template ili ne, sta vise istripovao sam se smo mozda svi pretrcali preko toga :)
u knjizi pravila pise da ako ti najavis assault on moze da radi overwatch bez obzira sto oruzje inace ne bi imalo domet
meri se jedino u slucaju da orzje ima 2 moda (rapid fire), U slucaju rapid fire, ako model nije u 12", onda puca 1x
Nece izaci FAQ za to. Stara demonska knjiga je mogla da ima 9 flamera i radili su upravo tako - 9d3 overwatch autohitaca. Mislim da im je to bila ideja kako bi sprecili unprobable charges (sa 12" kazem assault, pa ako me ukenja...).
Pitanje> pravilo I've been expecting you inkvizitora Coteaza... da li radi na vozilo u kome se ovaj bratac nalazi, tj da li transport moze da puca na rezerve koje dolaze u 12 inca od njega?
ovo gornje pitanje jos stoji, ako neko zna...
elem,
pitanje 2. gde tacno pise da vindiker ne moze da se prikljuci nekoj jedinici... u starim pravilima je eksplicitno pisalo, a ja sada ne mogu da nadjem u grey knights knjizi...
Nema independent character special rule.
Megabaja wrote:Pitanje> pravilo I've been expecting you inkvizitora Coteaza... da li radi na vozilo u kome se ovaj bratac nalazi, tj da li transport moze da puca na rezerve koje dolaze u 12 inca od njega?
Ne može, kaže and his unit, on nije priključen transportu.
nema ni jedan model iz grey knights knjige. svima pise isto>
1 (unique)
i
infantry (character)
1 (unique)
i
Evo gledam sad u codex i imaju ga svi characteri.
