Secrets of the Third Reich
An I have just received a customer order for a game that looks so bl**dy good I'm going to get some starters in to see what it's like.
It's called secrets of the 3rd reich and it's a wargame with supernatural bits to it. Like Tannhauser without the board and with unpainted metal minis.
Just looking through the rules and will write more when I know the mechanic.
Re: Secrets of the Third Reich
Samo cu da kazem pogledao sam i cudno je, ako je mehanika dobra sto da ne...
Zombi nemci, i gomila uvrnutih, ali interesantnih stvari...
Svidja mi se i to sto je setting stavljen u 1949... Stvarno je dosta slican Tanhauseru...
A bit Warmachiney too - battle armour for the Yanks.
Speaking of Tannhauser, what's going on with that Novgorod expansion we've been hearing so much for the past ... year or two?
The exact same thing as half a year ago. It's slated for release this Fall.
Prikazana je i prodavana na Gen Conu. Verovatno će uskoro biti i u široj prodaji.
Patience makes the flowers bloom.
For some reason, I read that as "boom" :DFGSerbia wrote:Patience makes the flowers bloom.
Okačio sam opis igre na moj blog:
http://waxerspasttime.wordpress.com
Dobro, meni ovo zvuci zanimljivo jos otkad mi je Damjan objasnio o cemu se radi... Igra li neko ovo uopste?
Osim njega? mislim da ne...
Procitah pravila, deluje zanimljivo, mada su modeli tezak shit...
Ali ako bi koristili ove modele... www.boltactionminiatures.co.uk ... mozda bi se nesto i moglo napraviti...
u svakom sluchaju je u planu naruchivanje ovih figura:
http://www.leisuregames.com/acatalog/Ru ... ames_.html
EDIT: wow, totalno sam mislio da je ovo Monsterpocalypse tema... 8O
I onda kliknuh na link i razmisljam se, vojnici iz WW2? wtf? :lol:
Da li je neko probao SOTR i da li bi mogli da podelite kakvi su utisci???
Damjan je odigrao par partija, valjda ce se javiti.
