Pravila MKII:
http://privateerpress.com/files/WARMACH ... 0Rules.pdf
Kartice MKII:
http://privateerpress.com/files/WM_MkII_Cards_0.pdf
Sumanjm da ce tako brzo izbaciti finalna pravila posle testa.FGSerbia wrote:The Hordes Field Test release has been announced for the 24th of November. This means combined tournaments by December!!
HOOOOOOOOOOOORRRRRRRAAAAAAAAAAAAAAY!!!!!!!!!!!!!!!!!!!!!!!!!!! I love you resurrection!
Ali ovde nije "RNG CMD" nego: While in this modelʼs command rangeSacrificial Strike (*Action) - RNG CMD
Leadership [Bloodgorgers] - While in this modelʼs command range, friendly Bloodgorger models gain Overtake.
QEDPravila strana 82 wrote:Every model has a command range equal to its CMD in
inches. A model is always in its own command range.
Mozes naci jos abilitija koji rade u RNG CMD (Tartarus - Curse) i koji rade u command range (Harbinger - Awe)Knjiga mudrosti wrote:Some abilities have a range (RNG). An ability’s range is the
maximum distance in inches it can be used to affect another
model or unit. Measure range from the edge of the base of
the model using the ability nearest to the target up to the
maximum range of the ability. If the nearest edge of the
target model’s base is within the maximum range of the
ability, the target is in range. A RNG of “CMD” indicates
the ability has a range equal to the model’s CMD.
When a model uses an ability with a RNG, it must target
a model in its line of sight. Determine if the target is in the
Cak i da krajenje bukvalno shvatimo rechenicu, samo imamo interpretaciju da ti max rng sluzi za afektovanje drugih modela.An ability’s range is the
model or unit.
- boldovano je dodato.An ability’s range is the
maximum distance in inches it can be used to affect this or another
model or unit.
Dakle: Sad radi, kad izadju finalna pravila nece raditi.Haight wrote: Answer is:
RAW, Gerlak would benefit from both Killing Spree and Overtake (via leadership ability).
However, after discussions with other Infernals and development, I have been authorized to announce the following statement, which comes straight from DC / Jason (and thus, is Official (tm)).
There was some questioning as to why Leadership is phrased in one manner and why No Sleeping on the Job is phrased in another. No Sleeping on the Job is phrased, intentionally, so that the model with the ability is granted the benefits even if it does not share XXX type. Leadership is intentionally built so that the XXX type is required. I issue this only to clear up that point of confusion, and not as an extrapolation of the above clarification or announcement. It is an intentional flexibility built into the one, and rigidity built into the other - it is not inconsistency.In the final version of Slaughterborn's card, he does not have the Bloodgorger subtype.
Thus, this entire question will be moot with the changes made to the final model. I will leave this thread open for remark, but keep in mind that the rules forums are not the place for criticism, bickering, or commentary out of the realm of rules and their mechanical interactions. Just a friendly reminder given the heated nature of this thread.![]()
-- Haight
